Old 01-15-2005, 01:26 PM   #1
phunkeeHomosapien
Member#: 56061
Default newer model dash into gc
I have seen this done several places and am just wondering how dificult it is to put a 2002+ impreza dash into a gc, is thier much cutting involved and is it worth it? thanks
mike
also i have seen door cards from newer models used as well.
phunkeeHomosapien is online now   Reply With Quote
Old 01-15-2005, 01:51 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yes, there is much cutting and fitting and molding etc...you should do some searchs and see what you find...I know that aerosim just finished one...
Old 01-15-2005, 03:43 PM   #3
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Have you actually done this or are you just guessing?
thesmokingman is offline   Reply With Quote
Old 01-15-2005, 03:51 PM   #4
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
meh...mike you know that kid who put EVERYTHING from a sti into his rs... if he can do it im pretty sure you could.
Rick
scoobydorift is offline   Reply With Quote
Old 01-15-2005, 03:52 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
I saying from what I have read from those who have done it...you need the wrx climate stuff...heater core, etc...
Old 01-15-2005, 03:55 PM   #6
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Its a drop-in cept you have to do a lil' fitment for the hvac. The rs dash beam is too narrow for the wrx hvac. And um, duh of course you need the wrx hvac equipment that goes without saying. The main point is, the wrx dash BOLTS ON to the rs beam.
Also, it actually makes it an easier swap using the wrx dash. You then don't have to do as much re-wiring.
Old 01-15-2005, 04:35 PM   #7
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
actually it would be worse for him casue he is swaping in a 94 wrx engine...lol
rick
Old 01-16-2005, 08:54 AM   #8
dmross
Member#: 2818
2000 2.5RS
Now what about an 05' dash?
dmross is offline   Reply With Quote
Old 01-19-2005, 03:25 PM   #9
Skell
Member#: 75638
new metalocalypse
is effin funneh
so whats the verdict on this if you just want to change the dash and the center console area? i might just buy new gc8 parts ..since these are scratched..
Skell is offline   Reply With Quote
Old 01-20-2005, 12:48 AM   #10
OvenMitts
Member#: 46278
96 Impreza
"brighton"
I'm not sure about the RS'es, but when I swapped a WRX dash into my L, quite a bit of trimming was involved. I used the WRX beam, which had to be cut and welded to fit right, the HVAC stuff was a pretty close fit, and the dash itself is fastened a lot differently. The two different firewalls are not even close for a bolt-in fit, unless my car was an exception. My dash is different from an RS'es, after all...
It's not impossible, just a whole lot of work, trial, and error.
But, once you get the fastening points set right, everything bolts in pretty close. The only plastic piece I had to cut was a little trimming on the console to get it to fit.
I don't know any right or wrong way to do it, but maybe there is a better way.
OvenMitts is offline   Reply With Quote
Old 01-20-2005, 09:20 AM   #11
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Why would you want to do this, the new dash looks so lame. Not to mention the fitment won't be that great no matter how much work you do.
Z
Zephyr is offline   Reply With Quote
Old 01-20-2005, 09:43 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
Z
I'm with zephyr here...just keep what you have...especially if the drivetrain will have DCCD, the old school dashes have places in the gauge cluster to disply the power split
Old 01-20-2005, 01:20 PM   #13
senomar
Member#: 47636
01 rsti v7
blue
senomar is offline   Reply With Quote
05 STi+ Dash into GC Jubert69 Interior & Exterior Modification 4 12-06-2008 03:10 PM
USDM wrx dash into GC body? zerogt86 Subaru Conversions 15 12-17-2007 09:38 PM
GD dash into GC chassis darksc00by Subaru Conversions 37 05-20-2007 11:52 AM
Question for you GD dash into GC swappers Lachlan Interior & Exterior Modification 1 01-08-2006 11:24 PM
02' WRX engine stronger than newer models? WReXinEfX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-28-2004 07:41 PM
