Old 01-16-2005, 05:37 PM   #1
dru_hill
Member#: 67661
2004 WRX sedan
Default Trans Oil filling
I was changing my gear oil in the 5 speed today, and I added 3.5 quarts and then checked the level and it was a little over the "F" mark on the dipstick. I must not have let it drain enough, cause I thought I was gonna be a little low. Is it bad to have to much oil in the trans like it is in the engine? I can't imagine that gear oil foaming up like engine oil would, but if I need to drain some out I guess I need to. It's such a pain though, I'd rather just leave it alone.
dru_hill is offline   Reply With Quote
Old 01-16-2005, 06:29 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
it's fine - just leave it alone (seriously - it is not going to foam - having too much oil in the engine is very different than the transmission)
Old 01-16-2005, 06:46 PM   #3
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
I do a lot of work with industrial gear drives for coal pulverizers used by power plants. Overfilling a gear drive can result in oil foaming problems. With that said, if you are only slightly over the F mark you should be OK, but you don't want to really overfill the trans. I overfilled mine on my last trans oil change. It was very easy to reach under the car and drain a little oil for peace of mind.
jac04 is offline   Reply With Quote
Old 01-16-2005, 07:27 PM   #4
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Before you get too excited, put a level across the radiator or something. Just a little off and the dipstick will read differently.
OneOBS is offline   Reply With Quote
Old 01-16-2005, 10:42 PM   #5
dru_hill
Member#: 67661
2004 WRX sedan
I think Im gonna drain a little out later this week when its a little warmer. It probably wont make a huge difference, but I will be thinking about it constantly. The worst part is that it stinks so bad.
Old 01-17-2005, 09:37 AM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Just buy a clear plastic tube and suck a little out. If its clear, you can keep it from getting to your mouth and it won't take much to lower the level.
Old 01-17-2005, 09:56 AM   #7
dru_hill
Member#: 67661
2004 WRX sedan
Yeah I think I have a little bit of tubing. I'll try that, I hope that its not to think to siphon though or I will have to just put my finger over the end like picking up liquid with a straw.
Old 01-17-2005, 12:44 PM   #8
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
A bit over the full mark is fine. Usually I put in a little less than 3.5 quarts (around 6+ pints) and it lies in perfect with F on level ground.
-paK +1
Pakin is offline   Reply With Quote
Old 01-18-2005, 11:56 PM   #9
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
what oil should i use in the tranny i have a 03 with 35k on it and nothing has been change please help thank you
tsubaru02 is offline   Reply With Quote
4EAT trans fluid fill location? Mobius118 Newbies & FAQs 3 06-01-2009 11:58 AM
Trans oil in the Diff. No trans oil. cdigerlando Service & Maintenance 9 03-31-2007 09:44 AM
Auto trans OVER filled... Idaho Wolverine Transmission (AT/MT) & Driveline 3 08-16-2005 12:45 AM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
helping a friend, question on 92 legacy trans. fluid fill location Achilles38WRX Legacy Forum 5 04-19-2003 02:06 AM
