Old 01-16-2005, 09:46 PM   #1
SIMPFLY
Member#: 54794
Jan 2004 wrx @ 5 mi
Apr 2016 @ 234,567 mi.
Default 04 WRX tranny drain plug - pic and question
What size of TORX socket do i need to remove the drain plug on my 04 rex? I looked in the service manual but did not find the info. here's a pic. thank you.
SIMPFLY is offline   Reply With Quote
Old 01-16-2005, 09:56 PM   #2
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
I just bought one of these for work, I think its a t-70 but I'll let you know tomorrow for sure. This'll keep the lube shop from draining the trans on accident!
that is wierd, my 04 has a 21mm like all the previous. I thought only 05's were getting the new plugs.
00Maddog is offline   Reply With Quote
Old 01-16-2005, 10:35 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
T-70 and good luck finding one. The are expensive from what I've heard too.
Old 01-16-2005, 10:37 PM   #4
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
thats weird. i wonder why they changed it.
adeliciouspizza is offline   Reply With Quote
Old 01-16-2005, 10:41 PM   #5
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
T-70
Matco $27
If you are in texas i have it if you need to borrow. and becareful, cause that mother tight!!!. Make sure its not your wal-mart special as it will prebably break or bend.
scoobdude is offline   Reply With Quote
Old 01-21-2005, 06:55 PM   #6
SIMPFLY
Member#: 54794
Jan 2004 wrx @ 5 mi
thanks for your help everyone.
I found T70 at the Matco-tool truck for $19.71 plus tax. unfortunately, matco doesn't sell it online. if anybody needs the tool, you can call 1-866-BUY-TOOL to find the truck in your locale or buy via phone.
Old 01-23-2005, 10:35 AM   #7
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Just to drop .02 . They changed the pluge so goofballs at Jiffy Lube and other fast lube shops will stop dropping the tranny fluid on the manual cars by mistake when you got an oil change .
imprezzakc is offline   Reply With Quote
Old 01-23-2005, 11:46 AM   #8
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I've got a question, not for me (i've an '03), but for others...
When retightening the bolt, do you retighten to ~33ft/lbs of torque like on the previous year models?
[don't forget to get a new "crush" washer when changing your transmission fluid. it really doesn't crush like the washer for the motor oil drain plug, but there's a washer there. at least on my car there's one. (costs me $2.50 from the dealer too...) ]
Old 01-24-2005, 01:29 AM   #9
SIMPFLY
Member#: 54794
Jan 2004 wrx @ 5 mi
the torque on the 04 5MT tranny drain plug is ~51 ft-lb.
04 wrx tranny drain bolt size ? 04wrxhart Transmission (AT/MT) & Driveline 14 08-18-2016 11:37 PM
Size for Tranny drain plug and diff plug? sfwrx Transmission (AT/MT) & Driveline 11 09-15-2007 11:38 PM
Help! Found this piece of metal attached to the tranny drain plug. Pics! subysouth Transmission (AT/MT) & Driveline 46 07-24-2007 04:14 PM
tranny drain plug question???? scooby_wooby Transmission (AT/MT) & Driveline 2 10-28-2005 04:39 PM
Need a pic where the tranny drain plug is BIG BEN Transmission (AT/MT) & Driveline 3 11-02-2002 01:22 AM
