#1 |
Member#: 3649
Vehicle:2001 Impreza 2.5 RS Blue Ridge Pearl-Red acc |
I was wondering if I might get some suggestions here.
I've got a craveing for more power, I've done some significant NA upgrades and I was trying to think of what adjustments or other small mods could be done to better compliment whats on there now. I know I need to get new plugs. I've been playing with the idea of raiseing the fuel pressure or possibly advanceing the timing. Someone metioned this would help, how and why, pros cons? I think I'm getting defi gauges soon, so that should help with tuneing the fuel pressure for EGTs. What ells can be done beyond this though. I'm not looking to get new cams or heads just yet. Just small things to help the car run just a little bit better. Any suggestions are welcome. Maybe a S-AFC? Anyone have any long term JCS torque chip reviews? Thanks, Ryan D. Mods Short Throw shifter With STI Bushings Magnecor Comp. Wires Ganz-Flow Cold Air Intake K&N Filter Charger Borla Headers Borla Mid-Pipe and Borla Exhaust Stock Cats CarbonFiber shift handle CarbonFiber Sport Peddles P.S. O and with my mods so far is any tuning or other changes required rather than just wanted.
#2 |
Member#: 2112
I wanna try my intake on your car, Ryan. I'll be going to Bandi tomorrow. Let me know what's up. G
#3 |
Techno Sapien
Moderator Member#: 449
Vehicle:2010 Legacy 3.6R Lim Azurite Blue Pearl |
Just an FYI the STi bushings for the shifter are exactly the same as the OEM ones:
http://www.scoobymods.com/mods/impreza/kartboy-sti.php Peaty |
#4 |
Member#: 3649
Well peaty, just a F.Y.I. I've held both in my hand. The STI bushing is alot stiffer than the stock bushings. I'm not calling Kartboy a lier, I'm sure he just wants to sell his bushings. His look very nice and rock hard.
Peaty have you ever had both in your hands at the same time and try to flex them. You know the center hole, on the stock one if you were to swash it down as hard as you could, you could get the hole to close. On the STI bushing you can not do that. The outside if soft but the inside is much much stiffer than stock. Check out another post I've been in. Ryan D. TREAD |
#5 |
Member#: 3649
P.M.ed ya burninrubber.
Can we get back on the subject. I'm still looking for suggestion. Ryan D. (edited) just cuz i was bored. |
#6 |
Techno Sapien
Actually I took those pics and did have both in my hand. The stock RS bushings and the STi ones were both about a year old. Maybe they fatague with time. Yes the STi ones are harder but my my estimation only a small amount. Also, the STi and RS bushings have air gaps in them that will also make them feel softer shifting. I've installed and felt both the Cusco and KB bushings and there is no comparison in hardness. The KB and Cusco may as well be bricks compared to the RS and STi bushings. My wife is a packaging engineer and possibly I could have the Duromoter checked between the STi, RS, Cusco and KB. On a scale of 1-10 the hardness of the RS being 1 the STi may be a 2 but the KB a 9 and Cusco a 10. I've also driven the STi, RS, Cusco and KB bushings installed. Also stock sti and KB shifters For all intents and purposes the STi felt similar to the RS and The KB and Cusco both feel more solid. The drawback to the KB and Cusco is that there is more NVH that comes from the driveline and some don't like the notchyness that comes with them.
Myself I didn't get any abnormal vibrations on any of the installs I felt. Only a few times I've come across that when the installer put in a new shifter lever and overtightened the pass through bolt at the pivot point. Too tight and the shifter fork arm will contact the lever rather than the bushing in the shifter and transmit all the vibration rather than let the small bushing absorbb most of it. It only needs to be snug like 8-10 ft/lbs. |
#7 | |
Member#: 3649
You may very well be right. I wish you would have said all that before.
1-soft 10-hard as H#LL Stock-1 STI-4.5 Cusco-9.5 KB-10 I just didn't like all the NVH. It was mainly on the HW. The STI fit my needs and wants. Now that we have all that out of the way anyone have any suggestions to help tune my car correctly for the mods I have listed? Ryan D. |
#8 |
Techno Sapien
OK they *feel* exactly the same to me.
