Old 01-17-2005, 12:17 AM   #1
rmac12
Member#: 78637
2008 STI
SSM
Default Accessport stage 2 with fmic?
would the stage 2 map run lean with a fmic and short ram intake? Or would i be problem free?
rmac12 is offline   Reply With Quote
Old 01-17-2005, 01:59 AM   #2
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
The AP was not intended for a FMIC...
BigJ04STi is offline   Reply With Quote
Old 01-17-2005, 04:10 AM   #3
awilson529
RIP
Member#: 38867
11 Mazda
Pulleys, & FMIC are within the learning curve, of the Ap...
It's safe, but you might not get the results you expect.
awilson529 is offline   Reply With Quote
Old 01-17-2005, 11:25 AM   #4
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
I was wondering this exact same thing.. makes me wanna lean toward EcuTek now or some other form of engine management. I just picked up a FMIC but I have stock turbo. I cant imagine it Hurting anything.. your just adding the time the air takes to get to the Throttle body... only thing that could affect it is if you get an aftermarket intake. (which is req. for a FMIC) But then if you get one that doesnt affect the MAF reading you should be ok right? Same goes for the BOV.. stay recirculating and there should be no problem. The AP map isnt gonna see any changes besides the extra charge time. But who knows... might screw it all up.
Subie2 is offline   Reply With Quote
Old 01-17-2005, 02:49 PM   #5
hondaeater69
Member#: 60324
My question is why on earth would you put a FMIC on stage 2??? FMIC is overkill for the stock turbo. The intake will probably mess with the tune more than the FMIC. If you have the proper gauges installed, you can install the parts and keep an eye on everything, mainly boost, EGT, and AFR. If something gets dangerous go get a custom tune or take off the parts that messed with the tune. Without the proper monitoring, i wouldn't mess with the intake that comes along with a FMIC.
hondaeater69 is online now   Reply With Quote
Old 01-17-2005, 07:05 PM   #6
Gonz
Member#: 18642
2005 Impreza WRX STi
Not safe. Stage II must use the stock intake.
Gonz is offline   Reply With Quote
Old 01-17-2005, 07:11 PM   #7
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
If the MAF readings still read the same then nothing changes from stock. Therefore its safe. Now whether or not that happens.. who knows!
Old 01-17-2005, 07:17 PM   #8
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
Stg II with a FMIC sounds like someone is gonna upgrade in the near future.. I see nothing wrong with it IMO. It wont "hurt" anything.
V2 Accessport Stage 2 with STI TBE? HELPr AccessPort 1 10-22-2009 10:15 PM
02 WRX 4eat, stage 2 with accessport - did I hurt my tranny?? hellonwrxwheels Transmission (AT/MT) & Driveline 6 01-04-2006 11:21 PM
Weird RPM surge with accessport stage 2 kinada423 Engine Management & Tuning 10 10-11-2005 04:44 PM
Did you pass OBD-II test with Accessport stage 2 and upipe resistor fix? MO REX Engine Management & Tuning 4 11-24-2004 08:12 PM
trying to go stage 2 with accessport skimmilk68 Engine Management & Tuning 4 05-25-2004 11:09 PM
