#1 |
Member#: 49274
Vehicle:2004 STI SILVER |
does someone know why my brand new egt gauge from autometer wouldn't reset to 0 and instead starting off the 800 deg. F? any way to fix that?
#2 |
Member#: 46099
Vehicle:2004 WRB WRX Wagon cobb stg 2.5 |
are you saying that if the car is off it is at 800 F? If you disconnect the probe does it still reads 800F?
#3 |
Member#: 49274
don't know didn't try that yet. had a shop install it for me. so because it starts at 800 instead at 0 the pointer goes to the max beyond 1600 deg. F after a little driving, which in normal circumstances would be too hot. another thing manual sais the gauge is going through a self test process apon startup which lets the pointer go to the max and then come back to 0. mine only moves from 800 to like 1200 deg F and back to 800.
#4 |
Member#: 46099
If you can figure out how they wired it, check all the electrical connections. Might not be properly grounded. I also had a problem grounding a gauge using the instructions provided. I had to tap into another ground wire, rather than use a bolt in order to get it to work. If a shop did it bring it back to them.
#5 |
Member#: 49274
I'll probably bring it back to them to see what's up.
#6 |
Member#: 62722
NESIC
Vehicle:2004 WRX Wagon WRB |
what kinda power supply is it hooked to? I had a similar problem when i didnt have it hooked up to a constant power.
| Thread Tools | |
| Display Modes | |
| EGT Gauge problem | WS6toWRX | Engine Management & Tuning | 11 | 09-21-2010 04:51 AM |
| Omori EGT gauge problem (long) | BluSuby | Electrical & Lighting | 10 | 07-15-2005 02:13 PM |
| EGT gauge problems | Bean75 | Electrical & Lighting | 6 | 02-14-2004 03:24 PM |
| Omori EGT gauge problem... | mturmel | Electrical & Lighting | 9 | 05-10-2003 11:58 PM |
| Greddy EGT Gauge Problem | mikev123 | Factory 2.0L Turbo Powertrain | 4 | 09-13-2002 08:41 PM |
