Vancouver Impreza Club
Old 01-15-2005, 11:08 AM   #1
daan
Member#: 79103
2005 2.5RS
Default Impreza (or Subaru) AWD vs. CRV AWD
Hi all,
Just out of curiosity, I had a question which I could find the answer to. What is the difference between the above AWDs. Is it that the CRV is normally two wheel drive and it distributes power to the rear once it slides and the Impreza's all wheel drive is normally on all the time and it distributes more power to the specific wheel. Thanks.
daan is offline   Reply With Quote
Old 01-15-2005, 12:33 PM   #2
jackwei
Member#: 233
Originally Posted by daan
Hi all,
CR-Vs are not AWD unless they changed it recently, CR-V is RT-4WD. There is no locking centre diff to make it AWD. and you are right, CR-Vs are usually in 2WD until there is slippage, then the rear wheel gets power. Not sure about the current generation CR-Vs but the old ones actually takes a bit of time to switch to 4WD.
jackwei is offline   Reply With Quote
Old 01-15-2005, 01:03 PM   #3
ashtaron14
Member#: 4674
2004 Toyota Vitz
Black Black Black!
An automatic impreza is also "RT-AWD" the normal distribution is 90 front and 10 rear, so on a wet day with bad tires (ie: stock), full throttle and you can get the front wheels spinning and then there'd be a second of waiting before the awd "kicks in" to 50:50... the full time AWD is only on the manuals where there's a consistent 50:50 distrubution
I used to own an auto impreza and that's what it felt like... very inconsistent and quite unpredictable, since it works this way you can easily snap-oversteer... pretty scary if you ask me
ashtaron14 is offline   Reply With Quote
Old 01-15-2005, 01:15 PM   #4
feiron
Member#: 62327
2005 WRB STI
[S600BY]
interesting..... I didnt know that auto arent really full-time AWD
feiron is offline   Reply With Quote
Old 01-15-2005, 01:37 PM   #5
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
yeah it's pretty weird...
i was playing donnuts in my car and in my friend's 04 TS wagon...while in my car i can do perfect drifting around the pole (counter steering all the time), in his car sometimes i have to use handbrake to induce oversteering while so other times it just suddently go oversteering...not very predictable and less control...
anonymous_wolf is offline   Reply With Quote
Old 01-15-2005, 01:38 PM   #6
march
Member#: 72169
04 WRX
I thought all Subarus are AWD doesnt matter what their tranny is, but really interesting to find out.
March
march is offline   Reply With Quote
Old 01-15-2005, 01:52 PM   #7
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Yeah this is a fun discussion.. Now can we get someone with authority on the subject to make an appearance?
I've heard things that vary between the model 50:50, 40F:60R (WRX?), 60F:40R (RS/TS?), 90F:10R .. and newer STi are totally variable between 40:60 and 60:40 ? It's hard to keep track of it all.
420WRX is offline   Reply With Quote
Old 01-15-2005, 01:55 PM   #8
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
general speaking
all manual WRX/RS/TS = 50:50 all the time
all auto WRX/RS/TS = 90:10 all the time
STI w/ VCD = i'm not sure...somebody help me out~
Old 01-15-2005, 01:59 PM   #9
skier
Member#: 47716
2004 Impreza 2.5TS
Not exactly. 1st gear - locked 50:50, second gear - locked 50:50 as well, third and fourth is 90:10 by default, switches to 50:50 when accelerating and everytime when the wheel spin detected.
So it's not that bad after all. You _can_ do donuts in an auto TS
skier is offline   Reply With Quote
Old 01-15-2005, 02:28 PM   #10
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
really?!
i didn't know that...
so i guess it is the rear LSD that makes my car easier to do donuts~
Old 01-15-2005, 02:47 PM   #11
-S-
Member#: 6979
I'm not sure why you said CRV's are not AWD. AWD doesn't necessarily mean full time AWD. If something can send power to all of its 4 (or 6, or 8...) wheels, it's AWD.
Along your line of argument, does this mean an older 4Runner/Grand Cherokee and the like are not AWD because it requires a manual lever (or button) to select the all wheel drive mode?
