Old 01-17-2005, 09:32 AM   #1
root
Member#: 55854
2004 STi
Blue/silver
Default Post your Dyno Plot and Mods, see format inside.
Please post your dyno sheets along with the corresponding mods. Please do not turn this into a conversation thread as I'd like it to be a place to quickly look for dyno sheets without having to wade through 300 random posts per 1 dyno plot. Thanks all...
root is offline   Reply With Quote
Old 01-17-2005, 10:14 AM   #2
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Do it. Gather all the info and post it here.
Mattr762 is offline   Reply With Quote
Old 01-17-2005, 10:41 AM   #3
root
Member#: 55854
2004 STi
Blue/silver
Or... everyone could post their own.
Old 01-17-2005, 03:21 PM   #4
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
Default I'd would like a dyno sticky thread, here's my contribution.
At FIS last friday.
Cobb catted dp, Borla Hush cat-back, AP Stg2 map 1.20 93 octane.
Chigliakus is offline   Reply With Quote
Old 01-17-2005, 03:52 PM   #5
DrKicker
Member#: 23071
2003 WRX
Facility: FIS - http://www.fi-systems.com
Type of Dyno: Mustang
Baseline # for a stocker at the dyno: around 170
Boost: 14.5
Fuel: 93 Octane
Target AFR: Unknown
SAE Corrections: Unknown
Peak HP at RPM: 243.3 @ 6000
Peak Torque at RPM: 240.0 @ 3750
Mods: Helix up/downpipe, Cobb catback, Unichip, TXS MBC @ 14.5psi, K&N drop-in filter, GP Moto intake elbow
DrKicker is offline   Reply With Quote
Old 01-17-2005, 06:26 PM   #6
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
EDIT: Comments deleted...
DYNOS ONLY
SilverSurfer04STi is offline   Reply With Quote
Old 01-17-2005, 06:51 PM   #7
root
Member#: 55854
2004 STi
Blue/silver
Yep. Dyno only and no commentary other than setup was my idea.
Old 01-17-2005, 07:39 PM   #8
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
How about a format, so that even if the image gets deleted it will be useful. like for instance:
Facility:
Type of Dyno:
Boost:
Fuel:
Target AFR:
SAE Corrections:
Peak HP at RPM:
Peak Torque at RPM:
Mods:
mnavarro is offline   Reply With Quote
Old 01-17-2005, 09:14 PM   #9
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
What the hell might as well throw one of mine up here
Mods include-
02' Spec-C Swap
APS Pod, 3" Twin Tip Cat Back
QuickTime Header, D/P with QTEC
Turbo-XS FMIC
Modded Injectors
UTEC
FP Green
Junior Tune
VP16
Thought I should ad my pump gas sheet too
Sunoco 93
2002WRXSTi is offline   Reply With Quote
Old 01-17-2005, 10:00 PM   #10
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
VF30 turbo
STi intercooler
STi injectors
KTR Ecutek reflash
Walbro fuel pump
PDE uppipe
Bosal downpipe
Maddad 3rd Cat Eliminator
Borla Hush
Perrin short ram
Samco IC hoses
GFB pulleys
port-matched stock header
The runs were taken right after a Vishnu 3k rpm reset, hence the differences between the three runs. The ECU was freaked out by running toluene and not resetting after switching back to 93.
McBain_TP is offline   Reply With Quote
Old 01-17-2005, 10:24 PM   #11
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
Dyno Comp
dyno dynamics dyno
stock rex's put down around 150
91 octane
Mods:
perrin short ram
injen up/dp
hks cf/ti exhaust
aps bov
ecutek
WgnWheel is offline   Reply With Quote
Old 01-17-2005, 10:53 PM   #12
bgbyztoy
Member#: 49437
04 wrb STI
PE1820 turbo [email protected]
bgbyztoy is offline   Reply With Quote
Old 01-20-2005, 09:03 AM   #13
root
Member#: 55854
2004 STi
Blue/silver
bump.
Old 01-20-2005, 09:38 AM   #14
joshd
Member#: 66694
2005 WRX STi
WR Blue
Car: 05 USDM STi - about 5K miles at time of tune
Facility: TurboTrix (tuned by Shiv)
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: 240-250/240-250 awhp/awtq
Boost: peak around 19, taper to 14
Fuel: 93 octane
Target AFR: looks to be around 11.1
Peak HP at RPM: 290awhp at ~5500
Peak Torque at RPM: 315awtq at ~3700
Mods: Vishnu TBE + Ecutek reflash, nuttin else
Other notes: blue lines are with TBE only before reflash
joshd is offline   Reply With Quote
Old 01-20-2005, 10:45 AM   #15
root
Member#: 55854
2004 STi
Blue/silver
Awsome folks. Great start so for.
Please be sure to list your car year and model (and engine size if it isn't stock for the car) as well. Especially if you don't have it listed in your profile or in case you buy a new car and change your profile.
Old 01-20-2005, 11:33 AM   #16
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
Car: USDM 2004 STi with 7,000 miles
Facility: KTR Performance
Type of Dyno: Dyno Dynamics
Baseline # for a stocker at the dyno: 220-230whp/wtq (STi that is)
Boost: 22psi tapers to 17psi at redline
Fuel: 93 oct.
