Old 01-15-2005, 02:10 AM   #1
skyline31
Member#: 72588
Default is OEM STI piston rings strong enough??
Just a quick question that is USDM sti OEM piston rings strong enough to take abuse as high as 1.8-2.0 bar?? i am using CP pistons with OEM rings now & about to tune very soon, so i am looking for your answer, thanks!!
skyline31 is offline   Reply With Quote
Old 01-15-2005, 10:01 AM   #2
aaronyoung
Member#: 73087
2002 wrx
Most OEM rings are very strong. They are usually (& should be) forged chrome-moly which is the strongest material used to date for rings, as opposed to cast iron rings.
The lands on the pistons are often the weak point but CP makes a great piston.
I would use the same set up if it were me, you should be totally fine.
aaronyoung is offline   Reply With Quote
Old 01-15-2005, 12:17 PM   #3
Tuning Factory Inc.
Vendor
Member#: 3600
Should be no problem although boost pressure doesn't harm rings or pistons, it is usually detonation you have to worry about. Also you'll need a huge turbo to be efficient at those boost levels. Most of the time people think boost pressure is the limiting factor but in actuality it really is not important. Most of those folks will find that they will yield better results and more power from taking it easy with the boost and keeping the turbo in it's efficient range.
Tuning Factory Inc. is offline   Reply With Quote
FS : FS VA: Lowered Price! OEM STi Pistons CHEAP! Bugeyeballa Engine/Power/Exhaust 53 06-08-2010 09:25 PM
Brand New OEM STi pistons, rings, wristpins 5lipstream Engine/Power/Exhaust 6 11-05-2009 11:06 PM
WTB: used avc-r, new or used perrin fuel rails, oem sti piston ring set blowbyu24 Private 'Wanted' Classifieds 1 01-26-2007 11:25 AM
Anyone know OEM 2.5 sti piston ring thickness? bugeyes Built Motor Discussion 4 06-30-2006 12:14 PM
New STi owner- tranny strong enough for WOT shifting? stevessti Transmission (AT/MT) & Driveline 20 11-29-2004 12:52 AM
