Old 07-10-2001, 10:35 AM   #1
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Question Advices on making my own header!!
Here where i live is really hard to get your hands on any aftermarket products for any subaru,and the ones you can get are xtremmelly expensive, so i decided to make my own header at the muffler shop, i already made the hole cat-back 2.25", but now i am considering making the header. The guy at the muffler place told me that he needs the mesaurements to make it, he is offering it to me, for about US$170 wich i think is arelly good deal.
My problem right now is that i dont want to get the job done and then the car gets any slower, so the guy told me he needs the description and mesaurements of what i need. Can any of you help me out?.
I need to now whats the best inlet size?, where do the curves go?,how many tubes are coming out of the engine (4 tubes that come together in one at the end or 4 tubes that come together in two and the one)? in fact i need any opinions you can give me.
Posting pics would really help.
Thanks in advance
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 07-10-2001, 12:28 PM   #2
motorob
Member#: 2878
06 Evo IX MR
Do a search for the MRT headers and exhaust systems. I would have your man copy that design. Four tubes coming off the engine, joining into two, and then into one. The four tubes should be 1 7/8", the two tubes 2", and 2 1/4 when they join into one. There needs to be a balance pipe between the two sides. Then put a single high-flow catalytic converter in place of the stock converters, and have him put an oxygen sensor fitting in one header tube, and one behind the cat. You'll be in business. You also might want to talk to some of the Puerto Rican guys on this board, they seem really nice, and they've got some very tricked out cars that look great. They might be able to give you some advice on suppliers in your part of the world. Good luck.
motorob is offline   Reply With Quote
Old 07-10-2001, 03:30 PM   #3
Member#: 5354
Can't the 2.5 RS engine use a header that comes out from the engine in four tubes 2" and then gets together in one 2 1/4" at the end? and do the tubes leght has to be the same?
Any other opinions?
Old 07-10-2001, 04:20 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
For a custom header, the MRT system is the system to copy. There is a fellow in P.R. who does have the MRT system, so you'll definitely want to get a hold of him. Also search in the Vendors forum for MRT or exhaust group buy or something. It has a few pictures of the system, and probably the fellow's name who lives in P.R. with the system.
The boxer motor header does not look like an inline 4cyl header, so the design is totally different. The diameter of the pipes used may vary depending upon intended use and other mods, but the dimensions given to you by motorob are what MRT uses and seem like a good base (i.e. unless you have cams, don't bother with anything bigger). The MRT system looks pretty big, tube-wise, as it is.
Equal-length tubes are a good idea.
JS
Julian is offline   Reply With Quote
Old 07-10-2001, 04:43 PM   #5
Member#: 5354
Where can i get some pics from the MTR header ?
Diameter of the tubes ?
My current mods:
-complete cat-back exhaust 2.25"
-Custom Ram air intake
-Unorthodox racing pulley set
Old 07-11-2001, 12:21 AM   #6
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
equal lenght
equal lenght
equal lenght.
tht's why JUNE headers are soooooo expensive.
borla are not equal lenght.
be prepared to loss some low end power.......but you will pick up some high end(high RPM) power with the mods you posted.
steven
AliBenn is offline   Reply With Quote
Old 07-11-2001, 12:24 PM   #7
Member#: 5354
Where can i get a pic of a JUNE header?
I still have some doubts!!
Which is better for mi engine?
(4 tubes into 2 and then 1) or (4 tubes that become one at the end)
and also, which do you think should be the diameter for the tubes?
Old 07-11-2001, 01:33 PM   #8
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
It's JUN not JUNE. Also reason why SYMS, CUSCO, ZERO SPORTS, PROVA, STi etc are so expensive.
Remember, if you can, get stainless steel.
GTBGUY is offline   Reply With Quote
Old 07-11-2001, 01:53 PM   #9
roninscar
Member#: 2306
2000 RS Sedan
Blue Ridge Pearl
Default Jun is waayyy difficult
The Jun header is more designed for turbo applications, and has a bunch of very tricky bends and welds. The mrt system is much more copyable.
http://www.mrtrally.com.au/shop/
select exhaust, they have a picture of the version for the Liberty.
Jun can be found here:
http://www.junusa.com/parts/exhaust/headers.htm
Cheers
scotto
roninscar is offline   Reply With Quote
Old 07-11-2001, 02:10 PM   #10
Julian
Member#: 1182
MY00 RS
BRP
Santo, reread my email and do the searches I suggested. All the info is there, you can find it.
I want to make my own grouding kit for my engine what do i need bottlediger Car Audio, Video & Security 8 12-26-2005 05:21 PM
Advice on making my 00RS faster than Mustang GT?? Blu25RS02 Normally Aspirated with bolt-on Forced Induction Powertrain 31 12-27-2002 01:27 PM
Want to make my own mudflaps- LDPE, polyurethane, EPDM, neoprene, etc... slidewaysmike General Forum Archive 12 03-18-2001 12:51 AM
How do I make my own decals on my printer? Andrew General Forum Archive 2 12-14-2000 04:44 AM
Making my own decal jasony General Forum Archive 3 08-11-2000 12:52 AM
