Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 01-13-2005, 07:28 PM   #1
2000wrx
Member#: 66659
2000 L WRX'd
Default rear drum question...yea I searched
Just wondering, I have rear calipers, brackets, lines and rotors. Can I put these on to my rear drum knuckles, what other parts should I need?
Anyone have a good source for shop diagrams?
2000wrx is offline   Reply With Quote
Old 01-14-2005, 12:32 AM   #2
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
you will need the rear hub and e-brake lines...other than that you should be fine.
scoobydorift is offline   Reply With Quote
Old 01-14-2005, 07:24 AM   #3
2000wrx
Member#: 66659
2000 L WRX'd
cool, so if I can source rear hubs I would need a shop to press the rotors on the hub??
I so wish I had a shop manual.
Old 01-14-2005, 09:56 AM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
You don't need hubs, you need the backing plate that the caliper bracket bolts too. This plate has to be exchanged with the drum plate which means pressing the hubs off and back on. Most people just swap the whole knuckle with hubs and plates to save the trouble.
The rotors just slide onto the wheel bolts, no pressing required.
You also need the disc e-brake assemblies and cables. Those are expensive new, so find used ones. You will likely have trouble getting the lat. links out so you should have spare bolts and bushings available.
PS this has been covered many many times so try searching in the brakes and suspension forum for "drum swap" or "drum disc" Look on this site for instructions http://wac.addr.com/auto/obs/cruise/cruise.html
linsavy is offline   Reply With Quote
Old 01-14-2005, 11:14 AM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i highly recomend just getting a compete rear knuckel +cable
A. to get the backing plate you will probblay have to buy the whole knuckle
B. the cables are a major pain in the ass to change
Old 01-14-2005, 01:25 PM   #6
2000wrx
Member#: 66659
2000 L WRX'd
I am having a lil trouble sourcing the whole set up... ill keep looking..
Old 01-14-2005, 01:42 PM   #7
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
i think when i bought my whole set up it was around 150 shipped for everything....keep looking in the private for sale they will pop up.
Good luck
Rick
Old 01-23-2005, 04:20 PM   #8
pantfire
Member#: 80125
1993 Impreza L AWDMT
burgandy!
are the single pot front calipers from a 93 L the same part as the single pot rear calipers from a legacy?
pantfire is offline   Reply With Quote
Old 01-25-2005, 11:48 PM   #9
JDM_Scobaru
Member#: 57809
ahh front and rear calipers are different
JDM_Scobaru is offline   Reply With Quote
Old 01-25-2005, 11:49 PM   #10
JDM_Scobaru
Member#: 57809
My cables werent too bad. I guess its just getting the cables out of that rubber thing is hard since you have to pull kinda hard
Odd question - Why does Subaru still use rear drum brakes? Back Road Runner General Community 76 04-18-2008 10:25 AM
Rear DRUMS to Rear Disc Coversion Question W01F Brakes, Steering & Suspension 4 08-26-2007 09:38 PM
Question about rear drum - disc conversion engee Brakes, Steering & Suspension 0 05-30-2007 04:32 PM
Yet another rear drum to disc coversion question...96 Impreza brighton left footed whooten Brakes, Steering & Suspension 6 01-24-2005 02:35 PM
Rear drum to disk conversion question mpaone Brakes, Steering & Suspension 8 05-14-2003 03:49 PM