-S- is offline   Reply With Quote
Old 01-15-2005, 03:09 PM   #12
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Exactly, those vehicles are considered 4WD, not AWD. Generally the distinction between 4WD and AWD has been 4WD requires user action to engage it (often a hi-lo transfer case), and there is usually no center diff. AWD means all the wheels are driven all the time and because of this AWD cars do require a center diff (otherwise you couldn't turn tight corners). I'd argue that real time switching systems like CR-V's and Subaru's 4EAT are much more like AWD since the switching basically acts like an electronic center differential.
Locking center diff has nothing to do with AWD/4WD. As I mentioned, most 4WD vehicles have no center diff, but all AWD vehicles do have one. Some AWD vehicles have locking center diffs to help in situations with extremely low traction. An AWD vehicle with open diffs would get stuck if only one wheel had zero traction but with a locked center diff, you need one front and one rear wheel to have zero traction. Add a rear diff lock and now you need both rears and one front to have no traction to get stuck.
AllWheelDrift is offline   Reply With Quote
Old 01-15-2005, 03:10 PM   #13
imprezaboi
Member#: 7382
MY01 GC8 - 4
BRP
DCCD can change the ratio of % power to the front or rear wheels. Extreme's are 90:10, 10:90; 50:50 for normal I guess. Yeppers only in 1st and 2nd gear in a auto ts or rs can 50:50 be active at all times, its pretty much the best way to make nice tight donuts or figure eights in the snow. No clue as to whether the wrx's are the same. Anyone want to clue in on this? Is the wrx auto tranny in respects to % distribution the same that of the rs or ts?
imprezaboi is offline   Reply With Quote
Old 01-15-2005, 03:41 PM   #14
OnlyKor..
Member#: 34335
03 Impreza WRX
errr... not exactly... for WRX's it's 45/55 split
OnlyKor.. is offline   Reply With Quote
Old 01-15-2005, 03:44 PM   #15
420WRX
Member#: 27752
For 45/55 with automatic and 40/60 for STD? .. I was told I have a 40/60..
Old 01-15-2005, 04:00 PM   #16
chopchop
Member#: 55630
04 STi Stage 2
so auto subarus have a 90:10 distribution until the car senses a lost of traction?? that applies to all 4 gears on an auto wrx?
i drive an auto myself and now that i know about the distribution differences, at times i did feel that the car's AWD kicks in when i am starting to lose traction on my rear wheels, but i just thought how RT-AWD would work anyways?
chopchop is offline   Reply With Quote
Old 01-15-2005, 04:24 PM   #17
jackwei
Member#: 233
that's not correct. RT-4WD has 0 percent to the rear when there is no slippage. AWD means that there is a locking centre differential, the CR-V does not have one and the AT subarus do.
your fronts were spinning because the diff has not locked yet. on a CR-V the centre diff WILL NOT LOCK. so if one wheel slips on the CR-V, only that wheel will spin since all the differentials are open. If you AT Subaru has a rear LSD, at least 3 wheels will spin no matter what once the diffs are locked.... 2 if it doesn't have a rear LSD.
Old 01-15-2005, 04:29 PM   #18
jackwei
Member#: 233
WRONG. Look up the definition, I have a book here that says otherwise, you can come read it if you like. AWD is 4WD with a locking centre differential.
Old 01-15-2005, 07:36 PM   #19
ronf
Member#: 51034
03 WRX, 02Forester
no no ! 4eat is 45/55 front/rear !! better than manual 50/50 !!
ronf is offline   Reply With Quote
Old 01-15-2005, 07:46 PM   #20
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
What's the title and whose the author of the book?
By AWD
[emphasis by me]
AWD's general statement above is regarding PART TIME 4WD vehicles (such as older 4WD SUV's, pickups, and other vehicles. The "part time" is due to the fact that to get "all 4 wheels" going, you need to use the transfer case to connect power to the front wheels. Usually these transfer cases mearly lock the front-and-rear drivetrains together and do not have a centre differential.
By AWD
...Some AWD vehicles have locking center diffs to help in situations with extremely low traction...
Again, another general (yet correct) statement by AWD.
Taken from www.rallycars.com
A full time 4WD performance car, as mentioned earlier, needs 3 differentials in order to operate properly.
