Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-24-2009, 10:42 PM   #451
The_Resonator
Member#: 75314
2005 WRX Wagon
Default My daily driver
WRX 2005 Wagon
Mods:
ACT clutch HD/street
STi VF39 turbo
GrimmSpeed Up-pipe w/ Flex Section ceramic coated
Cobb Accessport v 2.0
Invidea hi-flow catted downpipe
Invidea G200 catback system
Cobb Tuning Lightweight Main Pulley
TXS TMIC Kit
Walbro 255 Fuel Pump
Deastchwerks 650cc injectors
STi hood scoop
Iridium plugs
DEI Titanium Turbo blanket and DP wrap
Whiteline adjustable swaybars
Tuning by SS, Topspeed, ATL
The_Resonator is offline   Reply With Quote
Old 09-24-2009, 11:13 PM   #452
subaru_sti293
Member#: 167288
07 STI
FP_RED
2007 STI - 322.14whp/373.89wtq
Dyno Graph:
Tuned by NEETRONICS
This is my mod:
Cobb AP v2.
APS 65mm CAI
NGK 1-step colder plugs
DW 650cc Injectors
Warlbro 255lph Fuel Pump
Perrin Equal Length Manifold
Perrin Uppipe
HKS Hi-power Exhaust
Invidia V3 Catted DP Divorce Wastegate
ACT HDSS Clutch
ACT StreetLite Flywheel
3-Port Electronic Boost Control Solenoid thanks to grimmspeed.
JDM Lightweight Front Bumper Beam
Beatrush WRX/STi Super Light Subframe
subaru_sti293 is offline   Reply With Quote
Old 10-03-2009, 05:07 AM   #453
TheNailman
Member#: 133676
2005 WRX
2005 Subaru WRX 2.0L
64,9xx mi
VF23 Ported By Blouch
STI TMIC
STI Pinks, Flowmatched by Deatchwerks
Walbro pump
Grimmspeed phenolic intake manifold spacers
APS TGV deletes
Denso Iridium plugs
Perrin uppipe
Borla Headers
GMS turbo inlet
SPT Intake
Cobb catback
Grimmspeed EBCS
DIY Home depot grounding kit (oh yea baby)
tuned by ESP, Sterling ma.
261HP - 253TQ on a mustang dyno.
TheNailman is offline   Reply With Quote
Old 10-16-2009, 11:57 PM   #454
adamlavender
Member#: 144938
30R'd wrb
Vehicle:02 WRX
Facility:Revolutions Performance, 6500ft. elev.
Type of Dyno: Dyno Dynamics
Baseline # for a stocker at the dyno:165
Boost:20psi@4300
Fuel:E85
Target AFR:11.5
IDC:80%
SAE Corrections:1.5
Peak HP at RPM:425@5700
Peak Torque at RPM:420@4750
Mods:
06' EJ257 Short Block
ACL Bearings
Pauter Rods
Custom 9.5:1 CP Pistons
ARP head studs
04 EJ205 Heads and Valvetrain
06 STI Cams w/ avcs plugged
Cosworth Oil Baffle Plate
10mm Cosworth Blueprinted Oil Pump
ACT streetlite Flywheel
Crawford a/o seperator
Walbro 255lph
1100cc topfeed Deatchwerks
APS fuel rail
APS DR525 fmic
APS recirc BOV
Ultimate Racing Rotated Kit w/ 38mm TIAL wastegate
Garret GT3076R w/.82 hotside, Anti-surge comp cover, Aluminum Ceramic Coated both sides.
Custom short ram intake
Koyo radiator
AEM ems
MAF delete
old oil bottle secondary catch "can" with top cut out!
E85 map @20psi:
91 break-in map@15psi:
A local Dynojet reads consistantly 25+% higher.
adamlavender is offline   Reply With Quote
Old 11-14-2009, 12:15 AM   #455
Sk8er
Member#: 129045
2004 Subaru WRX Sti
Default 2004 STi (aka Electra)
Well I have an 2004 Sti with the following:
Perrin Short ram intake
Invidia Bellmouth DP and test pipe
HKS Catback Exhaust
Here is my Dyno sheet.
Green is stock map, red is tuned map. This dyno reads 15% lower, than a Dyno Jet which is more accurate. So 351.76 wtq @ 3400 and 310.70 whp @ 5500. The car is tuned to 18.5 psi of boost @ 3200 rpms and tappers down to 14 psi of boost @ 7000.
Sk8er is offline   Reply With Quote
Old 11-16-2009, 10:39 AM   #456
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
HKS Catback Exhaust
I think that your numbers are wrong or the folded up picture is wrong. It says a peak hp of 261 in red. Not any of the numbers listed.
