Old 01-16-2005, 09:18 PM   #1
Tgui
Member#: 44771
Talking Java UTEC Tuning Tool (JUTEC)
I've started Java based (cross platform) UTEC Tuning tool. The origonal post is on WRXHackers.com
http://www.wrxhackers.com/forums/showthread.php?t=3020
This is a cross post, yes, but I can't post files here.
In short, a UTEC tuning tool that now supports Linux and Windows. First public release allows a user to connect to the UTEC and pull logger #1 data to the GUI (I find this useful right now heh). I'd like to have people test just how cross platform this tool really is I'm coding up some 2D real time graphing functionality right now, then I'll work on the map editing.
Ideas, suggestions are welcome, but be sure to check out WRXHackers first.
Thanks,
-Eric
Tgui is offline   Reply With Quote
Old 01-16-2005, 09:57 PM   #2
CBRDSpeedfactory
Member#: 68255
ALL lots of fast 1s
mostly silver!
Default nice
i like the idea of the graphic interface, it would be nice to have a map editor that allowed for graphical display of the fueling/timing/boost maps individually for a load column accross all rpm with a click and drag feature for smoothing...
im not familiar with javascript...
chad b
CBRDSpeedfactory is offline   Reply With Quote
Old 01-16-2005, 11:15 PM   #3
anzu
Member#: 42154
2008 WRX STI
From NOVA eh? Maybe I'll see you around. Good luck with JUTEC, sounds really cool.
anzu is offline   Reply With Quote
Old 01-17-2005, 12:19 AM   #4
04RCSTI
Member#: 65694
MDC Forever
Black '06 STI
sounds like a really cool idea! keep us updated!
04RCSTI is offline   Reply With Quote
Old 01-17-2005, 07:37 AM   #5
Tgui
Member#: 44771
Thanks Download it, I need to know if this thing works for other people as is, that is before I start cracking on new features. Though, all it does now is pull logging data from the UTEC.
-Eric-
Old 01-17-2005, 07:50 PM   #6
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Thumbs up
Sell it to turbox's, and then buy yourself an STi divetrain and give it to me for giving you the idea. You should just call it J-TEC.
But really mad props for the idea and press on.
Trunk_Monkey is offline   Reply With Quote
Old 01-17-2005, 08:28 PM   #7
caryfd227
Member#: 22512
2015 Subaru WRX
Galaxy Blue Pearl
Thanks,
-Eric
So.. if its java, then you could implement Apple support as well as linux... Any plans for a Mac version?
caryfd227 is offline   Reply With Quote
Old 01-18-2005, 01:17 PM   #8
Tgui
Member#: 44771
Do you run OSX? I can try to throw something together for you to try. You can be my little test monkey, since I don't own a Mac.
-Eric-
Old 01-18-2005, 01:20 PM   #9
happasaiyan
Member#: 37731
-Eric-
the beauty of java. recompile and youre done.
happasaiyan is offline   Reply With Quote
Old 01-18-2005, 01:27 PM   #10
Tgui
Member#: 44771
Actually even easier than that. No recompile of main code. Just compile a package that supports serial port functionality. Plug in, and play
-Eric-
Old 01-18-2005, 01:55 PM   #11
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
I was working on building 3d surface maps of fuel/boost/timing in Java, but have been running short on time. Here's what I was thinking of: http://www.navgen.com/java3d/surface.html
It would be cool to be able to visualize the maps, then ultimately be able to select points on the 3d map and drag values up/down to generate a new values in a new map.
jetskizero is offline   Reply With Quote
Old 01-18-2005, 01:57 PM   #12
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Oh, another idea would be to plot on a 2d map the a/f values from a Tuner log (W/B) from the utec. Kind of like most of the dyno plots you see here. That would be helpful I'm sure.
Old 01-18-2005, 02:04 PM   #13
Tgui
Member#: 44771
I found that link a while ago also I'm tooling around with Java 3D, but first will be 2D graphing.
-Eric-
Old 01-18-2005, 04:57 PM   #14
caryfd227
Member#: 22512
2015 Subaru WRX
Galaxy Blue Pearl
-Eric-
Yes, the newest version of OSX.. thanks for even considering the idea... as it stands now I will have to buy a new computer or use virtual PC to program a UTEC. I don't own a UTEC yet, but I will within the next month and a half. Thanks!
Old 01-18-2005, 05:17 PM   #15
Tgui
Member#: 44771
BTW, check out the link to WRXHackers. I might not continue the path with JUTEC as origonally thought.
The reason why is Zutec. ANOTHER Java based tuning utility. I'm not in the market for reinvention. Go to the link below and see if user cdvma will prepare an OSX enabled application for you.
http://www.wrxhackers.com/forums/showthread.php?t=2686
Give me ideas folks, I have the mad skillz, lets cover some new ground with tools that don't already exist.
-Eric-
Old 01-18-2005, 06:14 PM   #16
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Wow, sweet. I'm downloading that when I get home tonight.
Zola is offline   Reply With Quote
PDX Tuning Coming to Houston - Open Source, Ecutek, AccessPort, UTEC Tuning Geoff Texas Impreza Club Forum -- TXIC 53 10-14-2009 11:27 PM
HYDRA - Greek Animal Or WRX TUNING Tool DRunkTrunkMonkey Other Engine Management 3 03-24-2005 11:39 AM
UTEC Logger Software! Tuning tools needed. woodruf Engine Management & Tuning 0 08-03-2004 01:32 AM
Utec Tune...Anywhere to get tuned? urabusXRW Tri-State Area Forum 1 11-23-2003 08:17 AM
found special deal on tuning tool gypsymoth Normally Aspirated Powertrain 6 05-21-2002 06:39 PM
