Mid Atlantic Impreza Club
Old 01-14-2005, 10:29 AM   #1
richy_21
Member#: 58670
2005 got muuuuu?
Default Helpppp With Up Pipe Removal
I cant get the freakn wrx uppipe of i want from the bottom of the car and removed the exhaust manfold....in other words the up pipe it hangin on by the black P.O.S. so i cant get it out...i tried vish nu instructions and removed the bolt and tried to jack it up...but the entire car went up including the uppipe. I really dont want to remove the turbo. So any help or suggestions. Im located in Charlottesville Va.
If you want to call my cell that would be great the number is 540-661-8411
Thanks Richard.
richy_21 is offline   Reply With Quote
Old 01-14-2005, 10:35 AM   #2
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I got mine out just by wiggling it, without jacking up the engine. There are two motor mounts if you actually want to jack up the engine, make sure you got them both. Also, make sure that you have disconnected the EGT probe.
Jard is offline   Reply With Quote
Old 01-14-2005, 12:38 PM   #3
KanosWRX
Member#: 17904
010 STI
Is the car on jacks or ramps? If its on ramps the car will look like its lifting up as you jack the engine, but really its only going up because you are taking weight off the suspension. So just keep lifting. If you have it on jacks, undo both sides and try that. And also make sure you un bolt the egt probe like jard said.
KanosWRX is offline   Reply With Quote
Old 01-14-2005, 12:47 PM   #4
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
you can get it out by pushing it up and down threw the down pipe location (since it is off). Meaning the turbo side of the uppipe will go up then facing the firewall and then the turbo side of the uppipe will be facing down to the ground in the down pipe spot. You might have to twist it a little but it came out very easy for me on the last car I helped on by doing it that way.
Tur1smoWRX is offline   Reply With Quote
Old 01-14-2005, 01:12 PM   #5
richy_21
Member#: 58670
2005 got muuuuu?
The car is on a lift.
Tur1smoWRX - i will have to try that next time im over there
removing studs for up pipe removal turbo_wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-21-2007 07:32 AM
Up pipe removal, engine mounts misaligning Agkelos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-10-2005 12:32 AM
Up pipe removal question. Soulofdarkness Newbies & FAQs 26 05-15-2005 06:08 PM
Who can help me with up pipe / downpipe install? MAD REX Rocky Mountains Impreza Club Forum -- RMIC 5 05-30-2002 12:11 PM
Is it safe to use stock ECU with up-pipe and turbo back exhaust (1 cat)? gtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-11-2001 08:32 AM
