Old 10-06-2008, 03:55 PM   #376
PA-Outback2000
Member#: 161832
2000 Outback Limited
The 1st one is the "Base Dyno" with only an intake and pulley.
The 2nd one is with the intake, pulley, and catback.
The 3rd one is the most recent, with the intake, pulley, grounding kit, header, cat, and catback.
From the Base, the 3rd graph shows a gain of 25WHP and 19TRQ. when you figure in an estimated 35% driveline loss, i get within 5HP/TRQ of the 200HP/TRQ mark.
PA-Outback2000 is offline   Reply With Quote
Old 10-06-2008, 07:33 PM   #377
RexTexWagon
Member#: 150987
2005 CGM Sniffles
AWDTuning Built WRX
Im liking the numbers Im seeing from a few vf39/43d 2.5l wrxs. Makes me excited cause thats what I want to do!
RexTexWagon is offline   Reply With Quote
Old 10-06-2008, 08:12 PM   #378
PA-Outback2000
Member#: 161832
rextexwagon... i am an N/A car, not a turbo.
Old 10-06-2008, 08:39 PM   #379
RexTexWagon
Member#: 150987
2005 CGM Sniffles
AWDTuning Built WRX
lol not yours, a few others I saw a couple pages back
Im seeing them up around the 280+ area
Old 10-06-2008, 08:56 PM   #380
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
2004 WRX wagon
SPT intake
Ebay turbo inlet hose
Ebay TMIC
Catless uppipe
Stromung divorced WG DP
Prodrive 3rd cat eliminator
Stock resonator section
Prodrive Axle-back
EJ257 Block with forged CP STi pistons
Forced Performance 8cm 18g
STi headgaskets
Stock 2004 2.0l heads
2006 WRX injectors
Walbro 255 LPH fuel pump
One step colder NGK Iridium plugs
2004 WRX transmission with Legacy GT 1-4th gears
ACT Streetlight FW
Exedy Stg 1 clutch
Tuned by Gadiel
93 Octane fuel
Eskram is offline   Reply With Quote
Old 10-07-2008, 01:53 AM   #381
stan_tichomirov
Member#: 150689
2007 Forester XT Ltd
Car: 2007 Forester XT Limited 5MT
Facility: Fine Line Imports
Type of Dyno: Mustang
Baseline # for a stocker at the dyno: stock, my car made 188whp/211wtq on same dyno
Boost: 14psi tapering off to 11psi
Fuel: 91 octane Chevron California crap
Target AFR: not sure, can ask tuner
SAE Corrections: not sure
Peak HP at RPM: 255.0 @ 6,000 RPM
Peak Torque at RPM: 255.2 @3,500 RPM
Mods: VF43, STi TMIC, STi exhaust manifolds p&p by me, GREEN panel filter, COBB catted downpipe, Prodrive 2.5" axelback, COBB v2 AP tuned by FLI.
It did make 280 wtq on the COBB VF43 map, but was boosting a bit too high. This tune is conservative and safe, and the car pulls hard.
The "Base Run" plots are my car when it was stock:
This pull was done on a different day, over-layed with the previous graph:
This was a hot run with intake temperatures of 140 degrees, over-layed with the previous graphs (intake temperature 100 degrees). It is meant to show the difference in power after soaking up some heat -- the difference isn't too dramatic, which is great:
Stan
stan_tichomirov is offline   Reply With Quote
Old 10-08-2008, 11:50 PM   #382
BEANCOUNTER
Member#: 150895
2011 WRX STi Sedan
OK, here's mine
2007STi
SPT intake, custom 3"turbo-back with Magnaflow stright through muffler
Custom tune
BEANCOUNTER is offline   Reply With Quote
Old 10-20-2008, 09:38 AM   #383
banny sti
Member#: 118815
Forged 2 litre on a standard position GT30 hybrid:
Forged and relinered 2.5 closed deck block on a standard position GT30 hybrid.
