Old 04-08-2008, 02:44 AM   #326
H22
Member#: 69277
05 WRX CGM
Originally Posted by H22 View Post
2005 5mt
Facility: Dyno-Comp
Type of Dyno: Dyno Dynamics Dynamometer
Baseline # for a stocker at the dyno: approx 225 whp for STi
Boost: 16 psi
Fuel: 91 oct
Peak HP at RPM: 225 whp from 5800 to 6200 RPM
Peak Torque at RPM: 225 wtq at 4600 RPM
Mods: APS u/p, Crucial Racing d/p, Crucial racing midpipe w/cat, MadDad 3" Whisper catback, Perrin crank pulley, 1 step colder plugs, Green d/i filter, Prodrive intercooler y-pipe, EcuTek, TB coolant bypass.
The red was Dyno-Comps OTS reflash with stock spark plugs.
Facility: Doug's Dynopower
Type of Dyno: Mustang
Baseline # for a stocker at the dyno: approx 150-160 whp for a WRX
Boost: 16 psi <--- only 14.2 PSI on the dyno????
Fuel: 91 oct
Peak HP at RPM: 220 whp @ 5851 RPM
Peak Torque at RPM: 219 wtq @ 4488 RPM
This is the same tune just did some pulls. I was surprised how close the two dyno's are.
On the street I hit 16-17 PSI and on the dyno only 14 PSI
Doug did not use a fan on the intercooler. He only sprayed it off with H2o between pulls. Outside temp 75 degrees.
H22 is offline   Reply With Quote
Old 04-17-2008, 09:09 PM   #327
dru_hill
Member#: 67661
2004 WRX sedan
Default P&L Motorsports stock turbo
04 WRX
Stock Turbo
Catless OEM uppipe
Cattless shorty DP and catless 3rd pipe
Stromung muffler
BPM turbo inlet
Injen CAI
Perrin IC hoses
AC Delco copper spark pulgs, brand new before tune
Cobb AP 93 oct protune by Jorge
Pimptasticlly smooth power. Look at that AF curve!! About 14.5-15psi of boost, car has 96,000 miles.
dru_hill is offline   Reply With Quote
Old 04-17-2008, 09:58 PM   #328
youthebest
Member#: 157277
07 STI
Default 07 STI Cobb STG2 MAP
07 STI
SPT Intake Heat Shield
SPT Intake
SPT DP Heat Shield
Heat wrapped TXS stealthback (w/ stock axleback)
Factory Short Throw Shifter(SPT?)
Factory Turbo Gauge
Cobb AP V2 w/ Stg 2 Map
Dyno History @Stage6 JAX,FL (1&2 done on the same day)
1. Stock map with SPT intake only
MAX WHP :189WHP
2. Cobb Stg 1 map with SPT intake only
MAX WHP : 235WHP (As shown in the picture)
3. Cobb Stg 2 map with everything installed
MAX WHP : 285.4WHP
AFR was even off the chart (below 10).
I'm waiting to get my car tuned by Doug from Topspeed.
A tuner at the shop said I should be able to get 320WHP ish~~.
