Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 01-13-2005, 06:45 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default New Coilovers Available! Stage 1-4 Suspension Packs from RaceComp!
NEW Staged Suspension Specials for 04-05 STi!!!
Stage 1 - $689
STi JDM Pink Lowering Springs
Group N Hardened Strut Top mounts
Stage 2 - $459
Whiteline Anti-lift Kit
SuperPro Steering Rack bushings
Perrin front and rear swaybar endlinks (WRX or STI)
Stage 3 - $649
Cusco (21mm or 22mm) Front Swaybar
Cusco 22mm Adjustable Rear Swaybar
Cusco Front Strut Brace
Cusco Rear Strut Brace
Stage 4 - $788
STi Aluminum Lateral Links
STi Pink Trailing Arms
Other Items:
Whiteline Steering Rack Bushings
These bushings are direct replacements for the softer stock steering rack bushings. Made of high-quality polyurethane, they will firm up the steering feel.
RCE-WL-SRB Whiteline Steering Rack Bushings -- $35.00
SuperPro Steering Rack Bushings
Made by Fulcrum Technologies, the same company that makes the Whiteline Bushings. The polyurethane bushing kit replaces the stock soft rubber bushings for quicker steering response. These will fit the MY98+ WRX/Impreza RS&TS/STi. These are the same 30mm style as the Whitelines, just much cheaper. Will not fit the MY05 STi.
RCE-SUPERPRO-SRB SuperPro Steering Rack Bushings $29.95
Whiteline ALK
Anti-lift/caster kit adds +0.5deg. Changes front anti-lift geometry reducing understeer. Supplied with new poly bushes.
RCE-ALK-WRXSTI Whiteline ALK MY 02-05 WRX & Sti $189
RCE-ALK-GC8 Whiteline ALK MY 93-01 Impreza $179
Whiteline Camber Bolts
The most cost effective solution on the market but not at the expense of quality. Not only does it provide the greatest adjustment range (up to 1.5 - 1.7 degree change) but it also allows repeat adjustment with out slipping. Can't get that with other designs.
RCE-WCB Whiteline Camber Bolts $64.95
Whiteline Adjustable Front & Rear Sway Bar
RCE-FSB-WHITELINE Whiteline Adjustable Front Sway Bar MY 02-05 WRX $165.00
RCE-RSB-WHITELINE Whiteline Adjustable Rear Sway Bar MY 02-05 WRX $165.00
RCE-FSB-WHITELINE-S Whiteline Adjustable Front Sway Bar MY 04-05 STi $170.00
RCE-RSB-WHITELINE-S Whiteline Adjustable Rear Sway Bar MY 04-05 STi $170.00
Suspension:
Cusco 21mm or 22mm Front Sway Bar for 02+ WRX and STi -- $165
Cusco Adjustable Rear Sway Bar for 02+ WRX -- $169
Cusco Adjustable Rear Sway Bar for 04+ STi -- $165
Perrin 22mm Front Sway Bar for 02+ WRX and STi -- $145
Perrin Adjustable Rear Sway Bar for 02+ WRX -- $195
Perrin Adjustable Rear Sway Bar for 04+ STi -- $210
Perrin Rear Endlinks for 02+ WRX -- $115
Perrin Rear Endlinks for 04+ STi -- $135
STi Pink Lowering Springs for 04+ WRX and STi -- $399
Zeal V6 Coilovers for 02+ WRX -- $2855
Zeal V6 Coilovers for 04+ STi -- $2855
This steel-type, inverted-monotube type shock absorber is produced for specific vehicles with strut-type suspension. The shock absorber for this type of set up takes great abuse, thus side load attributes must be strengthened. An inverted monotube with a Friction-Loss Cylinder was developed for this matter. While using the Function Series' technology, we've produced the new Zeal model for high performance driving. The nitrogen gas camber is positioned higher up and farther away from the braking area creating less heat transfer and thus, less chance for overheating. Also, under-spring weight is now lighter enabling handling to become sharper, quicker, and more responsive. Our easy-to-read and use, 6-Way Piston Valve Shock (PVS) Dial mechanism adjusts the rebound/compression force with its Piston Valve Shock Technology, Level 1 being the softest and Level 6 being the stiffest. Dial can be turned either direction infinitely. Pillow Ball camber adjustable upper mounts for direct feel of suspension motion help to decrease piston rod tension. ID60 Basic Spring (Street or Hard rates) maintains stroke and ensures a "seated" fit with upper and lower portions processed to a flat cut. The Adjustable Shock-Stroke System is a separate, adjustable lower cup/bracket used for height adjustability which eliminates problem of sacrificing stroke and altering spring tension. Spin the mechanism over the threaded shock casing up to lower (and down to raise) vehicle height. All Zeal Function Series systems include this height-adjustable system.
