Old 01-16-2005, 07:29 PM   #1
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
Default radiator cap
will an aftermarket radiator cap(blitz/sti/greddy/crucial) with a factory radiator and thermostat can make a radiator to leak??
scooby_wooby is offline   Reply With Quote
Old 01-16-2005, 07:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, if it is a higher pressure cap than the stock one. This is not a good mod. If you want the visual "bling" put a sticker on your existing cap.
Old 01-16-2005, 07:32 PM   #3
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
thanks for the input, i guess its my fault that my radiator leaked..arghh.. time to look for a cheap radiator
Old 01-16-2005, 07:59 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
In the future, a few minutes of research on this site before proceeding with such mods can save you a lot of grief later on.
Old 01-16-2005, 11:14 PM   #5
Rickyh
Member#: 40453
I've had the 1.4 bar crucial cap for about 9 months with no leaks. I had planned on getting a pwr radiator when the stocker leaked but it never did.
Rickyh is offline   Reply With Quote
Old 01-17-2005, 09:44 AM   #6
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Wow, it's 1.4 bar? That's pretty aggressive.. where did you buy it?
Jay
Diversion is offline   Reply With Quote
Old 01-17-2005, 04:14 PM   #7
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
UPDATE:
i called up the dealership today and told me that they did a pressure test and my blitz radiator cap wasn't the reason for my radiator to leak. tomorrow, they are going to make sure my headgasket didnt blow up. how do you know if a headgasket is blown?? my car was running fine before dropping it off to the dealership.
Old 01-17-2005, 04:49 PM   #8
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Hydrocarbons in the cooling system, and/or through the tail pipe. Sometimes you can smell it. Coolant temperature rises above normal, but that can be other factors such as a leaking radiator.
Internal leaks include milky condition of the oil sump from coolant leaking. Happens you your car turns off. There is no pressure on some of the cylinders but the pressure in the cooling system is still intact after shut off, so if the headgaskets leak, coolant will slowly seep into the low pressure area of the cylinder and in between the piston down to the sump. Viscousity of the oil is reduced over time.
Headgaskets can also leak from the oil passages to the cooling system (vice versa) and that can affect the cooling performance of the coolant or down to the combustion cylinder and burn oil.
Tailpipe emitting dark blusish smoke (oil), or whitish (coolant).
I'm sure there is more, just speaking from my mind
-paK +2
Pakin is offline   Reply With Quote
Old 01-17-2005, 04:59 PM   #9
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
i'm running catless and when i start the car up in the morning, (ofcourse) there is white smoke but in the midday/afternoon(weather is warm) there is no presence of white smoke.. thanks for the input pak
Old 01-17-2005, 06:42 PM   #10
Rickyh
Member#: 40453
yup, it's 1.4 bar. I got the cap from infinite performance.
Old 01-17-2005, 09:05 PM   #11
MisterX
Member#: 17275
2002 wrx wagon
wr blue
A higher pressure cap won't make a radiator leak unless ther's already something wrong with the radiator. In the case of most manufacturers, you've got a serious design deficiency to deal with in interest of shaving cost - plastic tanks. The plastic to aluminum joint is subject to failure.
MisterX is offline   Reply With Quote
Old 01-18-2005, 08:22 PM   #12
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
update:
the dealership replaced my radiator under warranty, they didn't find any evidence of my radiator cap being the reason of the leak. i'm a happy camper...
Old 01-18-2005, 08:32 PM   #13
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
It nice that the dealer didn't use the cap as a way out. I would think that a hose would fail much sooner than the radiator because of higher pressure. If you think the head gasket is leaking, take the cap offand start the car. When the coolant starts to flow to the radiator there will be bubbles and foaming if there is a leak.
Mikemar is offline   Reply With Quote
Old 02-04-2005, 03:16 PM   #14
JaMes W
Member#: 41500
2002 stock turbo WRX
[email protected]
I have been looking for info on caps. cant seem to find it on here... So there is no advantage to an aftermarket cap? just wondering because i am about to install a new radiator and thermostat and i wanted to know if a cap is something that i should get or not. i dont car about bling just function. Thanks
JaMes W is offline   Reply With Quote
Old 02-04-2005, 11:17 PM   #15
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
The two key features of a radiator cap are (a) that it fits properly on the radiator, making a good seal but still allowing overflow in/out and (b) the pressure at which it starts allowing overflow.
If you have an OEM radiator, the OEM cap will likely be the best fit for it.
Changing the pressure rating on the radiator cap means that *the whole cooling system* will now be running under a different max pressure. There is no real advantage to this *if your engine/cooling system were not designed for this*. On the downside, lots of things besides the radiator can spring a leak if subjected to higher-than-designed pressure, and many of them are much more expensive to fix than replacing a radiator.
So, unless you have substantially modified your *engine* and know what cooling system characteristics you want to change and why (higher cooling system pressure is not "better" like higher HP is), don't mess with a different pressure limit on the radiator cap.
Old 02-06-2005, 12:41 PM   #16
JaMes W
Member#: 41500
[email protected]
Thanks for the reply
FS:GT Spec radiator shroud, Perrin radiator hoses, Greddy 1.3 radiator cap Copper Rex Tri-State Area Private Classifieds 4 04-16-2010 04:35 PM
NC: ARC oil cap and radiator cap MartinD Private 'For Sale' Classifieds 39 06-15-2006 11:18 PM
FS: STi radiator cap and Zerosports oil cap blk rix wagon Private 'For Sale' Classifieds 48 06-14-2005 01:38 AM
Changing stock radiator cap to STi cap? millionsofsubys Normally Aspirated Powertrain 4 07-08-2004 10:27 PM
FS: SARD BOV, STi radiator cap, Billet Oil Cap adrive43 Tri-State Area Forum 5 05-31-2004 09:17 PM
