Old 01-17-2005, 08:44 AM   #1
hotrod
Member#: 14141
2002 Impreza WRX
Default Appears stock turbo is 13T not 13G
The subaru community has believed (myself included) for a long time that the stock turbo on the WRX was a TD04L-13G. This was based on statements made by well respected members of the community back in early 2002 when the car first came out.
The DSM community has been refering to it as a 13T for quite some time now, and since I just recently pulled my stock turbo off, I just pulled the compressor cover and measured the compressor.
According to compressor dimensions published on :
http://www.stealth316.com/2-turboguide.htm
The compressor impeller measures out as a 13T, not as a 13G.
My compressor measures 2.205 inches at the max diameter across the impellers, (exducer dia) compared to the expected 2.203 inch max dia on a 13T impeller.
The minimum dia across the impellers (inducer diameter) measures 1.599 inches compared to the expected 1.597 inches for a 13T impeller.
This shows a consistant bias of +.002 on the measurements ( using a very old vernier caliper that has not been calibrated in 25 years.
It looks to me like we need to begin the long process of changing the urban legend that this is a 13G impeller because mine at least certainly measures out as a 13T.
I suspect the basis of this is it is nearly impossible to find a compressor map for the 13T, and folks used the nearest thing they could find, and it took on a life of its own.
FWIW
Larry
hotrod is offline   Reply With Quote
Old 01-17-2005, 09:27 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks for the info Larry. If there is one member of NASIOC I wish we could bottle up in sell in stores, it would be you.
Old 01-17-2005, 04:09 PM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Just found an industry part listing by Mellet that list identification measurements for the Mitsubishi turbos.
http://www.melett.com/pdfs/MHI/Mhi%20TD04.pdf
My measurement are exactly as specified in that catalog
It specifies for the 13T, measurements of:
56.01 mm dia exducer = 2.20511 inches vs my 2.205
40.64 mm dia inducer = 1.59999 inches vs my 1.599
Catalog date 3/04
Larry
Old 01-17-2005, 09:36 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Would it be possible for a stock TD04 to be an 'H' and not an 'L' ??? And what is THAT difference????
Old 01-17-2005, 10:40 PM   #5
AlucardR
Member#: 54213
What does Subaru say regarding this? I think an answer right from them would be the most accurate.
AlucardR is offline   Reply With Quote
Old 01-18-2005, 02:50 AM   #6
DumbUglyDragon
Member#: 61077
1993 WRX
Haha - that took a while!
DumbUglyDragon is offline   Reply With Quote
Old 01-18-2005, 06:57 AM   #7
hotrod
Member#: 14141
2002 Impreza WRX
After comparing notes with jlevy I'm down grading my "guess" of the turbos flow to the range from 385 - 410 CFM, but it is still a guess.
As far as the H vs L --- I have no clue. Frankly I have better things to do than try to use my psychic skills to figure out what the "pro's" should have made public back in 2003 when they knew what this turbo really was.
I have very little patience with the turbo industry's super secret info mentality. Like most folks, on these forums I trusted the folks that started the speculation about the compressor being a 13G would correct the community if/when they learned otherwise.
Of course the draw of selling $900 dollar IHI turbo's that are hardly better than the stock turbo, seems to have won out over ethic's.
Larry
Old 01-18-2005, 08:23 AM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I agree Larry. Though I'm not a real old school here, I remember the days when it took an aftermarket turbo to break into the 12s. Even thinking you could do so with a stock turbo was unpossible in many people's minds. I also agree about the turbo info. I sandblasted a Garrett rep in OT the other day about it. It netted me a couple of new compressor map links to add to my Turbo FAQ and the promise that they aren't going to sit on them anymore.
Old 01-18-2005, 03:02 PM   #9
quazimoto
Member#: 70395
That was the "chica" right!I don't understand how they can provide better service for their customers if their customers aren't allowed to know exactly what they are getting.It would be like selling a car without gas milage and hp/tq ratings.
quazimoto is offline   Reply With Quote
Old 01-18-2005, 10:16 PM   #10
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
If it is indeed the 13T, that is the same turbo used on the BMW 525 Turbo Diesels
NWWagon is offline   Reply With Quote
FMIC w/a stock turbo, Is this okay or bad? KB'izzle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 05-14-2008 02:22 AM
wtb stock turbo blown or not grosspolluter SCIC Private Classifieds 0 04-05-2007 08:19 PM
my stock turbo is rusty as hell kenny08 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-22-2005 07:17 PM
How do you know if your stock Turbo is gone? superstud General Community 23 12-07-2004 05:07 PM
stock turbo is smoking! twlai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 06-28-2002 07:54 PM
