Old 01-15-2005, 11:16 AM   #1
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Default Great AVCS explanation!
I know there have been threads in the past but this is a great resource. I found it in the Drive magazine issued to our dealership and then located it online for you all to check out. I'm sure there are still plenty of people that have no idea how AVCS works.
AVCS explained: http://www.drivesubaru.com/Win05_WhatsInside.htm
crazyhorse is offline   Reply With Quote
Old 01-15-2005, 12:05 PM   #2
SaabTuner
Member#: 67608
That is a pretty good explanation.
For cars with variable intake cams as well the later the intake cam timing the more the overlap, and the more it allows port-flow to continue since intake reversion will occur later in the cycle.
Then there's VTEC, which actually just runs two different sets of cams. Weird stuff.
Adrian~
edit: Waaait a minute. Intake variable timing? I thought it was exhaust?
They also confused advance with retard. While the cam's graph appears to move forward with respect to time, the valve will open and close LATER and thus I would view them as "retarded" and not advanced since they will actuate at a later angle.
SaabTuner is offline   Reply With Quote
Old 01-15-2005, 12:46 PM   #3
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Nice find. I added it to the 2.5 FAQ thread.
Old 01-15-2005, 02:00 PM   #4
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Thanx crazyhorse. . . Found that very useful.
ADR 04STi is offline   Reply With Quote
Old 01-15-2005, 02:04 PM   #5
crazyhorse
Member#: 19502
scoop. =(
Always glad to help.. No one here to buy cars from me so I figured I might as well make myself useful
Old 01-15-2005, 03:58 PM   #6
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Great read.
Don't know if I'm the only one, but I actually had the AVCS cam sprocket fail on my STi. Made a horrible clicking sound under certain conditions.
Here was my log of the event and repair... AVCS Cam Sprocket Failure
T-WRX is offline   Reply With Quote
Old 01-15-2005, 06:43 PM   #7
JIM THEO
Member#: 29715
2004 WRX
WR blue
This is currently only available in JDM models, unfortunately and believe me makes much difference especially in spool ups!
JIM
JIM THEO is offline   Reply With Quote
Old 01-15-2005, 07:08 PM   #8
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
it is advance, and the graphs show it clearly because it's not the exhaust valve that changes.
nhluhr is offline   Reply With Quote
Old 01-15-2005, 08:53 PM   #9
kool168
Member#: 61006
thanks for the info
but i still don't understand why advance more timing will cause denotation and how higher octane gas will solve the problem?
kool168 is offline   Reply With Quote
Old 01-15-2005, 10:00 PM   #10
awilson529
RIP
Member#: 38867
11 Mazda
Incorrect. Read the new Sport Compact Car... It explains it fairly well.
awilson529 is offline   Reply With Quote
Old 01-15-2005, 10:12 PM   #11
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Originally Posted by kool168
thanks for the info
AVCS affects the valve timing, which is completely independent from ignition timing, which is what you're referring to. Ignition timing is a topic for another thread.
Old 01-16-2005, 12:40 AM   #12
grippgoat
Member#: 62182
2005 STI
VTEC doesn't run two sets of actual camshafts, but that's silly. I'm sure it's not literally what he meant.
For a pair of valves, the camshafts have a separate 3rd lobe between the two lobes that are normally there, and when VTEC activates, it does something funky I never quite understood to start making both valves follow the more agressive center lobe.
So while AVCS can change overlap and cam timing, VTEC can actually change lift and duration. Although I think some newer honda engines actually do both. They have variable cam timing like AVCS as well as the 2nd set of cam lobes that can be activated.
-Mike
grippgoat is offline   Reply With Quote
Old 01-16-2005, 06:33 AM   #13
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
-Mike
im stuck at the same place as u about v-tec. i know what it does but im not sure w/ all of the mechanical parts about it. i know that once u reach predetermined RPM a solinoid moves the cam to provide w/ a bigger lift and overlap. but im not sure about duration. i cant see how they can make the valve stay open longer.
snowman4us is offline   Reply With Quote
Old 01-16-2005, 07:18 AM   #14
grippgoat
Member#: 62182
2005 STI
The only thing I'm not really sure about is the exact mechanics of how the VTEC rocker arm gets engaged.
As for how they keep the valve open longer.... It's a completely separate cam lobe. They can grind it any way they want. They just have to grind it with a longer duration.
-Mike
(Former NSX owner... Turbo > VTEC )
Old 01-16-2005, 07:33 AM   #15
pio!pio!
Member#: 4190
2008 Impreza WRX STi
If you retard the cam timing DURING valve actuation..then you could extend the duration
pio!pio! is offline   Reply With Quote
Old 01-16-2005, 08:45 AM   #16
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
JIM
I believe the new USDM Legacy has intake and exhaust.
Abe Froman is offline   Reply With Quote
Old 01-16-2005, 09:49 AM   #17
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Great find - it was always a question if we had AVCS.
By advacing the intake sooner you can help the turbo spool up faster.
chucktoo is offline   Reply With Quote
Old 01-16-2005, 03:44 PM   #18
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
yeah thats true. but in japan the AVC actualy gives it more lift as well, not just overlap
Old 01-16-2005, 05:27 PM   #19
clamdip
Member#: 18709
VTEC- you're dealing with changing the cam profile during low and high rpms. a follower connects three cam lobes together through use of oil pressure. since the high rpm lobe is longer, the cam profile of the other two lobes becomes longer, hence the term LIFT.
AVCS- on the other hand, is just adjusting the cam timing (advancing or retarding) by degrees of up to 35 degrees advance. this allows more air/fuel into the combustion chamber, but uses the ECU to determine the ideal position of the camshaft according to sensors.
AVCS in a way is much like VTEC, however you're just dealing with two different approaches to the system. one is using cam timing to adjust a/f ratios, while the other is mechanical and uses valve lift at higher rpm's for better fuel economy at high rpm's.
hope this helps.
VTEC explanation
and the AVCS one is above.
clamdip is offline   Reply With Quote
Old 01-16-2005, 05:36 PM   #20
awilson529
RIP
Member#: 38867
11 Mazda
-Mike
The oil pressure engages a pin and "locks" the rocker arm together.
Old 01-16-2005, 06:25 PM   #21
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I had this article a long time ago, I think it originated from Subaru of Australia, but then couldn't find it. Good explanation of how the system works.
Old 01-17-2005, 12:15 PM   #22
crazyhorse
Member#: 19502
scoop. =(
Incidently... The current 3.0L H6 has variable lift as well. The camshafts actually shift to a higher lobe, etc.
Old 01-17-2005, 01:56 PM   #23
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
that is correct. but it only does it on the intake. i belive.
now we need that on both the intake and exhaust, for the ej series
Old 01-17-2005, 03:58 PM   #24
clamdip
Member#: 18709
you mean the legacy's have lift too? not the ones here in the states right?
Old 01-17-2005, 04:34 PM   #25
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
I dont know where all the misinformation is comming from but IIRC all the 2.5L blocks (sti, fxt, leg and so on) all come with AVS just on the intake side.
bikerboy is offline   Reply With Quote
AVCS Help deftonez99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-03-2010 03:38 PM
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 05:31 PM
FS:NY Apexi AVC-R, low milage, great condition singincanary Engine/Power/Exhaust 18 02-08-2007 04:25 AM
Apex-i AVC-R & S-AFC Great Condition! TheWRXMan Private 'For Sale' Classifieds 4 02-11-2004 12:55 AM
Great deals on AVC-R DragOnWRX Private 'For Sale' Classifieds 8 07-30-2003 08:19 AM