Banny
banny sti is offline   Reply With Quote
Old 10-20-2008, 10:25 AM   #384
jay25RS
Member#: 4273
2011 GR-STI
& 2013 Impreza Sport
Car: 2006 Impreza WRX 5MT
Facility: Swift Motorsports
Type of Dyno: Dyno Dynamics
Boost: 21psi tapering off to 10psi
Fuel: 93 Octane Mobil
Peak HP at RPM: 239.3 @ ~5,400 RPM
Peak Torque at RPM: 310+ @ ~3,300 RPM
Mods: CSS TMIC, Prodrive CAI, Cobb catted TBE, Koyo Aluminum radiator, Crucial Racing thermostat. Opensource tune, shocker sticker, and not amused sticker.
jay25RS is offline   Reply With Quote
Old 10-20-2008, 10:54 AM   #385
Louie
Member#: 43393
2011 STi
wow 21 tapered to 10? Thats a big drop. I thought it is usually a few psi, not a few bars.
Louie is offline   Reply With Quote
Old 10-20-2008, 10:56 AM   #386
jay25RS
Member#: 4273
2011 GR-STI
Stock TD04... Small turbo. An Evo X MR bone stock did nearly the same thing.
Old 10-20-2008, 02:24 PM   #387
Louie
Member#: 43393
2011 STi
I thought that it would hang on to 14 or 15. Sorry for acting so alarmed
Old 10-25-2008, 03:03 PM   #388
jays05
Member#: 78165
05 STI 35r + e85
tuned by Junior at The Shop.
cp pistons + rings
pauter rods
acl bearings
oem gaskets + arp head studs
heads pnp, supertech +0.5mm stainless valves, supertech valvetrain
cosworth 278/274 AVCS cams
gruppe-s uel header, custom 2.5" uppipe, custom 3" downpipe, qtp cutout, borla hush
gt35r .82ar T31 + tial 44mm ewg
pe 850s (maxed), perrin rails, dual walbros
openecu + UTEC SD + AVC-R
It made 505whp with the cutout open. On the first pull with the cutout open it was on its way to 520 and hit boost cut. With the cutout closed it made 490whp and peak tq was the same as with the cutout open. The fuel system is maxed out by 21-22psi.
jays05 is offline   Reply With Quote
Old 11-09-2008, 11:45 PM   #389
Styley1
Member#: 32566
1999 911 C2
XBL GT: Fenrick
2002 WRX Wagon
MadDad V2 Headers/Uppipe
VF39
Catted Cobb DP
STi Catback exhaust
Pink Injectors
Walbro pump
STi Intercooler
Conservative OpenECU tune for daily driver:
Tuner: DSG
Peak HP: 270@6000RPM
Peak Torque: 255@4500RPM
Styley1 is offline   Reply With Quote
Old 11-11-2008, 08:37 PM   #390
KandyWRX02
Member#: 176232
02 WRX
Kandy Apple Red
Default does this sound right?
i dont have a copy of my dyno sheet but i had my 02 wrx dynod this past spring and i thought i should have made more power. heres my mod list
momentum 40t turbo 18psi.
stock injectors modified to 660cc
perrin uppipe
helix 3" downpipe
full exhaust
perrin inlet tube
trust short ram intake
aps 50/50 bov
tgv delete
93 octane
it was tuned with the access port.
i made 251whp and 241wtq
does anyone else think these numbers are a little low? i wasnt really happy with the people who tuned my car especially because i paid $500 for maybe 2 hrs on the dyno and got one map. i just need some more opinions b4 i take it to another shop.
thanks
KandyWRX02 is offline   Reply With Quote
Old 11-11-2008, 09:10 PM   #391
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
That does not seem horrible. 18psi is not very high? Do you have any idea what your overall gains were?
Rexfan is offline   Reply With Quote
Old 11-11-2008, 09:14 PM   #392
That_Azn_Guy
Member#: 92531
2002 PSM WRX
Andrewtech/ej207
JDM S202 v7 motor (25,000 miles)
VF34 21 psi
APS TMIC
K&N Typoon
TurboXs Stealthback w/scoobysport
93 oct
That_Azn_Guy is offline   Reply With Quote
Old 11-11-2008, 09:33 PM   #393
KandyWRX02
Member#: 176232
02 WRX
Kandy Apple Red
no i mean the hp seems low to me. i wanted them to make a map for 20-21 psi and they never did. i see ppls cars on here with less mods making more hp i just dont understand
Old 11-12-2008, 01:57 AM   #394
Q2SubZero
Member#: 191717
2000 2.5RS Sedan
SRP
I'm new to the forums, and glad to join you all. Thanks to AcquaCow for my addiction to the '98 - '01 2.5RS model.
