Old 08-08-2007, 08:01 PM   #251
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
Well I finally got around to re-tuning my STi after I added the FMIC, SPT intake and took off the Forge BPV and EWG.
Big thanks goes to XX Chris and the XXTuning facility that never lets me down. My clutch has been feeling a bit weird the last few weeks and I found out on the dyno and on the street that it was Slipping. I still made good numbers though, on one pull the car made 307whp/366wtq, then 306whp/360wtq...I left with 306whp/357wtq @20psi with clutch slip. I gained 4-5whp/8-12wtq with the fmic and the clutch slipping I hit 20psi @ 3200rpm and I don't have to worry about heat soak. Next up is a Clutch, Meth and 1 step colder plugs...I'm coming for you high 11 seconds...
Humidity that day was ~50% and temps were up at ~90* i think...
THANKS to XXCHRIS!
My Old Numbers:
The EWG held boost for about 800rpm more, but the noise got to be too much for me so I had to let my lil' ewg go...
chlnOrSlpn? is offline   Reply With Quote
Old 08-16-2007, 12:12 AM   #252
*03wRx*
Member#: 128417
2004 Fast tuned
470hp/550tq FordLightning
running vf39 17psi with sti tmic, perrin crank pulley, 565cc injectors, walbro 255lph pump, cobb sf intake, invidia uppipe, Turbo xs tbe, cobb ap v2.0
next up meth injection, 2.5 short block, pnp wrx heads, fp red, fmic, bigger injectors
*03wRx* is offline   Reply With Quote
Old 08-16-2007, 01:50 PM   #253
runvusofme
Member#: 73942
2004 WRX STi JBP
Back to mostly stock...
Daily Driver Map:
93 octane and only 18psi!!!
Engine:
Cobb Tuning Stage 2 Fully Built Block with options
Features:
Brand-new EJ25 "STI" Semi-closed Block (2.5L Displacement)
Billet Steel (4340) I-beam "Long" Connecting Rods
Forged Aluminum "3D Chamber Matched" Pistons (8.5:1 CR, customizable)
Heavy-Duty Chromoly Piston Pins
Low Friction Piston Rings
STI Forged Chromoly Crankshaft (79mm Stroke)
Computerized Balance of rotating assembly
Also Added: (Piston Thermal Coating, Upgraded Main and Rod Bearings, ARP Head Studs)
Customized Perrin GT30R Rotated Mount Turbo Kit
MAF Relocated into the fender well
Tial 44mm Wastegate plumbed back into the downpipe
APS DR725 (Stealth Black) front Mount Intercooler
Forge Type RS recirculation Bypass Valve
Perrin Oil Catch Can
Power Enterprise 850cc Injectors
Walbro 255lph Fuel Pump
Greddy Evo 2 Exhaust (with Kartboy Polyurethane Hangers)
Ecutek Engine Management Flashed by Shiv Pathak Owner of Vishnu
Vishnu XEDE custom tuned maps
18 PSI / 93 Octane
24 PSI / 110 Octane
runvusofme is offline   Reply With Quote
Old 08-18-2007, 07:39 AM   #254
The Head
Member#: 98143
04 Cayenne TT
05 SL65, 03 GSXR1000
Default Fxt
Tuned at Engine Logics in Houston, TX.
Pump is 93 octane and race gas was VP MS109.
And in case you're wondering here is the bone stock baseline for the car on the same dyno.
And here's the stock vs. current race gas compared.
Mods (2006 FXT):
# APS 70mm CAI
# AVO Turbo Inlet Hose
# Turbochargers.com 50 Trim, 8cm housing– IWG, Std. Inlet
# WBR FMIC
# TGV Deletes – porting by Engine Logics
# Stock modified WRX injectors, ~810cc
# V2 Maddad header and uppipe
# Cobb Turbo-back Exhaust with Catalytic Converter - 3" adapter to remove donut gasket
# Cobb Accessport V2 – Engine Logics Protune w/LC and FFS
# Perrin Lightweight Pulley
# Mobil 1 10w30 Synthetic Oil
# Perrin EBCS in interrupt mode
# NGK Iridium Spark Plugs (1 range colder than stock)
At my last 358whp tuning session with a TMIC, the track results were high 116mph passes in 80-90 degree temps. I'm hoping with cold weather this winter to try and trap 120mph.
