Vancouver Impreza Club
Old 01-16-2005, 03:16 PM   #1
ADE
Member#: 61145
1998 WRX GC8 EJ-20
Default what to do with my 2.5rs engine&trans?
just done the wrx engine&trans swap. what can i do with my old 2.5rs engine&trans?
98 2.5rs engine with engine harness and head gasket problem which is not worth $$$.
98 2.5rs transmission with clutch and flywheel.
they are roughly around 80000km on them.
ADE is offline   Reply With Quote
Old 01-16-2005, 03:28 PM   #2
RayQuon
Member#: 43259
1999 2.0RS
RBP
Do you mind telling me where you got the swap done, and total cost?
RayQuon is offline   Reply With Quote
Old 01-16-2005, 03:34 PM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
ADE, the engine won't be worth much but you should try contacting TechWorksEngineering in Calgary, they sometimes will buy what you have for a good price. Did you replace the rear diff as well?
tora is offline   Reply With Quote
Old 01-16-2005, 03:39 PM   #4
ADE
Member#: 61145
1998 WRX GC8 EJ-20
do you have their # or web?
no, i didnt put the wrx rear-diff, i am still using 2.5rs rear-diff.
Old 01-16-2005, 03:48 PM   #5
tony_subaru
Member#: 22742
PM'd
tony_subaru is offline   Reply With Quote
Old 01-16-2005, 04:06 PM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
The rear diffs have a different final drive...I think you need the WRX rear diff if you are using a WRX clutch/tranny/flywheel.
http://www.techworkseng.com/
Or try the local wrecking yards to see if they want it, but most people will pay very little because of the high K's and the engine is not worth much to anyone unless they want to rebuild it.
Old 01-16-2005, 06:57 PM   #7
ADE
Member#: 61145
1998 WRX GC8 EJ-20
thanks for the info tora!!!
Old 01-16-2005, 07:28 PM   #8
Deziwoo
Member#: 53829
02 wrx
white
make a cool coffee table outta it!
just get it cleans and mounted......... slap some plexi glass over it and there you go!
tuner heads coffee table!
Deziwoo is offline   Reply With Quote
Old 01-16-2005, 07:50 PM   #9
veightkiller
Member#: 78967
2011 335i
you can sell it for parts...
veightkiller is offline   Reply With Quote
Old 01-16-2005, 09:15 PM   #10
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
You will especially need the rear diff - the WRX tranny has a 3.9 up front, 1:1.1 reduction center diff, and with your 4.11 diff in the back (3.54 expected), you will seriously break something in no time.
kgb is offline   Reply With Quote
Old 01-16-2005, 10:20 PM   #11
ADE
Member#: 61145
1998 WRX GC8 EJ-20
oh man....i have to look for the rear diff now.... thanx guys
Old 01-16-2005, 10:40 PM   #12
tora
Member#: 5851
09 Forester XT
+ NA Miata
Yes, do NOT drive the car or it will lock on you, or bind, or do something else nasty.
Old 01-17-2005, 01:34 AM   #13
Wylde Horses
Member#: 61255
dirty silver
Wouldn't it be better to change the front ring / pinion? I guess if it's all put back together this would be a real pain in the rear, but if you have the tranny out already, it should be pretty straight forward, right?
Wylde Horses is offline   Reply With Quote
Old 01-17-2005, 03:23 AM   #14
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Depends on how what stage the tranny is at - 4.11 with 1:1.1 center reduction diff is a no-no... if he has the 1:1.1 center reduction diff, then it's easiest to put the 3.54 ring on the rear. If he has 1:1 center diff (unlikely), and tranny is not in yet, front diff swap to 4.11 gives a better ratio.
Old 01-17-2005, 01:32 PM   #15
ADE
Member#: 61145
1998 WRX GC8 EJ-20
well, all i have done is that i took out the whole 2.5rs transmission to the wrx transmission. the only thing i didnt change is the rear diff. isnt the differences between 2.5rs and wrx's rear diff are the final speed?
Old 01-17-2005, 02:27 PM   #16
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
If you put in a stock WRX tranny, I believe you have a 3.9 front diff and 1.1 center, which require a 3.54 ring in the rear to make the whole drivetrain run at 3.9. If you can find the 3.54 ring, tear your rear diff down and swap the ring out on the diff. Not sure if the gear from the driveshaft will work but I believe it should.
Old 01-17-2005, 03:05 PM   #17
poruki
Member#: 68792
ADE, You have PM.
poruki is offline   Reply With Quote
Old 01-17-2005, 06:13 PM   #18
tora
Member#: 5851
09 Forester XT
+ NA Miata
Some good info on doing an engine swap.
http://www.sportcompactcarweb.com/tech/0403scc_hybrid/
Old 01-17-2005, 07:14 PM   #19
andys
Member#: 53455
2004 Forester XTI-RR
dark
Why are you making life complicated? Get the WRX diff from a wrecker and be done with it. Trip out on the LSD.
andys is offline   Reply With Quote
Old 01-17-2005, 07:20 PM   #20
tora
Member#: 5851
09 Forester XT
+ NA Miata
True, rear diff is pretty cheap from the wrecker.
Old 01-17-2005, 09:57 PM   #21
ADE
Member#: 61145
1998 WRX GC8 EJ-20
so the only thing i need to do is to find a wrx rear diff and bolt it on to the transmission?
Old 01-17-2005, 10:09 PM   #22
tora
Member#: 5851
09 Forester XT
+ NA Miata
Yup, assuming everything else on your swap is cool.
Old 01-17-2005, 10:13 PM   #23
ADE
Member#: 61145
1998 WRX GC8 EJ-20
thank you tora!~
Old 01-17-2005, 10:52 PM   #24
tora
Member#: 5851
09 Forester XT
+ NA Miata
ADE, why don't you send me a PM and tell me what you've done and I can make sure you haven't missed anything or made any booboos.
Old 01-18-2005, 01:42 PM   #25
patr
Member#: 97
if you cant find the layshafts to convert the 1.1 to 1.0 we have them here, but its a lot of labour/time intensive... ps there is no such thing as a 'ring gear' in the center diff, its 2 shafts that intertwine, one at 33 teeth, the other at 30. To convert to 1.0, you swap both to be 31 teeth
but the best bet is to get a 3.54 rear diff. If you want to swap the ring and pinion on the rear diff, its also some labour time and the guy who does it needs shim kits etc
the 1.0 conversion makes the car handle better (better torque split f/r)
-Pat
patr is offline   Reply With Quote
what to do with my 2.0l..........................? Flyin_Hayn Built Motor Discussion 39 01-13-2013 04:49 PM
What to do with my 2 new 200 gig drives. Protege Menace Off-Topic 37 12-02-2006 09:01 AM
what to do with my 2 JL 12"W3DV2 ? WS6toWRX Car Audio, Video & Security 3 07-27-2003 12:51 AM
('93-'01) first thing to do for my 2.5RS Blk Devil RS Impreza Forum 18 05-12-2002 02:53 PM
('93-'01) what to do with my 2.5rs makeewak Impreza Forum 17 03-24-2002 04:40 AM
