Old 01-13-2005, 04:06 PM   #1
ride4fun05
Member#: 62747
1998 Impreza L
Red
Default A quick question about cooling
I am putting an ej20 in my 98 L with an FMIC, what are my options for radiators, will the stock one work?
ride4fun05 is offline   Reply With Quote
Old 01-16-2005, 01:16 PM   #2
dentprone
Member#: 18588
1999 busted car
silverthorn
If you have a new ej20 then you will need to make a new top radiator hose..to fit the oem type of radiator that your 98 L model has...cuz the pipe for the top radiator hose comming from the ej20 comes straight out..and the one on your L model comes out on an angle.. C&R makes an awesome radiator that will bolt right in place..KOYO makes a stock size radiator as well as a thick ass 53mm one that bolts to your L body..just pick up some spal thin fans and mount em up... if you want to use a wrx radiator, and hoses you will have fab up some upper and lower braces to hold your radiator in place since the body is now the same..but it does fit with some pursuation..
dentprone is offline   Reply With Quote
Old 01-16-2005, 01:55 PM   #3
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
right now chaste automotive has a way sick custom radiator that will work with your stock fans(with minor modication)..i think he is selling it for 375 give or take. it big, its beautiful. but yes your stock radiator will work, just keep in mind that you will have to replace it sometime.
Rick
scoobydorift is offline   Reply With Quote
Old 01-16-2005, 02:01 PM   #4
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
question about cooling fan woaiwrx Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-22-2007 05:12 PM
quick question about oil pressure...worried about my car Blindeye_03 South East Region Forum 6 09-03-2004 11:58 AM
PC builders, I have a question about cooling... gongzero Off-Topic 23 10-01-2003 03:34 PM
Help, need quick answer to quick question about ezpass munkis General Forum Archive 2 09-29-2000 03:45 PM
