Old 01-24-2005, 11:15 AM   #1
guinsu
Member#: 18756
2002 WRX Wagon
Default Cleaning up Oil Leak
I've got one of those Fumato valves on my wrx and I've noticed it tends to leak slightly (not enough to lower the oil level in the car but enough to leave an oil spot in the garage). So now I have a thin film of oil on the floor of my garage. The floor is concrete that has been painted, so I am sure if I find a way to get it up there will be no permanent mark. I was just wondering what to use to get it up. I thought after soaking as much up with paper towels I could use dishsoap and scrub the rest out. Bad idea? I'm just tired of getting oil all over my back when I work on the car.
guinsu is offline   Reply With Quote
Old 01-24-2005, 11:26 AM   #2
spacenut999
Member#: 40307
2004 WRX Sport Wagon
I think there is actually oil spill stuff out there on the market...but I've used kitty litter. If you dump enough of that on the floor, let it sit for a while, then sweep it up it should dry up.
spacenut999 is offline   Reply With Quote
Old 01-24-2005, 11:29 AM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Post
I always use gas, which I wouldn't recommend on a painted garage floor, plus, it's flammable.
Just get as much as you can up with rags/paper towel and use a degreaser such as Simple Green or Greased Lightning. What you mentioned, about the soap and water will work fine. Removing the oily film shouldn't be a problem. Just whatever you use make sure to test a small area first that way you won't be painting your garage floor again.
-Charles-
ImprezaVA is offline   Reply With Quote
Gov't cleaning up oil spill = SOCIALISM!! Porter Political Playground 132 05-19-2010 06:49 PM
WWOTR: For cleaning up oil on concrete newscooby Off-Topic 25 03-28-2008 03:17 PM
New UP/DP, oil leak on Turbo Figone Factory 2.0L Turbo Powertrain 4 12-24-2005 11:23 PM
Yeah almost blew up my car again ( oil leak on 20g at sbr feed line) mpower22 Factory 2.5L Turbo Powertrain 20 08-30-2005 02:58 PM
Small Oil Leak/ 60k tune up Questions Ahzlon Normally Aspirated Powertrain 1 11-19-2003 07:38 PM
Message Board Statistics All times are GMT -4. The time now is 08:18 PM.