The Head is offline   Reply With Quote
Old 08-18-2007, 11:07 PM   #255
TK421
Member#: 146200
2009 Supermoto
07' STi
Tuned by Tim Bailey, This is the 91 Map. Conservitive tune for safe daily driving
Mods: Titek catted downpipe, Invidia N1 catback, K&N drop in..The rest is stock
Im a lil confused because he told me i was making about 306h.p but the sheet he printed sais 278. owell car runs amazing and hauls even more a$$
+13 h.p and + 42 torque over the OTS cobb stage 2 map
TK421 is offline   Reply With Quote
Old 08-19-2007, 01:42 AM   #256
kyosho
Member#: 53079
2005 RIP 2005 WRX
236/243 CA91 Tim Bailey
Mine are similar conditions to iheartscoobys (around 100 degrees with 15-20% humidity in crappy SoCal weather).
Tuned by Tim Bailey with 91 octane and 95ish octane. i'm on 95 right now and it's freaking awesome. Of course i have to go back to 91 the next time I fill up
Cobb COTS non-CA 91 stg 2 map: 213.95 hp, 205.89 tq
Tim Bailey 91 stg 2 map: 236.45 hp, 242.52 tq
Tim Bailey 95 stg 2 map: 246.73 hp, 260.77 tq
+23 whp, +37 tq over Cobb COTS map on piss 91 CA gas
+33 whp, +55 tq over Cobb COTS 91 map on a mixture of 91CA/100
Mods (just 2, rest is completely stock):
- APS TBE R1 w/ High flow cat
- PDE uppipe
kyosho is offline   Reply With Quote
Old 08-20-2007, 12:04 PM   #257
jack klompus
Member#: 152885
2014 Malibu LTZ
05 WRX 2.0 wagon. 5MT.
Facility: P&L, Franklin park, IL. Tuned by Jorge.
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: ?
Boost: 20psi
Fuel: 93 Octane
Target AFR: Unknown
SAE Corrections: none
Tempature: 90F
Peak HP at RPM: 282.4 @ 5900
Peak Torque at RPM: 279.7 @ 3700
Mods:VF39, ebay tmic, snorkus delete elbow, drop in filter, Perrin turbo inlet, catless uppipe, APS turboback 3", sti pinks, walbro pump. Champion coppers 1 step colder.
jack klompus is offline   Reply With Quote
Old 08-20-2007, 11:27 PM   #258
flatfour562
Member#: 127254
07 STi limited
07 STi tuned by Tim Bailey
Similar conditions to iheartscoobys and kyosho
Mods- Curcial dp, maddad 3ce, Crawford cat back, and Walbro fuel pump.
Green- Cobb ots 91 octane
Blue- protuned 91 octane
Red- protuned 91 octane (full tank) with a can of Torco.
flatfour562 is offline   Reply With Quote
Old 08-23-2007, 03:10 PM   #259
KOERLONIOUS
Member#: 120129
awesome Numbers on that FXT..
KOERLONIOUS is offline   Reply With Quote
Old 08-23-2007, 08:24 PM   #260
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
Mods:
Open ECU tuned by Myself
93 Octane: Stage 1 map
K&N panel filter, Snorkus delete, Megan Headers and cat-less up-pipe, Gutted second cat. open mid-pipe.
Mr.Krinkle is offline   Reply With Quote
Old 08-29-2007, 11:21 AM   #261
SiouxBe1
Member#: 157247
1991 Legacy L+AWD BJ
Cool Old School Cool '91 Legacy BF Original Owner
Mod list as applies to Power Group;
Cobb Equal length Headers Jet Hot Coated
Hi-Flow Cat.
