Old 01-14-2005, 06:42 PM   #1
subbykid
Member#: 64516
95 Blue Legacy
EJ22-T
Default ecu/electrical problem
Okay my problemo is this...
I have a 95 Legacy L, EJ22-T, wrx turbo and IC, with the greddy emanage. The emanage has been installed while the car was NA for about 4 months with no problems, and been on the car turboed for about 3 weeks. No problems at runnning 5psi.
While coming home from school and idling at a light, my car just turned off and would not restart. There was no bad idiling or check engine light. I have new plugs/wires/battery/starter in for the last 3 wks. No low oil or coolant.
While looking over everything I see that I have a blown fuse, sbf #2. I replace it and it blows again. So I am thinking I have bad relay or ecu. I took off the emanage and it only blows when the ecu is plugged in. I unplug it and it doesnt blow.
What do you all think?
subbykid is offline   Reply With Quote
Old 01-14-2005, 08:32 PM   #2
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
crossed wires.
tooocool49723 is offline   Reply With Quote
Old 01-15-2005, 08:37 AM   #3
subbykid
Member#: 64516
95 Blue Legacy
EJ22-T
crossed wires on what? the emanage, ecu, relay, could you explain a little more.
Also the fuse doesn't blow until I go to start the car. Once it goes to the on position you hear it pop.
Old 01-15-2005, 12:39 PM   #4
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
what is SBF#2? i dont happen to have a manual right now. anyway, whats happening is that some wire somewhere got crossed, probably not the ecu, but it is controlled by the ecu. it's blowing the fuse because threre's too much current going through the fuse, and in most cases, this means a wire is grounding out somewhere.
It would be something triggered off of ignition power because it's only active (the fuse only blows) when the key is in the on position.
Happy hunting.
Old 01-17-2005, 12:59 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Legacy777 is offline   Reply With Quote
Old 01-17-2005, 05:06 PM   #6
subbykid
Member#: 64516
95 Blue Legacy
EJ22-T
yeah I got a wiring diagram of my car and saw where that sbf2 goes too (same as what you wrote above). I am not getting spark, obviously.
I pulled the fuel pump relay and the fuse doesnt blow then, so I was thinking its that, but I read that relays dont blow fuses. the ignition relay realy I didnt pull yet.
Old 01-17-2005, 06:16 PM   #7
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
If the fuel pump relay caused the fuse not to blow, then hunt down those wires, as it's probably something along that circut.
Old 01-18-2005, 06:44 PM   #8
Legacy777
Member#: 4800
Ditto this suggestion. Try unplugging the connector under the rear seat. If the fuse does blow, you know it's the wiring between the relay and that connector. if it doesn't blow, it's sometihng with the wiring going into the tank, or the pump.....which is very very bad.
Old 01-18-2005, 06:58 PM   #9
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
very very very bad... sparking wire inside tank = big bad boom.
Old 01-19-2005, 05:12 PM   #10
2003Baja
Member#: 52985
A start that you'll never forget
2003Baja is offline   Reply With Quote
Electrical Problems, Seems Like ECU is not Powering On camaroz1985 Subaru Conversions 11 09-17-2008 10:10 AM
('93-'01) Please help - Electrical problems Boeleni Impreza Forum 2 04-08-2001 08:53 AM
Electrical problems? Bohanan Texas Impreza Club Forum -- TXIC 6 12-24-2000 05:18 PM
Static electricity problem dead-eye General Forum Archive 36 12-08-2000 09:40 PM
Weird electrical problem JJTheSubeDriver Car Audio, Video & Security 4 01-28-2000 08:23 PM