youthebest is offline   Reply With Quote
Old 04-28-2008, 09:36 PM   #329
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Facility: P&L Motorsports
Type of Dyno: Dynojet
Fuel: 93 octane chicagoland pump gas
Peak HP: 297.46
Peak Torque: 282.13
Mods:
Cobb Accessport V1 - Protuned by Jorge
IHI VF43 Turbo (non ported wastegate)
STI intercooler w/ cast Y pipe
DeatschWerks 565cc injectors
Walbro 255LPH fuel pump
HKS non-flex uppipe
ERZ Catless Downpipe
WorxTuning F3 catback
K&N Typhoon short ram intake
Gimmick Motorsports silicone turbo inlet
G3Red04WRX is offline   Reply With Quote
Old 04-28-2008, 09:48 PM   #330
wrxblk02
Member#: 115303
2012 WRX
Nice...very similar to yours ^^^
Facility: Precision Tuning
Fuel: 93 octane
Peak HP: 293.46
Peak Torque: 275.26
Mods:
Cobb Accessport V1 - Protuned by John
IHI VF43 Turbo
DeatschWerks 650cc injectors
Perrin Uppipe
Helix high flow catted Downpipe
Helix catback catback
Perrin lightweight crank pulley
[IMG][/IMG]
wrxblk02 is offline   Reply With Quote
Old 05-06-2008, 11:16 PM   #331
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Edit: Double Post
4ST-AIR is offline   Reply With Quote
Old 05-06-2008, 11:17 PM   #332
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Fuel: 93 octane Mobil
Peak Boost: 20.4psi holding to 7500RPM's (conservative tune)
Peak HP: 372.39
Peak Torque: 341.22
Mods:
AXIS Stage 3 shortblock
P&L GT3076R .82AR 4" Inlet (DEI Thermal Wrapped)
P&L Custom Catless DP (DEI Thermal Wrapped)
P&L Custom Up Pipe
P&L BIG MAF CAI
P&L Motorsports 3" Signature Series Exhaust (Race/Titanium Tip)
Port matched OEM header
TiAL 44mm EWG
CP forged pistons Swaintech race coated
ACL Bearings
Modified STI Forged Crank
Modified STI Forged Rods
Subaru OEM gasket Kit
ARP head studs
Cosworth 12mm High volume oil pump
Gates High performance timing belt
High Performance Belt tensioner
Iridium one step colder spark plugs
Resurfaced heads
TGV's deleted and P&P
GM 3-Port Boost Solenoid
Walboro 255 Fuel pump
920cc FI's
Spearco 1000CFM TMIC
TurboSmart 50/50 BOV
COBB Lightened Pulley
COBB AP V2
SPT Short Shifter
Exedy Twin Disc Street Clutch
Exedy Bilet Flywheel
GroupN trans mounts
Kartboy Front & Rear shifter bushings
Old 05-16-2008, 07:18 PM   #333
jotfinoski
Member#: 173817
02 shaggin wagon
140k 315whp
this was at 19-20 psi and the numbers are corrected.
very happy with the tune.
car pulls hard even with 140k.
mad props to dan over at pruven.
Facility: Pruven Performance
Fuel: 93 octane
Peak Boost: 19.5
Peak HP: 313.6
Peak Torque: 272.5
modifications yo.
MHI td05 18g w/ upgraded flapper
DW 750s
Gimmick Inlet Tube
SSA FMIC
Forge BPV
Grimmspeed Header w/ high flow crosspipe
Invidia Downpipe
Invidia Up pipe
DC Sport Cat Back
Turbo Xs Short Ram
Hallman MBC
jotfinoski is offline   Reply With Quote
Old 05-21-2008, 07:04 PM   #334
GilMikalian
Member#: 180029
2010 STI w/BBS
Default 08 STI @ Stage 2 with Stock CBE
2008 STI
  • AP v2 Stage 2 Cali Map 91 octane (at the time I was running v1.00 of the map, I have since upgraded to v1.01 but I don't expect any appreciable difference from the earlier version)
  • Cobb catted Downpipe
  • That's it! (for power mods anyway)
The Dyno plot was on Harman Motive's Mustang Dyno. I'm also throwing in a stock 08 STI plot which was done not on my car but the same dyno about 9 weeks earlier.
My Plot:
Stock 08 STI plot (not my car, but the same dyno):
GilMikalian is offline   Reply With Quote
Old 05-28-2008, 02:07 AM   #335
Glenlivet
Member#: 97973
2006 STI
WRB 498whp / 468 ft lbs
Default Car Finally Finished
Here is the run down. Well over a year of anticipation and headache the guys at PIA fixed me up and Tim Bailey finished her up on a cold February evening. What started as a headache with ECU programing (Thanks Tim and PIA for the assistance on that.) Followed by a necked down 3" exhaust (2 spots were down to about 2.25") A new V2 access port and a new JIC exhaust. I was plesantly suprised when my fuel pump cut me off at 32psi boost. This is what i ended up with:
Had one run at 508 when fuel pump cut out but wasnt a clean run more of a spike.