CUSCO for MY05 Legacy GT
Front 23 mm -- $226
Rear 21 mm $178
STi Pink Lowering Springs for MY05 Legacy GT -- $399
STi Front Titanium Strut Tower Brace for MY05 Legacy GT -- $349
STi Trailing Arm / Lateral Link Set for MY05 Legacy GT -- $569
STi Brembo Brake Kit for MY05 Legacy -- $CALL
Myles Williams
Racecomp Engineering LLC
www.racecompengineering.com
9123 Old Annapolis Rd. Suite 103W
Columbia, MD 21045
410-730-RACE (7223)
410-707-0108 cell
RaceComp Engineering is offline
Old 01-13-2005, 07:11 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Cusco heard your request, and have now answered with the all new Zero-2E system. With all the same benefits and features as the Zero-2 coilover, the Zero-2E adds the option to electronically control the shock adjustment from inside the car. Utilizing the E-Con (sold separately), you can select what stage (of 5) you want the shock set at. With great features such as:
- Electronically controlled shock adjustment (w/ E-Con)
- Pillowball upper mounts
- Adjustable shock casing
- Independent adjustable spring perch
- Stainless steel thread body
- Stainless steel case lock nut
- Stainless steel spring perch/lock nut
- Specially coated lower bracket
Performance!
Fits perfectly for any style driving. The advanced design features 5-stages of shock adjustment that exhibits incredible performance!
Comfort!
Create a comfortable ride for your passengers. Too stiff? Comfort is just a button away. No more frustrated passengers!
Strength!
Larger size pillowball used in the upper mounts. Endures through the hardest drives!
Setting!
Height adjustment and spring pre-load are designed to be adjusted independently. Lower your car with the adjustable shock casing while retaining the overall shock stroke. Set the spring pre-load to your desire and feel the difference in driving and traction.
Anit-Rust!
Worried about rust? No problem with the Zero-2Es stainless steel lock nuts, lower seat, and threads. With the external cylinder and threads being stainless steel, adjusting the height will be smooth. The lower bracket/case has a new special coating as well. The internal as well as the external surface has been coated.
*be sure to always clean the threads prior to adjusting the height. Road debris and brake dust can settle on the threads causing difficulty in smooth adjustment.
New Shock Absorber!
Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered.
- New design: Side port rotary valve
- New: Reduced friction piston
- New oil reducing cavitation
- New material: Special steel for piston valve shim
E-Con
Memorizing!
- 6 preset memories available
- Only a push of a button needed to fit any style
Rebound Force Adjustment!
5 stage adjustment for the front and rear independently. Each shock is designed specifically for the vehicle application. (one by one adjustment operation)
Stylish Operation Panel!
With the operation panel thickness being a mere 30mm, installation and location options are increased. The compact control unit can easily be hidden away and out of sight.
[IMG]
http://www.napsusa.com/Nukabe/pictures/econ.jpg[/IMG]
Adjusment Moniter
The E-Con uses high quality adjustment motors to control the rebound force quickly and accurately. The motor utilizes a special rubber cover to shield itself from moisture caused from the extreme humidity and temperatures found in the engine bay. Installation is a cinch with the specially designed bracket on the Zero-2E coilovers.
Lighting Adjustment!
Brightness of the operation panel can be adjusted. (also can be turned off)
Sound Adjustment!
Confirmation sounds can be turned on or off.
Cusco Strut Bars!
Will fit with Cusco strut bars.
The E-Con kit includes:
Rebound force controller x1
Operation panel w/ wire harness set x1
Main power wire/adjustment motor x4
Wire for motor 5m x2, 4m x2
Available for 02-05 WRX and 04-05 STI
PRICING
Cusco Zero 2E - $2160
E-com - $430
Package - $2475 SHIPPED!
Call us to order and mention this thread.
Old 01-14-2005, 11:12 AM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Prodrive Springs - $299 shipped (within the lower 48)
Old 01-16-2005, 03:19 PM   #4
AndyRoo
Member Sales Rating: (5)
Member#: 20952
MINI & Datsun
BRG & White
bump for myles
AndyRoo is offline
Old 01-18-2005, 02:49 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
bumped
Old 01-18-2005, 02:50 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
bumped for content
Old 01-18-2005, 06:14 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Ttt
Old 01-18-2005, 09:24 PM   #8
Pwise2326
Member#: 61685
1998 Legacy GT
Bump for an awesome vendor!
