Alaskan Impreza Club
Old 01-14-2005, 06:59 PM   #1
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
Default IM Question
Took the car in today to get IM'd and the inspector wouldn't even do the dynamic test. I even put back the third cat back in. He told be with the turbo swap and the downpipe cat missing that he wouldn't finish the rest. I need to know if any of you know a place to take it where their not so anal, or if I should just put the dowpipe back in? Thanks fellas.
EMSWRX is offline   Reply With Quote
Old 01-14-2005, 07:02 PM   #2
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
ur getting screwed....they just need to plug and make sure no codes or faults in memory....and that's basically it...where did u go?
SQUAD_907 is offline   Reply With Quote
Old 01-14-2005, 07:09 PM   #3
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
Quality tune on old seward next the the U-haul place. I just need to know before I start putting S*** back to stock..
Old 01-14-2005, 07:29 PM   #4
02-elite-gettingwrx
Member#: 45650
2015 WRX Limited
yeah i have to get i.m. very soon to and would like to know where to go where i wont get hassled, i dont wanna make my car back to stock either.
02-elite-gettingwrx is offline   Reply With Quote
Old 01-14-2005, 07:29 PM   #5
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
did u tell him u had a turbo swap? how did the tech know?
Old 01-14-2005, 08:05 PM   #6
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
he saw it. I didn't tell him I had any mods. He didn't ask, so I didn't tell. Not hard to tell a nice shinny new turbo though. I even had the heat shild on. He knew the downpipe wasn't stock. Although he didn't know we had three cats, he thinks there's only two. If I don't get any suggestions, I'll just put the downpipe cat back in.....
Old 01-14-2005, 08:22 PM   #7
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
i'd go somewhere else first for the test...if the same thing happens then put the pipe back on...
Old 01-14-2005, 08:46 PM   #8
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
I think that's what I'm going to do. I read a post about somewhere on 5th. Thanks for the suggestions 907.
Old 01-14-2005, 08:49 PM   #9
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
yah u can't go wrong going to another place cuz it's no pass no pay...
Old 01-14-2005, 10:38 PM   #10
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
yeah not much room to budge on that one, I would have failed it too. Problem is the third cat doesn't work without the second cat. All I/M techs know this from training to pass the test. (at least they should) It's a chemical reaction and the second cat is critical for the gasses to be ready for the third cat. The second cat is a reduction cat, the third is an oxidation cat. It's chemistry and when you remove the reduction cat there is not enough oxygen molecules for the oxidation cat to function correctally. The first cat is only to help out before the second and third cats fire off. (aka warm up for a couple minutes) It is not used after that. It is not required in many I/M areas, but because it is a cold start feature it is required in MOA's I/M plan. This is easy to miss because of the location though, that's prob. what happened. Dissabling the egt is also a failure. The turbo is up for debate, as I have not asked anyone and I would feel that ecm or boost mods would be more of a concern than the actual turbo model. It would also be easy to miss due to the heat shield.
It is illegal to tell a customer you won't COMPLETE a test on their car unless it isn't ready for I/M, (3 months before or less), leaking to much oil/coolant to test, mechanically not able to test, (engine knock, etc.) or dangerous or damaging to the I/M equipment or tech. You cannot tell someone you won't test their car because it is failing, the city wants you to test and fail it so it is documented. Then tell customer they failed, why, and how much to fix and pass. (or in the case of a no-pass no-pay refer you to a shop that makes repairs and send you off no charge) That is why he didn't finish the test, cause as soon as he realized it would fail he wanted to get the no $ making car out of the shop. ILLEGAL! It's called pre-screening
Also every I/M test regardless of year or test type (tailpipe or OBDII plug-in) gets the same visual and functional test. Only difference with 1996+ OBDII plug-in is you don't test the tailpipe emissions, you just take the ecm's word that it is ok. You still do the visual and functional (i.e. test that pcv valve!) otherwise how would you ever find a mil eliminator or unhooked pcv line? computer won't catch those.
anyway, I've said it once here it is again, if you have second and third oem cats, or an aftermarket catted dp with non modded rear O2 sensor, non-atmospheric bov, no exhaust leaks, stock airbox or c.a.r.b. sticker for intake installed, no catch can mods, check-engine light functional and off while running, stock ebc hooked up, and no codes in memory It will pass, unless the moniters won't set for some reason. This info is to help you, and an I/M certificate is only legal as long as you leave your car like this. If you remove the parts after the test you are breaking the law, and heli-borne I/M police will desend on your house and you will never be heard from again.
