Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 01-13-2005, 02:47 PM   #1
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
Question Splitting the stock EGT sensor signal to both ECU and a aftermarket gauge
Hey I was wondering if its possible to split the signal from the stock egt sensor to both the ecu and a separate egt gauge. I searched and couldn't find anything on this topic. Does anyone have an idea how to do this or has done it?
Worxman02 is offline   Reply With Quote
Old 01-13-2005, 05:06 PM   #2
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
The stock egt probe only serves to monitor proper uppipe cat. temps/function--no useful data there.
Subahaulic is offline   Reply With Quote
Old 01-13-2005, 06:01 PM   #3
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
i was thinking about getting a helix flex up-pipe with a egt bung. I thought that by splitting the signal it would be easier than trying to drill a new hole somewhere and also be useful. Thanks for the info subaholic
Old 01-13-2005, 06:19 PM   #4
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
For you question I would think yes since there are two wires for the stock EGT sensor and 2 for ones like the autometer EGT gauge. Now the thing is... and EGT gauge will not get a good (worth anything) reading from that location. What most people do is tap the header in the 3rd or 4th runner. There is a flat circle button on the driverside stock header which is perfect to tap. I have read nothing positive from using a EGT gague from the uppipe bung its too far from the block.
Tur1smoWRX is offline   Reply With Quote
Old 01-14-2005, 10:38 AM   #5
sloppy_seconds
Member#: 79435
so running one in the DP would be too far as well then...
sloppy_seconds is offline   Reply With Quote
Old 01-14-2005, 10:45 AM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You want to run the EGT sensor ~2" from the heads.
mbiker97 is offline   Reply With Quote
Old 01-14-2005, 01:44 PM   #7
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
You will have to have one taped, there is no getting around it if you want proper readings. Also if you are using an aftermarket uppipe without a cat you should bolt up that bung and get a resister for it. That will give your ECU proper feedback and you wont damage your stock EGT prob if you ever should need it.
Old 01-14-2005, 06:25 PM   #8
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
Thanks for all the input guys. its been a big help especially Tur1smoWRX thanks.
Old 01-14-2005, 06:54 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Any aftermarket gauge would need to have its own sensor, even if you connected the factory probe directly to the gauge w/o the ECU connection it would not be accurate. The factory probe is a negative coefficient thermistor, most aftermarket gauges use thermocouples. The two types are not compatible. Also if you tried to connect a gauge across the existing probe, not only would the readings be inaccurate but the gauge would load the circuit down and cause the ECU to get inaccurate EGT readings as well.
Old 01-15-2005, 11:26 AM   #10
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
Thanks mulder. Thats exactly what i wanted to know. I had a suspicion that splitting the signal would mess it up. Thanks! 2.2kohm resirtor mod for me when i get my up-pipe
Wanted: Stock EGT sensor. Broken is fine, just need the harness. fiveightandten Private 'Wanted' Classifieds 2 10-12-2009 04:39 PM
Stock EGT sensor...same as aftermarket??? subieworx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-27-2006 02:42 PM
anyone use the stock EGT probe to run your gauge ? SportyBry STi Forum Archive 2 08-23-2003 10:03 AM
catless uppipe+stock egt sensor or aftermarket sensor? other q's AWDconvert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-28-2003 08:48 AM
Do I need a special tool to remove stock EGT sensor from uppipe? tnmn28 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-16-2002 08:12 PM