Mod list is as follows:
New STI shortblock
CP Forged Pistons
Balanced STI Rods
Walboro fuel pump (i need to add another to get more HP)
ARP Head Studs
ACL Rod Bearings
JIC 3" Exhaust
Perrin FMIC
GT35 Turbo (Thanks Dude that has the nice grey sti whose name eludes me as i type this post but i think its Ryan but im probably wrong because i suck at names.)
Perrin 860cc side feed injectors with rails
Perrin Blow Through Boost Tube
Perrin SS BOV
Aquamist Methanol Injection Kit
Exceedy Twin Plate Clutch w/ lightened flywheel (Thanks Mike)
COBB Access Port V2
Perrin Equal Lenth Header
Apexi AVC-r Boost Controller (100% Tim Bailey Approved )
Perrin Catch Can
Greddy Catch Can
Cosworth oil pump
1st Ever Dave made License plate relocator.
2nd Ever Dave made faux pedal.
Big thanks again to Steve, Ryan, Mike, Dave, BJ, Tim, and all of the rest of the guys (i promise to remember everyones name next time.)
Next Mods:
Get Header Wrapped
TGV Deletes
Another Fuel Pump
Glenlivet is offline   Reply With Quote
Old 06-04-2008, 03:13 PM   #336
B.S.F.C.
Member#: 161754
2004 STi
It would be great if the following is added when members post there dyno results:
Injector Size
Base fuel pressure
Injector Duty Cycles at the time of the run.
Possible HP delivery can be fairly accurately calculated with theses figures and members can use this to check the validity of there tune or dyno results.
Example:
An 850 cc injector on a STI at 80% duty cycle and 45 PSI base fuel pressure can support 108 flywheel HP per injector or 432 flywheel HP or 432*.73 = 315 HP to the wheels.
The same 850 cc injector at 100% duty cycle and 55 PSI base fuel pressure can support 585 flywheel HP or 430 HP to the wheels but, who in there right mind will run this setup
If your tuner sudenly make 15 - 20 % more power than what the injector can support, you have to question both tuner and the accuracy of the dyno.
B.S.F.C. is offline   Reply With Quote
Old 06-13-2008, 06:30 PM   #337
toecutter
Member#: 18030
Default 2002 WRX 2.5L Hybrid
Looks like my setup is equivalent to a stock 2008 STI ( earlier post )
Mods:
2.5L STI shortblock
Deadbolt 18G Turbo
255 LH Walbro fuel pump
2007 sti 565 cc injectors
APS Large TMIC
Cobb catback
Vishnu lightened underdrive pulley
Prodrive boost solenoid
Harman Tune
toecutter is offline   Reply With Quote
Old 06-16-2008, 11:52 PM   #338
VK06WRX
Member#: 105952
2011 WRX
'11 Forester (wife's)
Car: 2007 STI
Dyno: Dynojet
Stage 2 Protune by: Jorge at P&L Motorsports
Temperature: Approximately 75?
Mods: APS 65mm CAI, Cobb TBE catted, Walbro 255 fuel pump, and GM boost celenoid.
Max HP: 293.xx
Max TQ: 330.xx
Power delivery feels perfect so far. Max boost is around 20.xx psi tapering to 15.xx by redline. I'll post a graph if I can figure out how to do it. Not totally sure how the "hosting" thing works.
