Old 01-15-2005, 10:39 AM   #1
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
Default Factory WRX axle back vs. STI axle back
Does anyone know if there is a design diff between them or is the piping on the sti larger?
I'm running a 3"TBE now with a blitz nur spec catback also cobb stg 2
I want to have the stock apearence though, Does anyone know if I put a sti axle back on how much hp I would loose?? or if I would have to much back pressure for the stg 2 map
boost4life is offline   Reply With Quote
Old 01-15-2005, 10:46 AM   #2
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
get one custom fabricated to retain 3". get the largest straight-through muffler that will fit and just paint it it black. finish off with a mild tip. the sti axle-back is 2.5".
kennyvb is offline   Reply With Quote
Old 01-15-2005, 01:35 PM   #3
Phil Jr.
Member#: 62221
they looks IDENTICAL to me...
Phil Jr. is offline   Reply With Quote
Old 01-15-2005, 04:58 PM   #4
hondaeater69
Member#: 60324
Don't expect to lose much, and you can still run stage 2 (some people are running stage 2 with just a short DP and all rest stock). Diameter is the same, not sure about design. May want to consider borla hush twip tip also.
wagon axle length vs. sedan axle length IA Performance Transmission (AT/MT) & Driveline 25 11-19-2011 06:46 PM
FS: 06 wrx stock tbe with STI axle back plus obp sti wing awdm666 Tri-State Area Private Classifieds 15 07-06-2009 03:18 PM
Axle questions, 04 sti axles vs 03 wrx axles, help! D Money Transmission (AT/MT) & Driveline 6 04-09-2007 02:01 PM
Flow comparison Prodrive vs STI axle back boost4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-24-2005 06:48 PM
Borla cat back vs blitz axle back trick18 Car Part Reviews 1 06-20-2003 01:21 AM