00Maddog is offline   Reply With Quote
Old 01-14-2005, 10:49 PM   #11
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
actually now that I'm reading over this a couple more things, pre 1970ish don't get an underhood check, just tailpipe. Just trying to be accurate
And someone will probably wonder why an aftermarket dp with one cat will pass when one oem cat won't. Well I already explained most of it, just that aftermarket cats are both cats in one. Reduction in the first half, Oxidation in the second. That is why they only work when installed the correct direction, and why when they have an air pipe fitting is in the middle, to add oxygen for the oxidation cat in the second half. Only some cats have air pipes, on other car models.
Old 01-15-2005, 01:01 AM   #12
XR4Tim
Member#: 73802
Fast rare cars...
Lots of them
I took my old Volvo to the Jiffy Lube on Old Seward near Tudor. It had a failing Air Mass Meter, poorly functioning brake light switch, and no reverse lights (among other problems). They passed it anyway. You might want to check there.
XR4Tim is offline   Reply With Quote
Old 01-15-2005, 02:24 AM   #13
Need Money
Member#: 38096
08 Bmw 335xi
SNIKT!
You have pm
Need Money is offline   Reply With Quote
Old 01-15-2005, 04:07 AM   #14
R-one
Member#: 16497
2002 wrx wagon
WRBlue
Sorry to go a bit OT, but what do you think about the alki kit in regards to I/M Maddog? Guess it is easy enough to swap the tank to avoid the whole issue...
R-one is offline   Reply With Quote
Old 01-17-2005, 04:05 PM   #15
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
Alright, put the stock dp back in and the access port back to stock. I have an obd II that will tell me if all my run monitors are in ready status. The only thing that I can think that might be a problem is the CEL fix in the rear o2 sensor. Anyone know if this might cause me to fail?
Old 01-17-2005, 08:19 PM   #16
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
it will show either rear 02 sensor slow response, or "not ready." but i hear that you can have a couple of the monitors not set, and still pass.
AK_2002_WRX is offline   Reply With Quote
Old 01-18-2005, 01:07 AM   #17
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
yes i believe your allowed 3 not set and still pass anything more than that and its game over.
mike
tribalwrx is offline   Reply With Quote
Old 01-18-2005, 02:31 AM   #18
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
game over i wonder if my old car was ever I/Med ever since i got rid of it...
Old 01-18-2005, 08:09 PM   #19
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
Case closed! Car passed. Thanks for everyone's suggestions. With the dp and third cat, it passed with flying colors.......
Old 01-18-2005, 08:13 PM   #20
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
did u take it to a different place or same one but put the 2 cats back on?
Old 01-19-2005, 01:15 AM   #21
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
I took it to a differnt I/M station. The guy was knocking em out left and right. No more than 5 min. and he was done. He must have done 5 or 6 in the half hour I waited.
Old 01-19-2005, 01:58 AM   #22
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
congrats on passing!
Old 01-19-2005, 03:24 AM   #23
02-elite-gettingwrx
Member#: 45650
2015 WRX Limited
where did you go! i have to pass one very soon
Old 01-20-2005, 11:32 AM   #24
EMSWRX
Member#: 31547
2002 WRX WAGON
ASPEN WHITE STAGE 4
Quality tune on tudor by the gas station and subway.
Old 01-20-2005, 01:09 PM   #25
scuzzy
Member#: 29214
05 WRX Wag (Work)
91 Legacy Wag (Play)
What would you do if you had something such as an 91 Chevy that came from the factory a 305; but is now a 496 with twins.
Can you register it out of Anchorage or something? It would never pass inspection in a million years, and it's so far from stock the only thing that's original is the shell..
any ideas?
scuzzy is offline   Reply With Quote
Perplexing IM question? ) 06 vs. 07 Se7enrex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-11-2010 01:29 PM
IM Question Imprezed04 Alaskan Impreza Club Forum -- AKIC 28 11-23-2009 03:26 PM
2000 2.5RS Stock Intake & IM Questions.. spritefiend Normally Aspirated Powertrain 5 01-10-2008 08:56 PM
IM question t4nk Alaskan Impreza Club Forum -- AKIC 25 06-20-2007 06:58 PM
AOL IM Question SteveKerr Off-Topic 27 07-18-2003 12:57 PM
