Old 01-17-2005, 12:43 AM   #1
DONAUDI
Member#: 71639
2004 STI
Default defi fuel pressure guage
installing defi fuel pressure guage. need to know what line to tee into. have 04 sti. looks like fuel lines are color coded. one of them is blue and i think the other is yellow. also what diameter tee is needed. thankx
DONAUDI is offline   Reply With Quote
Old 01-17-2005, 03:19 PM   #2
DONAUDI
Member#: 71639
2004 STI
Bump or answer or link?
Old 01-17-2005, 05:40 PM   #3
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
i just put it inline after the fuel filter using a T that i think i got from Pegasus - i dont remember which size, just go look at the hose maybe 1/4 or 5/16 .. make sure you get one threaded properly for your defi sender .. http://www.pegasusautoracing.com/
ronaldwrx is offline   Reply With Quote
Old 01-17-2005, 07:06 PM   #4
DONAUDI
Member#: 71639
2004 STI
BUMP
Old 01-18-2005, 12:39 AM   #5
vf39hipsi
Member#: 55794
there is no underhood fuel filter on the STi. Just trace the line that goes to the fuel rail NOT THE PRESSURE REGULATOR, I believe it is the top line when you are looking by the strut tower.
vf39hipsi is offline   Reply With Quote
Old 01-18-2005, 01:21 AM   #6
DONAUDI
Member#: 71639
2004 STI
I could be wrong but i pulled some fuel lines today to get diameter. I'll post it when i get the correct size. Anyways i pulled the top line then had someone turn on the car. The fuel shot from engine side to rear of the car. So i pulled the only other thick fuel line. Which was the bottom most one. Had them start the car again and this time it was going toward the engine. So i hope its this line theres three altogeher. But only two are thick the other one is thin. By the way what is those black fpr looking devices on the fuel line. Never seen those before in my 5+ years of wrenching.
Old 01-18-2005, 01:15 PM   #7
DONAUDI
Member#: 71639
2004 STI
Fuel line size 5/16. Will get part #'s from napa later.
F/S: AEM Boost & Defi Fuel Pressure & Defi Voltage Meters - BNIB!! CALIBAN SCIC Private Classifieds 0 02-09-2009 04:37 PM
fuel pressure guage/sensor as oil pressure Jaxx Electrical & Lighting 0 04-09-2007 01:10 PM
Fuel Pressure Guage Help! chichapher Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-07-2002 01:05 PM
Fuel Pressure Guage Install question DaveK Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-25-2001 12:09 AM
Fuel Pressure Guage install... Autometer sucks! 8Complex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-04-2001 04:26 PM
