Old 01-13-2005, 08:08 PM   #1
98SS
Member#: 65211
Default Need to change oil?
Brand new STI.
Bought it Mid Oct. 04.
Due to bad weather, work etc.
So far I only put 900+ miles on it.
I know that we need to change oil at 3000 miles. But it's going be 3 month mark soon.
Should I wait till 3000 miles or should I change it mid Jan?
Thanks.
98SS is offline   Reply With Quote
Old 01-13-2005, 08:22 PM   #2
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
It couldn't hurt.
Stanley is offline   Reply With Quote
Old 01-13-2005, 08:24 PM   #3
sir_wagon
Member#: 71549
I would go with 3 months in your case. You were driving around before the pistons rings were fully seated, so some combustion by products probably got pass the rings and into the oil. This makes the oil deteriorate even if the number of miles still low.
sir_wagon is offline   Reply With Quote
Old 01-13-2005, 08:52 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
OMGHi2U
after your first 1000 miles of break end period
i would suggest syntethic and new filter.
thing of like this, so now that the motor is broken in do
you want what particules that might be floating around
in your motor to circulate through your motor?
old school rule..change oil after break in..
my 2 cents.
Ben
Old 01-13-2005, 08:55 PM   #5
WRXVT
Member#: 17979
335i Blue
Id say follow the owners/maintenance manual... 3000 or 3750 IIRC
WRXVT is offline   Reply With Quote
Old 01-13-2005, 09:11 PM   #6
Scoobie Noobie
Member#: 65498
My dealer suggested an oil change at 1K. I did it. I've been following the book since then. Even if it's not a requirement, it's probably a good idea. (N00b talking here)
It's pretty cheap, I've wasted a lot more $ on sillier stuff than that.
Scoobie Noobie is offline   Reply With Quote
Old 01-13-2005, 10:31 PM   #7
WRXed4good
Member#: 37143
02 WRX Wagon
Alpine White
Look at it this way - price of oil and filter $15-$20
peace of mind knowing your car is good - priceless
There are no negatives so just change it!
WRXed4good is offline   Reply With Quote
Old 01-14-2005, 01:45 PM   #8
JayD707
Member#: 51018
2005 Legacy
yea id wait till u hit 1000k anddo the change
JayD707 is offline   Reply With Quote
Old 01-14-2005, 03:27 PM   #9
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
I recall reading someplace that SOA suggests that it'd be good to change your oil at around 1500 to get rid of "any material from break-in or left over from the machining process used to make the engine." I also recall reading that "Subaru does not use any special break in oil, so feel free to change it as early and as often as you like. The only downside is the increased cost of frequent changes." Or something to that effect.
Al_Smokemcrack is offline   Reply With Quote
Old 01-14-2005, 05:08 PM   #10
98SS
Member#: 65211
Thanks all.
It will be changed at 1k.
I need to change my oil jamesfacts New England Impreza Club Forum -- NESIC 38 05-02-2004 12:52 PM
Need to change tranny fluid and oil?? skyredrex Service & Maintenance 3 11-10-2003 11:17 AM
Do I need to change oil sooner after engine rebuild? cky211 Service & Maintenance 5 05-17-2003 05:03 PM
('93-'01) 13k miles-what fluids besides oil do I need to change? Robmat Impreza Forum 2 06-22-2001 06:59 PM
what oils do I need to change?? spunky Newbies & FAQs 2 10-25-2000 11:18 PM
