Old 01-15-2005, 01:35 PM   #1
feiron
Member#: 62327
2005 WRB STI
[S600BY]
Default question on TurboXS stage3
Stage 3 is basically stage 2 with more agressive tuning assuming that a larger IC is installed right? which means it needs better cooling capacity to be safe...
my question is.. can I run stage 3 with the stock IC in the winter?
it gets below 0 degrees (in celcius) at night and at noon it rises to 6 degrees at most...
*flame suit on*
feiron is offline   Reply With Quote
Old 01-15-2005, 03:20 PM   #2
jalow72
Member#: 64293
I am surrounded
by land manatees!
*flame suit on*
Fuel map is different between the Stage 3 and the Stage 2. I would not run the stage 3 map (presuming that winter air is keep that intercooler cold) unless I at least had the uppipe.
jalow72 is offline   Reply With Quote
Old 01-15-2005, 03:39 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
The stage 2 map runs leaner then the stage 3 map in many areas(if not all, I forget). If you run the stage 3 map without an intercooler, your car will most likely run much richer then with a stage 2 map. Ie- If your engine runs an a/f ratio of 10.5 to 1 with the stage 2 map, using the stage 3 map would probably drop that to 10 to 1 or richer in many situations. This could make your car slower. I'd suggest stayin away from the stage 3 map if I didn't have a large top mount intercooler, and the rest of the mods that the stage 3 map is ment to be used with. As always, this is just my opinion.......
peace
Old 01-15-2005, 04:41 PM   #4
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I am catless all the way... the fuel map in stage 3 is designed to dump more fuel, correct?
Old 01-15-2005, 04:44 PM   #5
feiron
Member#: 62327
2005 WRB STI
[S600BY]
peace
I agree.... stage 3 will make me run richer, but then... on cold days... the engine will receive more air particles due to the colder temperature, yes?
my noobie logic tells me that means there should be enough air to be burnt along with the fuel...
keep the opinions coming that's the point of posting here
Old 01-15-2005, 04:59 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
I....but then... on cold days... the engine will receive more air particles due to the colder temperature, yes?
Your newbie logic has some holes in it. The utec see's the amount of air going into the engine. If more air goes in on a colder day, the utec will put out more fuel. So, having a richer map will make you run richer on cold and warm days then a leaner map would. It's not like the stage 3 map is the winter map for a stage 2 car. It's a stage 3 map.
peace
Old 01-15-2005, 04:59 PM   #7
jalow72
Member#: 64293
I am surrounded
by land manatees!
For a second there I fell into the "cold air" logic trap too. But now that I really think about it, a larger intercooler also has a significantly increased airflow into the throttle body. I do not think cold air would compensate enough for the cfm and believe that you would not see any greater performance difference than you do with stage 2.
Old 01-16-2005, 01:29 PM   #8
feiron
Member#: 62327
2005 WRB STI
[S600BY]
good point... I didnt even think about the air flow
thanks guys
quick question on turboxs fmic! chrisc75 Water/Methanol Injection, Nitrous & Intercooler Cooling 8 05-01-2009 12:45 AM
Noob Question on TurboXS Base Maps i4dat Engine Management & Tuning 3 02-02-2006 02:24 PM
Question about different on utec stage3 and stage2 maps R.C.Y.K. Engine Management & Tuning 15 10-27-2004 01:25 AM
Anyone in So Cal running TurboXS Stage3 or 4 Newbie Subie Southern California Impreza Club Forum -- SCIC 2 11-02-2002 06:09 PM
Question on TurboXS Unichip? tibikefor2 Newbies & FAQs 3 01-26-2002 09:55 PM