In general, "full time 4WD" is better known as "all wheel drive". Without the centre differential, the vehicle would handle terribly due to the fact that the front AND rear wheels would in essence have to turn at the same speed. Not a problem with these (part-time) 4WD vehicles since usually it's in 4WD mode in snow, on dirt, in the mud, etc. Rarely would they been in 4WD mode on pavement.
The purpose of the "locking" centre differential is to have the best of both worlds. 1) The ability to have the front-and-rear wheels spin at different speeds for handling. (Have you driven a 2WD car with no differential? Why don't they make a 2WD car with no differential? It'd handle better in a straight line, but turning (slow turning especially) would be a real PITA). 2) The ability to lock and transfer power to both ends for better traction.
I hope you've enjoyed this lesson and discussion on AWD/4WD and the many variations of it. Tune in tomorrow, where we'll learn why we need to put oil in the frying pan AND in the engine, and why they're different.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 01-15-2005, 07:59 PM   #21
Penphoe
Member#: 269
I'm not sure about the R(eal)T(ime) AWD system on the CRV. My wife has one, but I haven't played with it in the snow just yet. I do believe it's mainly FWD until slippage, then the drivetrain clunks into place to get power to the rear wheels. And if the centre diff doesn't transfer any power to the rear, then why get an RT CRV at all? Might as well stick with FWD which Honda does pretty well with.
I'd have to disagree with you with respect to the Subaru AT "centre diff". Not all AT's have them.
I've got my MY05 Subaru Legacy catalogue in front of me right now. In the specs section at the back it says:
4-speed AT better known as the 4EAT
Electronically controlled multi-plate transfer case
No mention of a centre diff here.
But with the new 5EAT:
5-speed AT (a.k.a. 5EAT)
VTD with lateral g-sensor AND an electronically controlled locking centre diff.
How does the 4EAT get away with not having a centre diff? Well, the electronically controlled transfer case basically acts as a "torque converter" [for the lack of a better word] that allows the two ends of the drivetrain spin at different speeds, much like a differential, but without all the gearing inside.
LaterZ!
Darren!!
Old 01-15-2005, 08:16 PM   #22
holam
Member#: 8878
98 wagon white
99 2.5RS white
Well I heard that All-Wheel Drive is a term registered by Subaru, but they just never mind other brands using that name, correct me if I'm wrong.
Then for Subaru, the term All-Wheel Drive is not only a matter of the diffs., but it also includes the boxer engine (which lowers the centre of gravity), the different varieties of transmission (in AT the centre diff is included in the transmission), and the symmetrical layout. Now it might even includes VDC, or other means traction control.
At least that's what I found from their brochures ^_^. So if u ask what's the differeces between the CR-V and Subaru's AWD, u might as well think about the engine.
That's just what I found, correct me if I'm wrong.
holam is offline   Reply With Quote
Old 01-15-2005, 08:29 PM   #23
Penphoe
Member#: 269
I think that's Subaru's catch phrase for 'Symmetrical AWD' for including the boxer engine AND the AWD layout. AWD has nothing to do with the engine. Heck, the Carrera4 (or whatever the AWD 911 model is called) has the boxer engine BEHIND the rear wheels!
LaterZ!
Darren!!
Old 01-15-2005, 11:41 PM   #24
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Well then by your defintion, 90% of vehicles sold as AWD aren't AWD.
Maybe I should sue Subaru because they claim my TS is AWD (5mt) but it doesn't have a locking center diff.
Old 01-15-2005, 11:57 PM   #25
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
BTW, if anyone wants to know more about AWD and 4WD, including differentials etc, they can read these links:
http://auto.howstuffworks.com/four-wheel-drive.htm
http://mozart.chat.net/~jeske/unsoli...egacy/awd.html
WTB 5 speed 95-97 1.8 impreza AWD tranny or 97-99 legacy outback AWD tranny mellow65 NWIC Private Classifieds 5 08-23-2008 04:43 AM
subaru AWD VS industry awd dankEe General Community 27 11-17-2007 12:26 AM
EVO awd. VS. STi awd. innova Off-Topic 80 12-20-2005 12:07 PM
Details on 2005 CRV AWD system? TimStevens Off-Topic 18 01-31-2005 11:01 AM
Subaru AWD vs Volvo AWD (video, repost) remarcable Legacy Forum 16 09-18-2001 11:48 PM
