#1 |
Member#: 72021
Vehicle:1999 JDM GC1 IMPREZA WHITE |
While reading a post of how to install an air/fuel gauge on Ravensbade-Impreza.com, I came across a term known as a "vampire" tap, he used it to connect the sensor on the gauge with the O2 sensor wire at the back of the ECU and apparently he didn't have to cut the O2 sensor's wire either to splice it. Does anyone have a picture of this orknow where I can go on the net to find more information about it. It seems to be a very ingenious gadget and I would like to know about it so I can purchase one here in Barbados. Thanks.
#2 |
Member#: 60671
Vehicle:91 Suzuki GS500E 99 STM RS stg2 (gf's car) |
vampire taps are often also called quick splice'es. you can find them at any walmart, advanced auto parts, or pepboys.
they are very handy. but be careful. in wires that use waveform signals, it sbest to strip and solder. you dont want to have the "teeth" cut a part of the wire permenantly hurting throughput. expect to pay 2-6 bux for a pack of 5-20 |
#3 |
Member#: 16200
Vehicle:bah straw and coal straw and coal as always |
3M makes 'T' taps, too.....another great product
#4 |
Member#: 10757
Vehicle:2002 WRX Sedan Platinum Silver Metallic |
I don't really recommend the use of t-taps/vampire taps. They present the possibility of cutting through some of the copper wiring and weakening the wire. Especially for ECU wiring, I would carefully strip a section of the wire and use a linesman's knot. Then secure it with good electrical tape.
Calvin |
#5 | |
Member#: 60671
solder owns all ![]() |
#6 | |
Member#: 10757
![]() Calvin |
#7 |
Member#: 8023
Vehicle:2004 2.5 RS |
#8 |
Member#: 22412
SWIC
Vehicle:2002 WRX Sport Wagon Platinum Silver Metallic |
Vampire taps are just fine if used properly (these are low voltage, low current, taps) - you want to use one which is appropriately sized for the wire gauge you are using (one which is too small might cut the wire, and one which is too large might not make contact) and keep in mind that they are not water-tight (so they are inappropriate for under-hood use) - I also wouldn't want to use them for much other than power for a gauge - anything passing a signal and it's probably better to strip and solder. (one caution - make sure you use the tap in an area where you can readily repair the wiring harness if something bad happens)
here's a link for some are Radio Shack ($1.69 for 4) ![]() |
#9 |
Member#: 8023
Also useful for hard to get to places.
#10 |
Member#: 29355
NWIC
Vehicle:03 subarus are for lesbians, not douchebags |
that is a mondo-ly hard to get to place.
but i did it with traditionaly cut and splicing. |
#11 |
Member#: 43245
Vehicle:02 WRX WR Blue |
I don't like vinyl electrical tape too much. If you can't pull the pin out of the connector and use heat-shrink tubing, use self-fusing tape instead. It glues itself to itself really nicely, and you don't need any heat either.
#12 | |
Member#: 60671
where to pick this up:? and most obviously, its insulated, correct? |
#13 |
Member#: 43245
I got a roll at The Home Depot.
Insulated, yup. It's for electrical use. Looks just like vinyl tape, but it has a peel off backing on one side. It's not really sticky either, until you lay it over itself. |
#14 |
Member#: 40949
Vehicle:2003 wrx wr blue |
it's for pipes!
i love the ****...just like the factory wrappings on my starion!! no sticky mess, easy to use, hard to pull the backing off tho |
#15 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! '95 Montego Miata |
I 3rd using the self-fusing tape.
Also, IMHO, the type of taps shown by DrD are much easier to use correctly and are more mechanically robust than the type shown by brunetmj. |
#16 |
Amish Rake Fighting
Moderator |
Since I solder for a living, is a Soldering FAQ needed?
#17 |
Member#: 3601
NWIC
Vehicle:2006 WRX Wagon BRIGHT BLUE! |
A comment from an avionics technician:
While soldering and insulating using heat shrink is OK, the recommended way to splice and tap wires is to use a proper crimped connector and crimper. A crimped connection does not have the stiffness of soldered junctions and is less likely to break due to vibration over time. Having said that, either is acceptable. But a good crimper is often quicker and easier to use in tight spots - and makes very good lifetime connections! |
#18 | |
Member#: 8023
#19 | |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
Those vampire taps have worked really well for me for low voltage stuff (gauges, on/off signal wires). |
#20 |
Member#: 56143
South East
Vehicle:Fit is Go |
Bringing this subject back to life-
I ordered a set of edms and they come with a wiring harness that uses vampire taps. Does anyone have any experience with using the taps for headlight applications? Would I be better off buying (making one isn't an option) an alternative to these? Any opinions? thanks |
#21 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO |
Those taps are not the best thing to use for headlights or other high-current applications, especially when they are also exposed to the environment. They may work ok at first but the connections will deteriorate over time and eventually become intermittent or fail completely.
Only crimped or soldered connections should be used with your headlights, and everything should be fully insulated and sealed to protect the wiring from the elements. |
#22 |
Member#: 56143
South East
Vehicle:Fit is Go |
yea...that's what I figured. I just ordered a true PnP harness from wagons_ho
#23 |
Member#: 12763
Vehicle:2003 Impreza WRX wgn rally blue |
hey, instead of talking about silly stuff like "go to home depot" does anyone know which freaking sensor wire to cut and/or tap to make the A/F gauge work?
i don't have a current ECU diagram and any help would be appreciated. also, why read off the rear O2 sensor ? i would think front O2 would be more appropriate due to my new exhaust and LACK of a catalytic converter. thanks, jason sadistic@vt.edu |
#24 | |
Member#: 41097
SCIC
Vehicle:2005 WRX Aspen White |
#25 | |
Trust no one
