Old 01-14-2005, 07:26 PM   #1
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
Default MY02 clock going out?
So now its winter in MN and my LED clock goes away for days and doesn't come back on. It seems almost temperature related. When it is around 20 degrees here there is no way to get it, but once the car is really warm, if you tap the center console it comes on, and the time is still accurate. Now that it is the coldest week of the year, -6 degrees without windchill, the clock is back on. Like i said, it works fine in either extremely hot or cold weather, and it usually takes a hit to fix it, i checked the wiring behind it and it all checks out, any comments on this? For about 3 months it was completly out and didn't come on with any temp change or banging, and when it does come on or goes out, it fades, its not a sudden on/off, rather a dimming either on or off that takes a couple seconds.
wrxpeed is offline   Reply With Quote
Old 01-14-2005, 07:31 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The display itself is probably shot, or there is a bad connection on the circuit board. If you are comfortable with electronics you can take it apart and try to mess with it, if not just leave it alone. Check the Private Classifieds, there are sometimes used OEM clocks available pretty cheap.
Old 01-14-2005, 08:04 PM   #3
ducktapeguy
Member#: 24353
2001 Forester
Mine had the same problem. If it's the same as the forester clocks, take it apart and solder the SMT resistor inside. There's been a lot of cases of having a particular resistor breaking at the solder joint.
http://www.subaruforester.com/viewto...forester+clock
ducktapeguy is offline   Reply With Quote
Old 01-14-2005, 09:26 PM   #4
Dewey 8d
Member#: 32397
91 Legacy L SW
Sexy Gray
I also had the same problem. But I've done nothing about it except stare at the blank clock. Why am I posting again?
Justin
Dewey 8d is offline   Reply With Quote
Old 01-15-2005, 06:01 PM   #5
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
thanks guys for all the info, I really hate staring at a blank face there, that and i hate having to look at my watch for the time while driving. I may just get a center gauge pod for there anyways.
WTB: MY02 clock Snowphun NESIC Private Classifieds 6 01-02-2010 03:52 PM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
LCD in MY02, check it out! iBlueVirus Car Audio, Video & Security 25 11-21-2001 12:17 PM
('93-'01) Prices of MY02 to go down? maybe? JaPsiCaN Impreza Forum 8 10-03-2001 11:21 AM
I just got my MY02!!!! They are out!!!! matt7184 General Forum Archive 6 09-12-2000 05:14 PM