2 1/2" Mid-pipe
S.S. Axle Back Bosal Muffler
Delta Cams 220 grind
MSD Dis-2 Ignition
Hyper Ground System
NGK Iridium plugs
NGK Blue Silicone plug wires
JC Sports CAI w/ K&N Pod Filter
JC Sports Torque Chip
Cobb Alloy Crank Pulley
GFBits Alloy Power Steering Pulley
Exedy Light-weight Flywheel & Stage 1 Clutch
Mobil One Full Syn. Oil since break-in
Elevation: a mile above sea level Temp: 90 degrees Barometer: steady
Daily Driver with over 250,000 original miles!
SiouxBe1 is offline   Reply With Quote
Old 08-31-2007, 01:46 AM   #262
redesx
Member#: 126128
Default swweeet
swwweeetttt
redesx is offline   Reply With Quote
Old 08-31-2007, 11:03 AM   #263
06subieWRX
Member#: 116464
2006 wrx sport wgn
white
Default 06WRX VF39-19psi Cobb Tuned
[IMG]G:\AlexII\dyno.jpg[/IMG]
VF39 w STi TMIC
Cobb up pipe
HKS dp w/ Borla XR1
K&N Typhoon Intake
Cobb AP
Pro Tuned by Christian @ Cobb Tuning
295 Torque
267 HP
19psi
06subieWRX is offline   Reply With Quote
Old 08-31-2007, 11:19 AM   #264
Magman
Member#: 40038
2002 Impreza WRX
great numbers. its good that such a small list of mods makes really nice power
Magman is offline   Reply With Quote
Old 08-31-2007, 12:31 PM   #265
STIfun
Member#: 133127
1997 Toyota Supra TT
Green
2005 Wrx STi
Turbo: VF39
Mods: Intake, downpipe, full exhaust, walboro fuel pump, UTEC,
Port and Polished Crucial Headers, TIC port and coated Crosspipe, X02 upgraded TMIC
Tuner: Doug at Topspeed
Dyno Numbers: Pump 295whp and 329wtrq
Race: 324whp and 375wtrq What a difference gas can make.
STIfun is offline   Reply With Quote
Old 08-31-2007, 02:20 PM   #266
crownjewel
Member#: 112914
2007 WRX
2007 WRX
Facility: Harman Motive
Type of Dyno: Mustang
Stock with snorkus delete elbow
Boost: 12.1
Fuel: 91
Target AFR: NA
SAE Corrections: NA
Peak HP: 192
Peak Torque: 211
Mods: none
crownjewel is offline   Reply With Quote
Old 09-19-2007, 12:54 PM   #267
marrenr813
Member#: 135668
2015 WRX
Type of Dyno: Mustang Dynamometer
Baseline # for a stocker at the dyno: Unknown
Boost: 20.6 psi
Fuel: 91 Octane (Costco gas)
Target AFR: 13.1
SAE Corrections: Unknown
Peak HP at RPM: 265 AWHP @ 5850ish
Peak Torque at RPM: 298 WTQ @ 3650ish
Mods: Cobb catted downpipe, APV2, Harman Protune, 100% wingless
marrenr813 is offline   Reply With Quote
Old 09-24-2007, 02:39 AM   #268
slalom274
Member#: 29757
06 STI
2006 STi
Turbo: VF39
Mods: APS TBE, Agency power header & uppipe, nothing else.
Dyno Numbers: 93oct 300whp and 327wtrq ..At only 16 psi!
