Old 01-16-2005, 12:17 PM   #1
elohdaeh78
Member#: 61395
2005 WRX
CGM
Default oil leaking issue
I have an 05 wrx. I have 9k miles on it and i have changed the oil 3 times. Everytime i go to change it i notice that oil is leaking out of the oil pan plug. When i first changed the oil i didn't notice a crush washer on the oil plug, what i thought may have been the washer sat deep in a groove on the face of the plug but it was soo smashed in there that i coudln't even fit a razor blade inbetween it, i showed it to my brother who has a 02 wrx and he said thats not how his looks. My question is does the washer fit in a groove in the plug or does it just sit flush on the lip. I have been putting crush washers from subaru on it each time i change the oil and each time it still leaks, i am wondering if it already has a washer on it and its just soo crushed inside the plug that i can't get it out.
elohdaeh78 is offline   Reply With Quote
Old 01-16-2005, 12:58 PM   #2
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
I just looked at the drain plug that I removed from my 05 when I installed the factory gauge pack. The flange on the plug should have a flat surface that the crush washer sits against. There is no groove. The crush washer is very noticeable.
Now, I just noticed that my 05 seems to weep a little from the oil drain plug (which is now actually the drain plug/sending unit). I used a new crush washer and tightened the plug to 30 ft-lbs. I tightened the plug a little more today to see if that takes care of the problem. At my next oil change, I plan to inspect the pan a little more closely to see if there is something on the pan side causing the problem.
I hope this helps a little.
-Jeff
jac04 is offline   Reply With Quote
Old 01-16-2005, 05:36 PM   #3
elohdaeh78
Member#: 61395
2005 WRX
CGM
-Jeff
Thanks for the response so that means my car didn't have a crush washer on it from the factory, i tightened the **** out of the drain plug this time, if it still leaks i have some sort of issue and subaru will be fixing it. Thanks again.
Two leaking rear main seals in a year?? Leaking Head Gasket...Oil Pressure Issues??? jsavage Factory 2.0L Turbo Powertrain 4 05-21-2010 11:06 AM
Oil leak issue, help me stop freaking out. 08 WRX TheBrandon Factory 2.5L Turbo Powertrain 28 04-01-2010 01:58 PM
oil leak issue alwu Factory 2.0L Turbo Powertrain 3 11-05-2009 07:43 PM
New oil leak issue sidewayz Factory 2.0L Turbo Powertrain 2 03-15-2008 01:14 AM
Oil Leak issue help simonbsays Newbies & FAQs 6 10-06-2007 05:16 AM
Message Board Statistics All times are GMT -4. The time now is 11:23 AM.
