Old 01-16-2005, 01:08 PM   #1
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
Default wheel bearing grease
I'm installing a perrin RSB and I heard its reccomended to grease the rubber mounts, so i went to autozone and i bought wheel bearing grease is this okay to use ont he rubber bushings?
DJ_STI is offline   Reply With Quote
Old 01-16-2005, 01:16 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Did you buy the bar new or used? Don't they come with a small pack of grease? I've used white lithium grease on rear sway bars in the past with no problems. I imagine any grease that doesn't degrade the rubber should be fine in that particular application. Please correct me if I'm wrong.
supermarkus is offline   Reply With Quote
Old 01-16-2005, 01:28 PM   #3
DJ_STI
Member#: 56826
2006 Subaru Evo IX
hmm, it came in a little packet for 99cents. I bought the bar used so the guy removed the grease before giving me the RSB. Thats what I'm worried about is that this grease may degrade the rubber, how can i tell if it will or won't.
Also is it safe to remove the sway bar and endlinks while the car is on rhino ramps, im almost 100% sure it is because they don't have anything to do with holding the wheels up but just making sure.
Old 01-16-2005, 04:19 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Ramps are the preferred way to do swaybars.
Old 01-16-2005, 07:18 PM   #5
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
yep, grease is good, ramps are good.
00Maddog is offline   Reply With Quote
Old 01-17-2005, 03:54 AM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
It's definitely easier for me to do the sway bars with the car loaded, the suspension sag makes it difficult to reconnect the endlinks when the wheels are off the ground. If you're skinny, it's not difficult to just crawl under the car to do the mod. I've done it several times and I never use ramps when I just need to tighten the hardware.
Old 01-17-2005, 03:58 AM   #7
merv
Member#: 79554
2004 WRX wagon
I wouldn't worry about grease degrading the rubber, most ball joints and u-joints (cup seals) are made dust/water tight using rubbers seals and grease has no effect on them.
$0.02...
merv is offline   Reply With Quote
Old 01-17-2005, 08:53 AM   #8
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Okay thanks for the help everyone!
Just a quick question that is not even worth creating another thread. Which hole is the stiffest setting?
http://www.perrinperformance.com/Ass...Bar_Rear02.jpg
The one closer to the front of the car or the one towards the back of the car? Which hole will i bolt the endlink to for the stiffest setting? thanks again
Old 01-17-2005, 10:10 AM   #9
cboggess
Member#: 30804
87 Yugo
Red
The one to the front of the arm (which makes the lever arm the longest) is the soft setting. The one to the back of the car (which makes the arm the shortest) is the hard setting.
cboggess is offline   Reply With Quote
wheel bearing grease ? jsin93816 Brakes, Steering & Suspension 20 02-15-2010 12:25 PM
FS: Wheel Bearings w/seals. Prepacked with Neo HP800 Bearing Grease Gro Harlem Suspension/Brakes/Handling 9 03-04-2009 10:35 AM
Wheel Bearing Grease dunk Motorsports 23 04-27-2008 12:05 AM
which wheel bearing grease ? JasonE Brakes, Steering & Suspension 3 06-08-2003 11:15 AM
Wheel Bearing Grease BG5 Service & Maintenance 4 12-07-2001 03:25 AM
