Old 01-16-2005, 06:43 PM   #1
gsteclipse33
Member#: 72859
Default how do u know what map u have loaded onto each number on the utec
is it figured out buy the one on top is switch 1 then the one below it is switch 2 because i loaded up stage 2 and put it onto the utec but under dashboard it still says under mode that its stock does that matter thanks
gsteclipse33 is offline   Reply With Quote
Old 01-16-2005, 06:57 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Yes it matters......
Code:
GENERAL INFORMATION
1. Stock mode is selected with the rotary switch at the rear of the UTEC set to 0. If
the remote switch is fitted this should also be set to 0. You can not run stock
mode if you have upgraded your injectors!
2. Maps 1 through 5 are selected by turning the rotary switch at the rear of the UTEC to
1 to 5. If the remote switch is installed, ensure that the rotary switch at the rear
of the UTEC is set to 0 and select the map you want using the remote switch.
Switching between maps will take effect only when the engine is below
1600 rpm. Use caution when switching maps.
The UTEC Dashboard will show both the number of the Map and the switch position
that is selected once the car is running. If the car is not running the UTEC may
revert back to stock mode. Also, when starting the car the check engine light will
flash and indicate which map you have selected. For example if you have selected
map 2 the check engine light will flash twice and then stay on until the car is started.
The map at the top is 1 and the mao at the bottom is 5.
peace
Old 01-17-2005, 12:48 AM   #3
gsteclipse33
Member#: 72859
thanks u asnwered eery question i had
How do i know what kind of WRX i have kbrok Newbies & FAQs 15 01-09-2014 11:13 AM
how do i know what shortblock i have? GripGC8 Pre-2002 Factory Turbo Powertrain 5 10-14-2006 12:54 PM
how do you know what kind of downpipe do you have? ASpec818 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-05-2003 09:58 PM
How do you know what model you have? stentorian General Community 0 01-10-2003 03:31 PM
anyone have 0-60, hp numbers on the vishnu turbo kit? Subecowboy Normally Aspirated Powertrain 94 11-18-2000 03:25 AM