2000 2.5RS Sedan:
'04 USDM STI engine swap courtesy of GarageTuning
3" Apexi Downpipe
3" HKS Super Dragger catback exhaust
lightweight flywheel
Stock turbo
Stock 2.5RS 5spd
Full tune by Kevin @ GT
91 Octane, CA =(
WHP: 297
WTQ: 311.4
Q2SubZero is offline   Reply With Quote
Old 11-13-2008, 09:32 PM   #395
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
07 WRX RomRaider tuned Stage 2
-GReddy Ti-C CBE
-Invidia v2 DP
-STi TMIC
-93 Pump Gas
ThreeEleven is offline   Reply With Quote
Old 11-14-2008, 02:08 AM   #396
Lou DAlecy
Member#: 41099
2004 WRX
Platinum
Subaru Stars 2004 WRX, 296whp and 110,000 miles
2004 WRX, Platinum Silver
13.45 sec. ¼ mile @ 101mph ( 251 whp )
(Beaver Springs Raceway, East Coast Subaru Shootout, 2004)
2004 WRX (factory spec.)
227 hp @ 6000 rpm
217LB-FT @ 4000rpm
170 whp @ xxxx rpm
xxx ft/lbs @ xxxx rpm
2004 WRX Stg-IV (dyno tuned @ Godspeed in Novi, Mi.)
326 hp @ xxxx rpm
251 whp @ 6016 rpm (without SUS intake, Perrin pulley, Godspeed Tunnel Ram)
240 ft/lbs @ 3914 rpm
2004 WRX Stg-IV + DYNO RESULTS from 11-8-05 @ Tuning Factory
296 whp @ 6005 rpm (pump gas) approximately 384 hp at the flywheel
278.7 ft/lbs @ 3817 rpm (pump gas)
307 whp @ 6016 rpm (C-16 race gas) approximately 398 hp at the flywheel
297.6 ft/lbs @ 3892 rpm (C-16 race gas)
Turbo-XS UTEC Stg. IV+*
(Godspeed 296+whp @ 18psi)
UTEC with Remote map selector
IHI VF-34
Hyperflow TMIC
Koyo Aluminum radiator*
160* Thermostat*
Redline Water Wetter
Blitz SUS stainless air filter
Godspeed Tunnel Ram Intake (with heat shielding)
STi fuel injectors
Walbro fuel pump
NGK platinum plugs (one heat range lower)
Perrin lightweight pulley
Exedy Stage 1 clutch
ACT Streetlite Chromoly Flywheel (13.9 lbs vs. 26 lbs)
Godspeed up & down pipes (thermal wrapped)
Greddy Evo 3” cat-back, Stainless Steal
Cusco front & rear sway bars (21mm)
Cusco chassis brace
Hotchkis lowering springs f/r*
Tokico struts f/r*
Konig Drivers (16x7, satin black)
Goodyear Tripletread (225-Z50-16), Nitrogen filled
EGT gauge 52mm, Autometer (Sport-Comp)
Oil temp gauge 52mm, Autometer (Sport-Comp)
Oil pressure gauge 52mm, Autometer (Sport-Comp)
Boost gauge (PSI) 52mm, Autometer (Sport-Comp)
A-pillar dual gauge pod
Lou DAlecy is offline   Reply With Quote
Old 11-18-2008, 12:36 AM   #397
J-rad
Member#: 194623
2002 WRX Sedan
nice ride!
J-rad is offline   Reply With Quote
Old 11-18-2008, 11:29 PM   #398
Louie
Member#: 43393
2011 STi
Lou Dalcey-
how are you estimating your flywheel HP?
Old 11-24-2008, 07:22 PM   #399
lesperance4013
Member#: 195461
AWD Dyno 305 WHP
lesperance4013 is offline   Reply With Quote
Old 12-09-2008, 06:06 PM   #400
blackbandit
Member#: 183836
2006 Evolution IX
TB
Evo ix. Cams, Turbo back exhaust, intake, lower and upper intercooler pipe, intercooler upgrade, pump gas stock turbo, mbc 24.6 tapering to about 18psi by redline. Maybe a boost leak? Temps were 61 degrees humidity 64%
Note: The dotted line was my baseline. From my email flash my tuner sent me. solid line is the final results.
[IMG][/IMG]
blackbandit is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1210 09-14-2009 03:25 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain 0 11-10-2001 05:40 PM
Message Board Statistics All times are GMT -4. The time now is 11:27 AM.
