Old 01-23-2005, 11:23 AM   #1
Dexter
Member#: 5179
Default Attempting to replace my belts. Help
I have loosed the bolts which hold the alternator and moved the alternator down as far as possible, I can't get the belt off. It's loose but I can't pull it off the alternator or power steering pullys.
Actually I don't want to damage the belt or pully by using a screw driver for leverage. Does any one have any suggestions?
thx
Dexter is offline   Reply With Quote
Old 01-23-2005, 12:49 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It should just come off, unless it has been replaced previously with the wrong (too small) size belt. Is everything 100% stock, no underdrive pulleys?
Old 01-23-2005, 01:56 PM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
You did adjust the belt tension adjustment slider bolt, I hope. If not the alternator won't move very far and you'll not get the belt off. I know this is pretty obvious, but just making sure.
Alan is offline   Reply With Quote
Old 01-23-2005, 02:08 PM   #4
Dexter
Member#: 5179
I have loosend the bolt which glides the adjustment slider bolt, as well as the bolt itself. The alternator is able move down until it can't go any further. Yet, the belt grooves can not slide over the pully troughs.
I am starting to think my beloved dealership gave me the wrong belt but I read somewhere else in here that someone else had to pry it off. They did not state how they did it.
Old 01-23-2005, 07:58 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
There is also a bolt that holds the alternator onto the bracket on the right. If you loosen that it should give you enough slack.edited, (bolt, not belt) Sorry bout that.
Tim Sanderson is offline   Reply With Quote
Old 01-24-2005, 12:44 AM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
On the alternator belt adjuster, you should go down all the way until there is little of the bolt bottom seen in the screw block.
By then there should be some clearance between the bolt head and the head surface of the adjusting screw of about a 1/2 inch. If you have more than that, try pressing down on the alternator and see if it goes down any further, as those tend to seize early before the max travel.
-paK +1
Pakin is offline   Reply With Quote
So I attempted to do my timing belt today... WeldingHank Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-04-2008 12:17 AM
i'm attempting to 'gut' my 3rd cat. Need Help BlackDahliaInFlames Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-23-2007 09:20 PM
Trying to replace my alt belt. Help Dexter New England Impreza Club Forum -- NESIC 10 01-23-2005 10:11 PM
Someone help me to replace timing belt on 92 Mita for $100? WRXVII Tri-State Area Forum 4 01-28-2004 01:38 PM
Looking for help to replace timing belt on a CRX?(Sac) jotarou1 Bay Area Impreza Club Forum -- BAIC 0 02-22-2003 05:25 PM