VK06WRX is offline   Reply With Quote
Old 06-27-2008, 10:22 AM   #339
drkwrx
Member#: 111532
2011 WRX limited sed
2005 WRX- LIST OF ENGINE MODS SO FAR..........
-16G Deadbolt ported & polished,black & gray coated-wrapped
-Maddad D/p,whisper exhaust,headers & upipe - all wrapped-except for the exhaust
-650 deatschwerk injectors
-walbro f/p
-turbo xs FMIC
-xs shorty intake
-stock bov
-tuned very conservatively at 17lbs of boost hp294.7 & tq278.5 @ AMS by Dan-will post dyno graph later
drkwrx is offline   Reply With Quote
Old 07-05-2008, 07:09 PM   #340
evilomen76
Member#: 173809
2005 WRX
Default 2005 wrx
2005 stock WRX
Turbo xs top mount
FP 20g 7cm ported and polished
Utec
750cc injectors
walbro fuel pump
Ividia up and down pipe
Turbo xs rfl blow off
Perrin crank pulley
aem wide band
Snow performance meth 70 meth 30 water
full exhaust no cats 3inch
321 hp on 93 @ 22psi
370 hp on 93 with meth @29psi tapering to 28psi
evilomen76 is offline   Reply With Quote
Old 07-11-2008, 07:30 PM   #341
iluvdrt
Member#: 46248
82 Brat
Tan
98 Lego GT Wgn
Automatic with B&M trans cooler
Rebuilt heads
Drop in filter (air hog)
WRX cat back back
snorkus delete
TB coolant bypass
8mm wires
NGK iridium plugs
STi struts/springs
Mobile 1 fluids in everything
195000 original miles on oem bottom end
*mostly stock, no tune*
video:
iluvdrt is offline   Reply With Quote
Old 07-28-2008, 08:10 PM   #342
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
305WHP 323WTQ!!!
297WHP 319WTQ Weather Corrected!
2004 STi w/ 75000 miles on her!
AEM CAI
Megan DP
Blitz Nur Spec Catback
rek888v2 is offline   Reply With Quote
Old 07-28-2008, 08:17 PM   #343
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
^^BS, you have more done to your car than just a CAI and TB.
Louie is offline   Reply With Quote
Old 07-28-2008, 08:18 PM   #344
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Nope, you abviously have no clue what your talking about.
As one on the tuners on this car, Im insulted that you would call BS. If your tuner isnt hitting these numbers, that not my fault. Come see H&H Performance in Fayetteville NC and Me and Robbie will hook you up!
Old 07-28-2008, 08:48 PM   #345
NjSTi120
Member#: 139824
06 STi SGM *RIP*
07 Mustang 541whp 483wt
Car-06 sti
Dyno- dyno jet
Place- ICS in stamford ,ct
Turbo- vf-39
Boost- 20psi
mods are....
-invidia TBE
-cobb ap1
-K&N typhoon short ram
-Walbro 255
-Turbo XS TMIC w/perrin y-pipe
-Perrin turbo inlet
334whp 376wt
sorry for blurry letters and num's.... printer was low on ink
NjSTi120 is offline   Reply With Quote
Old 07-28-2008, 08:55 PM   #346
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Hi Im Robbie..I tuned the car. It was tuned today weather was about 93*.
The car is a simple stage 2. Tuned with Cobb. Ive tuned quite a few stage 2 sti's to 300whp/330 tq range...Its not all that hard.
and he is running a APv1
robbieshonda is offline   Reply With Quote
Old 07-28-2008, 09:16 PM   #347
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
On an 04 STi? Yeah I stand behind my opinion that either the dyno needs calibration or there are other mods other than the CAI and TB exhaust without EM. I'm sorry you feel put out by it.
And your posting someone elses numbers on here? Man thats messed up. Its not even your car?
Old 07-28-2008, 09:32 PM   #348
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Read the post Above yours.
It is his car. and he has a Cobb AP V1.
and I Tuned it.
EDIT* and the dyno was maintenanced and calibrated Friday. Stock STi's put down in the 238ish whp area. His Car was a stage2 and was making 260whp 240ish tq as a base.
Old 07-28-2008, 10:04 PM   #349
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
and I Tuned it.
Hey whatever you say dude. From what I've read from the previous 12 pages say different. But way to turn that car into a monster.
Old 07-28-2008, 10:35 PM   #350
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
If your jealous then say your jealous and if you have no real clue what your saying other than saying what others tell you to say then go for it!
BTW, who trained you to tune???
And it is my car smart guy, learn to read then post. Let the brain catch up to the garbage your spouting!!!
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