Target AFR: 11:5
SAE Corrections: None (Within dyno room all air pressure, humidity and air temperature are put in each run to avoid correction)
Peak HP at RPM: 337.9whp @ 5,500rpm
Peak Torque at RPM: 345wtq @ 4,900rpm
Mods:
Deadbolt SuperZilla SZ49 turbo
ECUTek KTR Dyno Tuned
TurboXS Turboback Catless Exhaust w/RFL-Ti Muffler
Power Enterprise 850cc STi Injectors
Perrin Big MAF w/intake
Perrin Lightweight Crank Pulley
Perrin Front Mount Intercooler
GT Spec Header w/ Uppipe
Tial 44mm External Wastegate w/dump to atmosphere
Walbro GSS342 Fuel Pump
Blitz SBC i-d III Boost Controller
Rick
ami2fst4u is offline   Reply With Quote
Old 01-20-2005, 02:19 PM   #17
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
mods:
vf22
utec
txs tbe
txs v1 tmic
joe-p mbc
modded stock injectors
walbro pump
"not the greatest" plugs
tuned by junior @ 20psi
max hp: 279
max tq: 268
since the dyno tune:
apexi avc-r
avo turbo inlet hose
wastegate helper spring (now holds 18psi @ redline whereas before it tapered to 15ish)
ngk one step colder copper plugs (bkr-7e)
im thinking about losing the stock intake. anybody have before/after results when adding an aftermarket intake to a stg 4 wrx?
-ed
LatentWagen is offline   Reply With Quote
Old 01-20-2005, 09:08 PM   #18
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Thread stuck, title changed.
Paul G.
paultg is offline   Reply With Quote
Old 01-20-2005, 10:40 PM   #19
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
Facility: turbotrix edison,nj
Type of Dyno: dynojet
Baseline # for a stocker at the dyno: 170-180?
Boost: 18.5 down to 16 at redline
Fuel: 93
Target AFR: rich LOL
SAE Corrections: ???
Peak HP at RPM: 284 @ 6400
Peak Torque at RPM: [email protected]
Mods: P&P vf34, hyperflow tmic, STi pinks, 3'' turboxs exhaust+stromung muffler, fuel pump, wrapped uppipe, ported exhaust manifold, perrin turbo inlet.
ECUtek tuned by Shiv
MikeWRX-NJ is offline   Reply With Quote
Old 01-20-2005, 10:53 PM   #20
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Facility: GRD Performance
Type of Dyno: Dynapack
Boost: 17psi peak. Made [email protected]
Fuel: ~98 octane
Target AFR: 11.2:1
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]? or thereabouts
Mods: EJ257 block,V8 RA heads with V7 cams, PE1818 turbo, TXS turboback with Prodrive muffler, PE650 injectors, APS fuel rails, APS DR500 FMIC, Perrin short ram. TGV deletes, Borla header. (Lower runs are without the Borla header). Blitza DSBC-R.
Remapped V8 RA ECU w/AVCS tuned by Trey Cobb.
Best 1/4 mile was a [email protected] Ran [email protected] at 8psi.
Old 01-21-2005, 01:49 PM   #21
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
TXS STG2 (TXS basemap Unichip, TXS DP, greddy EVO catback, stock uppipe) 228whp/235wtq
TypeC is offline   Reply With Quote
Old 01-24-2005, 08:52 PM   #22
HF|[S]Devil
Member#: 41522
2002 Legacy L
Deep Sapphire Pearl
2002 Subaru Legacy L
Custom cat-back stainless steel 2 and 1/2 inch exhaust with muffler, K&N air filter.
Stock more or less.
HF|[S]Devil is offline   Reply With Quote
Old 01-24-2005, 09:54 PM   #23
HighTechRedneck
Member#: 68022
04 Forester XT
Forester
04 Forester XT
Facility:FourStar Motorsports (Ecutek tuned by Mick Kehl)
Type of Dyno: DynoDynamics
Baseline # for a stocker at the dyno:215whp STI
Boost:1.2bar
Fuel:93
Target AFR:unknown
SAE Corrections:none
Peak HP at RPM:233whp @ 4900rpm
Peak Torque at RPM:267wft/lbs @ 3650
Mods:Ecutek, VF30, Ultimate-Racing catless uppipe, Bosal downpipe, stock third cat, Tanabe Hyper Medallion 3" catback, WRX ic and bov, K&N panelfilter, Samco Y pipe, Walbro 255L pump, stock injectors, stock spark plugs
HighTechRedneck is offline   Reply With Quote
Old 01-27-2005, 12:58 PM   #24
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
Facility: Tuning Technologies
Type of Dyno: DynoJet
Baseline # for a stocker at the dyno: *unknown*
Boost: peaked @ 16psi
Fuel: 91 octane (76 brand)
Target AFR: Whatever COBB claims....then look at my AFR
SAE Corrections: STD
Peak HP at RPM: ~215 @ 6,000 rpm
Peak Torque at RPM: ~226 @ 4,400 rpm
Mods: Helix uppipe, Helix catless downpipe, Borla XR-1 catback, Cobb Stage 2 Cali 91 octane map.
Drews_WRX is offline   Reply With Quote
Old 01-29-2005, 03:46 AM   #25
jarelee
Member#: 31506
05 Tacoma on TE37'
Facility: Brainstorm
Type of Dyno: DTS Dyno
Baseline # for a stocker at the dyno: Unknown - Around 165/170 whp
Boost: 15.5 psi
Fuel: 91 Octane (76 gas)
Target AFR: Unknown
Peak HP at RPM: 221 WHP
Peak Torque at RPM: 195 WTQ
Mods: HKS Uppipe, HKS Downpipe, 3" COBB Cat-Back, Blitz SBC-ID (road-tuned by myself)
Note: Car pinged alittle because it was too hot that day, so it pulled timing on one of the runs.
jarelee is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