slalom274 is offline   Reply With Quote
Old 09-28-2007, 12:11 AM   #269
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
Vehicle: 2007 STI
Mods:
SPT intake
SPT Cat-back
Perrin 1 pc catted DP
Walbro fuel pump
Fuel: 93 octane
Temp: 93 degrees
Humidity: approx. 90%
Facility: Central Florida Turbo
Type: Mustang dyno
Tuner: XPT Stage 2
reddoak is offline   Reply With Quote
Old 10-01-2007, 02:56 PM   #270
Marcus K
Member#: 92274
2008 STi Aspen White
Built by GReddy
2006 STi
Tuned by Harman Motive
Mustang Dyno
Stock: 232WHP / 230 WTQ
My Stg 2: 294WHP / 320 WTQ @ 21PSI on 95 octane
Invidia G200 Cat-back
Invidia High-Flow Catted DP
Cobb AccessPort
SPT Intake
NGK Iridium 1-Step Colder Spark Plugs
Walbro 255LPH Fuel Pump
Perrin LW Crank Pulley
Marcus K is offline   Reply With Quote
Old 10-21-2007, 11:41 AM   #271
silverwerx
Member#: 81246
. .13 EVO X MR
.03 Cosworth Wrx, 14 Jeep
tuned by turbo xs. the engine is a full billet cosworth longblock with cosworth 275 cams. the turbo kit is a turbo xs gt35r kit with 1100cc injectors. on just pump gas the car made 452.9whp at 24 psi. we are changing the turbo soon and going for the mid 500's on pump gas.
silverwerx is offline   Reply With Quote
Old 10-28-2007, 08:14 PM   #272
Glenlivet
Member#: 97973
2006 STI
WRB 498whp / 468 ft lbs
Untuned at 19 psi on pump gas
Facility: PAI
Boost: 19
Fuel: 92
Target AFR:
SAE Corrections:
Peak HP at RPM: 332 @ 7000
Peak Torque at RPM: 311 @ 4500
Mods: Perrin rotated turbo kit 3071 with FMIC
Perrin 816cc Side Feed Injectors with side feed fuel rails
APEXi AVC-r Boost Controller
Perrin Equal Length Headers
Walboro 250lph Fuel Pump
JIC Ti Exhaust
Perrin Big MAF
Glenlivet is offline   Reply With Quote
Old 11-06-2007, 08:58 PM   #273
alee86
Member#: 132603
Thumbs up
Got road tuned by Ed today and I am thoroughly impressed and satisfied. My car is finally making the power I wanted from the beginning and pulls incredibly hard. Now I truly realize what "smooth turbo power" really is!
Facility: EQ Tuning
Type of Dyno: Road tune
Baseline # for a stocker at the dyno: 210-220
Boost: 20psi peak
Fuel: 91 octane
Peak HP at RPM: 268.1
Peak Torque at RPM: 323.3
Mods for 04 STi:
stock vf39 IWG
generic bellmouth dp
perrin CBE
GM 3 port boost solenoid
stock fuel pump
stock injectors
NGK one step colder plugs
I know, the torque on this is insane. Ed thought I had aftermarket headers!
alee86 is offline   Reply With Quote
Old 11-06-2007, 09:51 PM   #274
Ryanr1490
Member#: 149267
2002 6-speed wrx
psm
Facility: East Coast Swappers
Type of Dyno: Dyno jet
Baseline # for a stocker at the dyno: 170hp/180tq
Boost: 18 psi
Fuel: 93 octane
Peak HP at RPM: 251hp at 4700rpm
Peak Torque at RPM: 249tq at 5800rpm
Mods: TurboXS Up-pipe (wrapped) and Cattless TBE (downpipe wrapped), Perrin Short ram, Turbo Inlet, and Y-pipe, DEI Turbo Blanket, Aem altenator pulley, Agency Power Crank pulley, MBC.
Ryanr1490 is offline   Reply With Quote
Old 11-07-2007, 10:33 PM   #275
autowagon
Member#: 42933
03 WRX (ej257 swap
black
this is 4eat 2.5 liter wrx head with deadbolt super16g perrin tmic and full 3" exhaust with some neckdowns cobb dp for example 92 oct 4200ft (top dyno)
this is 4eat 2.5 liter with wrx head with helix 264 cams super16g perrin fmic perrin 2 cat dp and perrin dual tube exhaust 92oct sea lvlish (bottom dyno)
this is 4eat hybrid helix264 cams tdo620g perrin fmic, same as above.
autowagon is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