Anyway I know you want to change your plugs. You should really do that asap. I know in the 99 and 2000, not sure about others, have Champion as stock plugs. Myself I really don't like the idea of those in my car. I went with the STD NGK copper plugs rather than the plats. From what I heard the copper gives better performance and the plats have better long term duriability. I just change my plugs every year is all. In the end it's actually cheaper to go with the copper ones. I put the Bosch +4's in my wife's 2.5 Legacy and didn't notice much of a differnce like they claim. Also, if you haven't done it yet put in some vent spacers to let out the heat. http://www.scoobymods.com/mods/impreza/ventspacers.php and open up the hood scoop plate to let in the cool air. http://www.scoobymods.com/mods/impreza/hoodscoop.php It gets hot under there. http://www.scoobymods.com/mods/impreza/thermal.php Opening up the bumper vent will get more air to the intake too: http://www.scoobymods.com/mods/impreza/bumpervents.php |
#9 |
Member#: 8124
Vehicle:1998 Old Grey Mule Regacy Rype R |
Do you know approx. how many HP you are running with the mods you currently have installed?
-Steve |
#10 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2006 B9 Tribeca LTD 2005 Impreza 2.5 RS |
You have a good list of mods there.
My recs are to get a Torque Chip II and a lightweight pulley or under drive pulley next, then a COBB cam later. However, STI motor mounts and Tranny mounts will help put power to the ground too. If you don't wanna do a set of cams, at least consider a 12 lb flywheel. Shameless plug, I can sell you all or any of those items above, if you decide to stay NA vs turbo ![]() Larry www.ImprezaRS.com |
#11 |
Member#: 3649
Well my long term goal is a turbo, long term being about 2-3 years down the road. To keep me happy untill then I'm first doing a nice NA/NOS build. I've done most of the small bolt on stuff ie; exhaust, intake, wires. Right now I'm working on getting some gauges and tuneing tools. After the gauges, EGT, OIL-T, bottle PSI, I'll have my hands on either a NOS 50-75s or a venom kit of the same power. After the NOS I plan on upgrading the internals of the engine ie; cams, heads, rods, pistons, trans, mounts etc etc...after that maybe a larger shot. Then comes the O mighty turbo and boost gauge.
Peaty: Thanks for the suggestions. Plugs...This weekend vent spacers...Putting them in tonight. Hood Scoop...Spacers also, tonight. I looked a the graph of temps, looks like fender intake is the coolest,,,Ganz flow. As for the bumper vent. I've been thinking about it. I'm not sure if I want to remove the vents and just leave the ring or do some wire mesh. I know just taking out the vents and leaveing the ring would be better and I don't really like the whole wire mesh thing. So I think I'll just break down and saw out the vents and paint it black, my only real concern is water or just stuff getting in the intake. I've also been thinking about covering my Ganzflow with some type of insulator to keep the heat off it but the only ones I've seen fall off within a week. Great suggestions peaty thanx. Ryan D. Last edited by Scoober01; 07-11-2001 at 10:13 AM. |
#12 |
Member#: 3231
RMIC
Vehicle:88 626 Turbo white |
booga boooga!
#13 |
Techno Sapien
Larry has a good idea about the underdrive pulley too, I forgot about that one I've had it so long. My concern when I put it in was that my AC would suffer as it gets really hot here in KS. I worried for nothing because it works fine even in 110°F weather. I think if you eventually get a turbo you'll have to go back to the stock pulley though. Still they are easy to sell.
#14 |
over boosted again
RMIC
RE: the under drive pulley. I also carry lightweight normal sized pulleys. These use the stock belts and the AC runs fine.
Per Grassroots Motorsports Magazine, for every 1 lb lost in pulley weight = 2.7 hp at the crank. These pulleys are 4lbs lighter! I expect to have more next week. Larry |
#15 |
Member#: 961
Vehicle:1999 RS-Tw/ CobraMAF Custom Rallispec kit/IC#1 |
Scoober01,
rid yourself of those stock cats. Its the most restrictive part of your exhuast and limits the other mods. IMHO: Save the pulley money for a bigger 2.25"-2.5" cat. (it offers better bang for the buck) |
#16 |
over boosted again
RMIC
Yeah - cats. Search the links for Random Technology and buy a couple of high flow cats from them ($59.95 each), and then bash up your old ones so a muffler shop will install the new ones legally
![]() Larry |
| Thread Tools | |
| Display Modes | |
| Where to get what is needed to put foglights in 04-05 RS??? | Bamboorex | Electrical & Lighting | 8 | 11-01-2009 07:16 AM |
| Newb to E-85, what is needed to run ethanol? | DFv2 | Factory 2.5L Turbo Powertrain | 6 | 05-14-2009 05:54 PM |
| What is needed to go from 235whp to 285whp | Twenty36_1 | Proven Power Bragging | 26 | 03-17-2006 12:24 PM |
| what is needed to take on the.... | 949 | Factory 2.5L Turbo Powertrain | 18 | 09-14-2005 11:57 PM |
| What is needed to build rally car? | SAM_463 | Motorsports | 14 | 03-27-2001 01:37 PM |
