Old 01-14-2005, 03:28 AM   #1
mistaboosta
Member#: 68722
Default Aem Ems
Hi
I purchased an AEM EMS for my WRX. Currently I have UTEC and I am tuning it myself.
So the question is "which one (EMS or UTEC) requires more work and knowledge to tune" ?
btw i read that i would need a resistor to use my low impedance injectors (I have the PE 800s and guess they are low impedance). What kind of resistor is that and where do i install it?
mistaboosta is offline   Reply With Quote
Old 01-14-2005, 05:44 PM   #2
jlee8196
Member#: 22211
Aem ems don't let you use low imp. inj.?
I think you can use high or low . There should be an option on the inj. setting.
I Could be wrong, I remember seeing that on AEM website.
From what I heard the map that AEM EMS come with is not driveable. Only can get the car started, and that's about it.
So I would say....... yep AEM requires more tunning and knowlege.
jlee8196 is offline   Reply With Quote
Old 01-14-2005, 06:32 PM   #3
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
AEM Factory Trained Tuner
Originally Posted by mistaboosta
Hi
The AEM EMS require more work but you can achieve more horspower and much more control over the motor.
The AEM EMS dont control low impedance injectors on the WRX unless you install a resistor pack.
The PE 800 are high impedance so dont worry.
Gadiel
Gadiel is offline   Reply With Quote
Old 02-01-2005, 07:11 PM   #4
mistaboosta
Member#: 68722
what are the key problems i will have using AEM?
I know its base maps sucks and require a lot of tuning.
Old 02-01-2005, 07:15 PM   #5
Wraith
Member#: 30364
2005 Devilish STI
Angelic white
Why would you get AEM if you have a UTEC?
Wraith is offline   Reply With Quote
Old 02-02-2005, 06:07 PM   #6
mistaboosta
Member#: 68722
i will be changing the block, heads, cams etc and i want more control over my car. also my ecu has some problematic imaginary misfire issues.
Old 02-03-2005, 12:32 AM   #7
STiTuner
Member#: 5778
09 135i
Jet Black
AEM gives you a LOT more control of a LOT more features. make sure you have it tuned by someone VERY familiar with the product. I highly reccomend this product to someone who has access to a tuner know knows the ins and outs of the unit.
STiTuner is offline   Reply With Quote
AEM EMS -Trade- for Hydra EMS, 02-05 wrx AwdBoostCreep Engine/Power/Exhaust 2 05-22-2009 11:14 AM
FS: (Toronto) AEM EMS + AEM UEGO Wideband LuvJuggs Canada Region Private Classifieds 13 04-14-2009 01:42 AM
Hyrda EMS, AEM EMS, or upgrade to sti ecu/wiring harness 03SuBbYWrX Other Engine Management 3 11-27-2007 04:47 PM
AEM Products - AEM EMS, Tru-Boost, UEGO, Tru-Time and gauges!!! HorsepowerFreaks Engine/Power/Exhaust 5 11-20-2006 05:40 PM
