Old 01-16-2005, 09:17 PM   #1
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
Default cruise control install
allrighty guys im installing cruise control on my 93gc. i know ill need the cruise cable/vacum pump and i know ill need the dashswitch and control stock near the steering wheel.My question is 2 parts.
1. is there anything im missing parts wise?
2. is it just easiest to swap out steering wheels for the cruise control
note these parts are coming out of a 92 legacy wagon.
Thanks in advance.
bugman1964 is offline   Reply With Quote
Old 01-19-2005, 06:31 PM   #2
ultrasonic
Member#: 18006
1. All the connectors (and wiring) to plug into all the parts. And the cruise control computer module, which is probably under the dash somewhere.
2. I don't know about '93. I found that it's very easy to add the switch to later models- I've done it on a '90 & '00. You would have to compare your steering wheel with one of the same year that has the stock cruise switch. Swapping steering wheels with the 92 Leg is a possibility, but I can't confirm that.
ultrasonic is offline   Reply With Quote
Old 01-20-2005, 11:31 AM   #3
avk
Member#: 17252
'06 WX8
59E
You might be able to use cruise control parts from a Legacy, but they won't plug into the harness connectors on the Impreza. The c.c. on Impreza does not have a vacuum pump, just a big actuator connected directly to the intake, and the wiring is different. The c.c. kit for '93-'94 (and '95 1.8) is H7010FA200/210 (manual/auto), it's listed now for $70 and maybe someone still has it.
avk is offline   Reply With Quote
Old 01-21-2005, 01:37 PM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Try fogler subaru in North Carolina. They found the old units and sell them for around $60.
linsavy is offline   Reply With Quote
Cruise control install problem w/ aftermarket wheel. SueBaroo Electrical & Lighting 15 01-04-2010 05:39 PM
easiest way disconnecting cruise control cable from TB, cruise control removal 02-03 fastwrx25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2008 07:30 PM
Cruise Control Install ImprezaVA Electrical & Lighting 16 03-30-2005 09:36 AM
cruise control installation domm Electrical & Lighting 0 06-02-2004 04:00 PM
('93-'01) Cruise control install on MY99 OBS? Dozza Impreza Forum 6 04-21-2001 01:27 PM
