Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-13-2005, 12:02 PM   #1
SooobieSnack
Member#: 44380
Default Tach output from the ECM digital or analog?
I'm wiring a Stewart Warner G.U.S. tach and I need to know whether the signal from the ECM is digital or analog???
SooobieSnack is offline   Reply With Quote
Old 01-13-2005, 02:52 PM   #2
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
waveform?
psyber_0ptix is offline   Reply With Quote
Old 01-13-2005, 05:53 PM   #3
brunetmj
Member#: 8023
2004 2.5 RS
Is the stock tach on the car digital or analog? Numbers or needles?
brunetmj is offline   Reply With Quote
Old 01-13-2005, 07:16 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The output is more then likely going to be digital. ie if you read it with a voltmeter or osciliscope, it would read an alternating 0 and 5v. Or as mentioned could be waveform. I'm not really sure.
The stock tach is analog, but it has a motor that moves the needle. There is a controller in the combination meter that tells the tach motor how to move.
Legacy777 is offline   Reply With Quote
Old 01-13-2005, 11:22 PM   #5
brunetmj
Member#: 8023
2004 2.5 RS
The more I think about this the more I believe your right. I suppose if the tach was considered analog there would be some sort mechanical mechanism moving the tach. More than likley the instructions are asking about analog in case you have an old car.I have installed two different brands of market tachs in an STI and never was asked that question.
Old 01-14-2005, 09:12 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it is digital; ie, it has two states, on and off. the speed at which it changes state indicates rpms.
Old 01-14-2005, 10:17 AM   #7
SooobieSnack
Member#: 44380
Yeah, I think it's digital too. I'll let you all know once I get the tach in.
help diagnosing whine from the engine bay or transmission Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-19-2010 08:58 AM
Tach output signal wire nwindyz Electrical & Lighting 1 05-01-2007 08:30 PM
Advice from the Locals: EM or Hardware FIRST? Tricky Vancouver Impreza Club Forum -- VIC 52 03-12-2005 02:51 AM
Anyone from the Staten Island or surrounding area? 03MBP Tri-State Area Forum 48 08-01-2003 05:31 PM
Noise from the rear bearing or diff? JAnderson Normally Aspirated Powertrain 3 05-12-2003 05:53 PM