Pwise2326 is offline
Old 01-18-2005, 09:26 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
thanks man.,...................we try .
myles w.
Old 01-19-2005, 10:32 PM   #10
BGPKR
Member Sales Rating: (13)
Member#: 41842
2006 LGT LTD 5SM
Myles,
I've already installed the Pinks and Group N tops I've ordered from you as well as my Hotchkis Competition sway bars and Whiteline steering rack and rear diff bushings. How much of a difference will the rear lateral and trailing links make along with an ALK. I have a few more bucks to spend and want to make it count. I can't decide on suspension or power mods.
Thanks
Geoff
BGPKR is offline
Old 01-20-2005, 12:15 PM   #11
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by BGPKR
Myles,
Thanks
Geoff
well I have an analogy that I want to use , but Its not very clean( )
Yes, those two items will make a huge difference in turn in and feel. The the trailing arms and lateral links will take alot of slop out of the rear of the car, while the ALK will give more caster and the combo would be felt right away. You also will need to be smoother too.................
Myles Williams
sales@racecompengineering.com
Racecomp Engineering LLC.
9123 Old Annapolis Rd Suite 103w
Columbia, Maryland 21044
410-730-RACE
410-730-5503 FAX
410-707-0108 mobile.
Old 01-20-2005, 01:06 PM   #12
mnavarro
Member Sales Rating: (2)
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
I have a 2004 STI, can I use ingall's camber bolts or whiteline camber bolts in the front suspension. Will they slip?
Thanks
mnavarro is offline
Old 01-20-2005, 01:15 PM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Thanks
I have run the Whiteline camber bolts without any problems. My employee ran them (autocrossing ) and never had any slipping.
mw
Old 01-21-2005, 01:17 PM   #14
dunny
Member#: 4115
2002 Impreza WRX
Myles, any real difference between the Whiteline, Cusco and Perrin bars? For an '02 WRX, would you recommend one over the other?
dunny is offline
Old 01-21-2005, 02:21 PM   #15
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
I have had great success with all 3. If I were falling from a cliff and had to grab onto one..................ummmmmmm....I might grab the Cusco and at the same time, grab a Perrin endlink, with WHiteline heavy duty sway bar mounts.....
lol
Myles Williams
410-730-RACE
410-730-5503 FAX
Old 01-22-2005, 05:08 PM   #16
BGPKR
Member#: 41842
2006 LGT LTD 5SM
Hey Myles,
Which version of the ALK do you have in stock? I'm looking for the one above the comfort. And, how much shipped to 26534?
Thanks
Geoff
BGPKR is offline
Old 01-24-2005, 06:47 PM   #17
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Hey Myles,
Thanks
Geoff
the sport version is due in very soon.
mw
Old 01-27-2005, 12:45 AM   #18
subablunc
Member#: 55923
still 1 Cusco Adjustable Rear Sway Bar for 04+ STi in stock ?
If you can also have quite quickly the Helix catted DP, I'd take both in the same time. Just tell me when you'll get more catted DP
subablunc is offline
Old 01-27-2005, 01:17 PM   #19
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The Sway bar is in stock yes. Check your PM about shipping.
Old 01-27-2005, 02:01 PM   #20
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Special on Cusco Zero2r's for '05 STI, 5 sets in stock!!!!
Details in 2nd post.
Myles Williams
410-730-RACE
410-730-5503 FAX
Old 01-31-2005, 02:02 PM   #21
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
up up up
Old 02-07-2005, 12:12 PM   #22
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bump
Old 02-09-2005, 11:58 AM   #23
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Ttt
Old 02-09-2005, 05:06 PM   #24
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
AST Coilovers are now available!!! Info in at the top of 1st post!!!
Old 02-11-2005, 03:57 PM   #25
samboard
Member#: 62363
thanks myles!
rec'd the sways! great service!
sam
samboard is offline
Closed Thread
Racecomp Engineering Sale -- Prodrive, STi, Sparco, Takata, Cusco RaceComp Engineering Interior/Dressup/Audio & Security 190 03-22-2006 01:12 PM
Racecomp Engineering Sale -- STi and Cusco RaceComp Engineering Exterior/Styling 213 03-22-2006 12:56 PM
Racecomp Engineering Sale -- TurboXS, Perrin, Cusco, IHI RaceComp Engineering Engine/Power/Exhaust 148 01-24-2005 05:33 PM
Racecomp Engineering Sale -- Endless, Zeal, Rotora, Perrin, Cusco, Pagid, Ferodo RaceComp Engineering Suspension/Brakes/Handling 159 01-13-2005 05:41 PM
