Old 01-13-2005, 02:38 PM   #1
silvscorp
Member#: 28480
Default leaving for a trip, how much gas should I leave in the car?
I am going be out of the country for roughly one and half month. So basically the car will be garaged untill I come back. My question is how much gas should I leave in the tank? Half, less than half or I shouldn't even worry about it for such a short time.
thanks
silvscorp is offline   Reply With Quote
Old 01-13-2005, 02:44 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
You shouldn't really worry about it. But if you are worried, fill it to the brim.
Julian is offline   Reply With Quote
Old 01-13-2005, 03:29 PM   #3
silvscorp
Member#: 28480
u mean fill all the way up? well i have about half tank left and when I leave it might be a quart or so.. if that's ok?
Old 01-13-2005, 03:32 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
A fuel tank should be stored full(or completely empty and purged) to reduce condensation in it...fill it
Old 01-13-2005, 03:37 PM   #5
silvscorp
Member#: 28480
thanks for the explaination.
Old 01-13-2005, 03:44 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
yeah
water lock in the line is never any good
happened to a guy i worked w/
i guess he just drove around w/ a low tank for a while and it froze water in his fuel line, the nights were cold here like 25-30deg highs luckly i dont know how but i knew it was that and said push ur car in a garage for over night and ittle start in the morning, sure enough
Old 01-13-2005, 04:12 PM   #7
cnk
Member#: 10757
2013 BRZ Limited 6MT
I'd also add a bottle of Stabil.
Calvin
cnk is offline   Reply With Quote
Old 01-13-2005, 04:29 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Calvin
Read/follow the directions
Old 01-13-2005, 10:55 PM   #9
cnk
Member#: 10757
Sorry Uncle Scotty. . .1 ounce for every 2.5 gallons. Is that better?
Calvin
Old 01-14-2005, 05:35 PM   #10
andyfish
Member#: 66277
2004 WRX Wagon
Leave you parking brake off if you can. The brakes can cease a for bit upon returning due to rust.
andyfish is offline   Reply With Quote
Old 01-14-2005, 10:59 PM   #11
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Worst problem I have had letting a car sit for a month was brake rotor rust (1 time so bad they had to be turned). Can you get someone to drive it around at least once a week?
Mike Wevrick is offline   Reply With Quote
Old 01-15-2005, 05:23 PM   #12
Bottom Feeder
Member#: 2808
It's 'seize', my friend.
Bottom Feeder is offline   Reply With Quote
How much movement should there be at the front diff. DIRTWRX Transmission (AT/MT) & Driveline 0 11-17-2009 12:34 PM
How much nuts should you put in your mouth each day? Sephro Off-Topic 17 02-13-2007 02:35 PM
how much lower does greddy lip make the car? dFunk Interior & Exterior Modification 9 12-26-2005 10:16 AM
How Much Do Your Looks Matter in a Car Deal? Seahag1978 General Community 27 07-13-2005 02:07 AM
How much and where to go in the SE? press in new backing plates. mpaone South East Region Forum 7 01-19-2005 02:23 PM
