Old 01-16-2005, 01:03 AM   #1
aakrusen
Member#: 77308
'02 WRX
Default Stock gauge cluster
Will an 04 WRX gauge cluster work with an 02-03 WRX without any modifications? Also, how would you change the digital odometer if you could trade one in? The reason why I ask is because I like the tack in the center versus the side.
aakrusen is offline   Reply With Quote
Old 01-16-2005, 01:38 AM   #2
brunetmj
Member#: 8023
2004 2.5 RS
I really can't answer that question without comparing wiring diagrams. However have you considered an after market tach? Get one with a shift light maybe? Sure would be a lot less expensive.
brunetmj is offline   Reply With Quote
Old 01-16-2005, 11:49 AM   #3
aakrusen
Member#: 77308
'02 WRX
I'm not really interested in the a.m. tachs because I like to do the "less is more" approach. I' don't want a bunch of stuff on my dash and a-pillar. I have seen a WRX with STi cluster but I didn't ask any questions about it.
Old 01-16-2005, 01:47 PM   #4
veightkiller
Member#: 78967
2011 335i
why dnt you get the STI version gauge cluster for 02-03 ..that one will fit...im not too sure about 04...maybe it's the same socket but diff.wiring diagram.....so good luck ..
veightkiller is offline   Reply With Quote
Old 01-18-2005, 03:29 PM   #5
InfamousDX
Member#: 25413
04's will bolt in no swaet... I've done it. www.tacomaspeedometer.com is a compnay I know of that will reprogram your speedo WITH an official certificate.
Fs 05 Stock Head Unit & Stock Gauge Cluster plamwrx MAIC Private Classifieds 6 02-09-2009 11:37 AM
stock gauge cluster for 04 wrx OvrClkdPmp Private 'Wanted' Classifieds 1 12-27-2004 10:21 PM
Wiring harness for the Stock Gauge cluster. Valhakar Electrical & Lighting 2 11-11-2003 08:41 PM
Can I switch my mph/tach in my stock gauge cluster? wighti Interior & Exterior Modification 26 06-23-2003 06:32 PM
Stock gauge cluster question EvasionOfTruth Interior & Exterior Modification 2 05-09-2002 08:03 PM
