Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-16-2005, 08:25 PM   #1
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Default FXT trans into a GC RS?
Is the FXT 5-speed transmission a drop-in for a GC 2.5 RS?
If I do an engine swap, I'm interested in using the reinforced tranny from an FXT. Does it have the correct ratios and dimensions to use only the tranny and not have to swap the rest of the drivetrain?
Thanks.
Layman is offline   Reply With Quote
Old 01-16-2005, 10:28 PM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
It'll fit. You'll have to more than likely use the diff off the FXT though unless the final drive on the FXT is the same as the RS. If it's a pull type clutch you'll have to put in the correct clutch as well as change the clutch slave cylinder. While you're in there I would also consider putting in a nice lightened flywheel. It makes it that much better.
Z
Zephyr is offline   Reply With Quote
Old 01-16-2005, 11:21 PM   #3
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Cool. I forgot all about the clutch.
I think the final drive is the same. 4.44 on both, right?
Old 01-16-2005, 11:23 PM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The RS with a 5MT's final is 4.11, not sure about the FXT.
Z
Old 01-17-2005, 03:01 AM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
FXT is 4.44.
Ben
Old 01-17-2005, 04:11 AM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
Originally Posted by PHATsuby
FXT is 4.44.
Ben
is it really a 4.444? or are we talking about the auto?
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-17-2005, 04:37 AM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
it is really 4.44, we are talking about the manual.
Ben
Old 01-17-2005, 05:23 AM   #8
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
so, could it be an STi 5 speed in cognito, i havent heard of a 5 speed with a 4.444 final drive other than STi trannys.
on the original Q, the only problem would be the final drive ratio, as said above.
Old 01-17-2005, 11:06 AM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
Isn't the RS 4EAT ratio 4.444? If so, you'd be G2G using an FXT 5spd w/RS auto trannied diff.
Jay Storm
Old 01-17-2005, 11:32 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes its very likely that it is a v-limited RA tranny in cognito
it is probblay the 3nd most desireable transmission
2nd being a RA w/dccd
1st being a 6 speed
Old 01-17-2005, 12:00 PM   #11
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Hmmm. So since I have a 4.11 right now, I'd have to swap the rear diff anyhow - unless I wanted to crack open the tranny.
Damn. It's a sweet transmission, but that's a gas-burning ratio!
Old 01-17-2005, 12:05 PM   #12
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Gas burning? yes, however the forrester still gets half-decent MPG.
tooocool49723 is offline   Reply With Quote
Old 01-17-2005, 01:11 PM   #13
PHATsuby
Member#: 13617
2001 Legacy GT back
what is a v-limited RA tranny and how does it differ from the usual STi RA trannies. The forester gets decent gas mileage cause its gear ratios are pretty good, or at least the gas saving one is
Ben
Old 01-17-2005, 05:31 PM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
FXT still uses tall tires for an overall ratio similar to or lower than an Impreza. At least on the surface it would appear that way.
Jay Storm
Old 01-17-2005, 06:28 PM   #15
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
Ben
a v-limited RA is a limited edition WRX. it is not an STi version.
Old 01-17-2005, 06:49 PM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
yes, i am aware of what it is, i was asking about the tranny difference, thanks though.
Ben
Old 01-18-2005, 12:17 PM   #17
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
it's not an STI 5 speed. same wrx gears with a different final drive. that is it...nothing reinforced by it.
latinskllz is offline   Reply With Quote
Old 01-18-2005, 01:20 PM   #18
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Are you talking about the FXT tranny?
If so, that's contrary to both what SOA says and other people's impressions. I'm pretty sure it's reinforced beyond a WRX tranny. Otherwise you'd have a ton of shattered trannys out there.
Old 01-18-2005, 06:12 PM   #19
pr0driveX
Member#: 23207
2013 BRZ
latinskllz is right. Check around in the Tranny Forum because somewhere there was mentioned this stuff. Same tranny as a WRX but different final drive. Hence why a FXT is faster.
Eric
pr0driveX is offline   Reply With Quote
Old 01-18-2005, 06:18 PM   #20
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
besides, a FXT has the same motor as an STi w/ different ECU and turbo. It makes much more power than a WRX, and if it was the same tranny, it would break MUCH more often.
Old 01-18-2005, 06:21 PM   #21
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
doesnt the 4.44FD help keep the tranny from abusorbing all the shock, i forget why but i was reading that somewhere.
what does a FXT tranny go for?
scoobyimpreza is offline   Reply With Quote
Old 01-18-2005, 07:09 PM   #22
pr0driveX
Member#: 23207
2013 BRZ
FXT has an STi motor, yes. It only makes 210 hp though which is less than a WRX but also slightly more torque at 235 ft lbs. It is the same tranny as a WRX but, like I said before, it has a different final drive (4.44 v. 3.90) making the FXT accelerate a lot quicker.
The shorter gearing helps get the power down faster and perhaps "absorbs" the shock better.
Eric
Old 01-18-2005, 07:49 PM   #23
pr0driveX
Member#: 23207
2013 BRZ
Okay, so maybe the transmission case was strengthened and redesigned, but I'm pretty sure the ratios are the same as a WRX with a final drive of 4.44
Old 01-30-2005, 11:09 PM   #24
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
More power doesn't necessarily break a tranny. It can be: driving habits, how the torque curve is on a car, etc.
the reason why the FXT are not breaking that much is because how linear the torque curve is on the car. With a turbo'd RS with high compression, the torque curve climbs up really fast and that breaks trannies, if not contributes to it.
One nice feature about the fxt tranny i believe is on there is the triple cone synhros on 1st and some of the other gears to ease shifting. Other than that, it is a wrx gear ratio'd box and it appears to be the same box without webbing with the 4.44 final drive.
i have seen one in person and the case doesn't look like it has extra webbing...
Just some food for though.
07 FXT trans into 04wrx with LGT 1-2 gears scoobdude Subaru Conversions 9 04-09-2012 02:56 AM
06/07 wrx clutch into gc rs unforgiven2144 Transmission (AT/MT) & Driveline 1 08-04-2008 09:18 AM
FXT trans case same as WRX trans case? 03WRX-WRB Transmission (AT/MT) & Driveline 5 03-04-2008 06:14 PM
95 JDM Trans into 05 RS. Im stumped Gurus needed! Pics included! Honkey3k Transmission (AT/MT) & Driveline 5 03-02-2007 12:42 AM
GruppeS JDM FXT swap into '99 RS cjfike Subaru Conversions 5 08-04-2006 04:12 PM