Louie is offline   Reply With Quote
Old 11-16-2009, 11:24 PM   #457
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
supporting mods on 05 STi
dw850's
catless invidia bellmouth dp, grimmspeed port polish/ceramic coated manifold and uppipe
custom 72mm short ram intake
aps inlet
txs large topmount I/C
spec C I/C sprayer/tank
smc 100% meth injection
1 step colder ngk
walbro 255
grimmspeed ebcs
grimmspeed tgv deletes port and polished/ceramic coated and phenolic spacers[/quote]
tuned by Brad @ EngineLogics in Houston, TX
69 deg temp low humidity not sure of elevation 93 oct w/ 100% meth inj the tuning on FP green was extremely similar climate conditions 3 wks prior
this is comparison to my former FP Green w same supporting setup (blue): dom 3.0 xt-r and (red): fp green
krambte79 is offline   Reply With Quote
Old 11-17-2009, 10:17 AM   #458
idipskoalmint
Member#: 169716
2005 WRX STi
WTF Tuned
2005 WRX STi
OpenECU tuned by Dom @ MPS. Dyno'd at Moon Performance.
Mods:
Invidia Bellmouth Downpipe
Borla XR-1 Catback
Grimmspeed 38mm EWG
PnP exhaust manifold / crosspipe
APS 65mm CAI
Grimmspeed BCS
Walbro GSS342
Dyno:
idipskoalmint is offline   Reply With Quote
Old 11-18-2009, 11:30 AM   #459
HAnk_TIFC
Member#: 211098
2003 Impreza Sti
WRC blue
My GDB STi
EJ207 with HKS GT2835R
Blue line: W/ HKS Valcon
Red line: W/O HKS Valcon
HAnk
HAnk_TIFC is offline   Reply With Quote
Old 12-01-2009, 01:58 AM   #460
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
These are my old results on a very minimum setup at 4800ft with a dieing vf39(note the taper) it was smoking and not holding boost.
06 WRX
vf39
Stock airbox
Stock FP
Stock injectors
sti tmic
stock bcs
Octane:ut 91
target boost: 19.1psi
cobb tuning mustang dyno(heart breaker)
note stage two sti on this dyno are around 239-250whp/270-280wtq
06-wrx-tr is offline   Reply With Quote
Old 12-12-2009, 01:59 PM   #461
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
VEHICLE: 2003 hybrid WRX
SHOP:PIA
TUNER: MIKE
DYNO: Mustang
FUEL: 92octane
MAX WHP: 330@6200
MAX TQ: 330@4300
TARGET BOOST: 20.5psi
MODS:
New stock EJ257 shortblock
Blouch PnP 20g TD05 8cm turbo
Invida catless up/downpipe
Greddy EVO2 catback exhaust
APS 70mm CAI
Grimmspeed EBCS
Deatshwerks 750cc fuel injectors
Walbro 255 fuelpump
TurboXs big TMIC
Cobb AP V2
Protune
khyree05 is offline   Reply With Quote
Old 01-16-2010, 12:58 AM   #462
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
VEHICLE: 2002 WRX MT
SHOP: The Shop CT
TUNER: Junior
DYNO: Dyno dynamics
FUEL: 93 octane
MAX WHP: 301
MAX TQ: 270
TARGET BOOST: 16.5psi
Mod:
VF34
TXS TMIC
Pink injectors
Maddad catted downpipe
Maddad whisper catback
Grimmspeed ported exhaust manifold
Stock intake with K&N panel filter
Stock BCS
Perrin pulley
Walbro fuel pump
BPM turbo inlet
One step colder NGK iridium plugs
Slipping clutch...
Old 01-19-2010, 02:17 AM   #463
Scott_2.5TS
Member#: 163806
Facility: Rocket Rally
Type of Dyno: Dynodynamics
Boost: ~20psi
Fuel: 91 octane
Peak HP: 246 @ 6300rpm
Peak Torque: 242 @ 4000rpm
Mods:
Cobb AP V2
VF39
Sti pinks
Sti tmic
Rocket Rally uppipe
Invidia belmouth catless downpipe
Invidia G200 3" catback
APS cold air intake
1 step colder plugs
Dyno is low reading/uncorrected, stock Sti puts down ~215whp, stock WRX puts down ~160whp
Scott_2.5TS is offline   Reply With Quote
Old 01-21-2010, 04:56 AM   #464
parm
Member#: 235894
my sti has 305 hp
parm is offline   Reply With Quote
Old 01-21-2010, 07:34 AM   #465
kendostick
Member#: 179241
2004 STI
blooooooo
VEHICLE: 2004 sti
SHOP: Top Speed
TUNER: Doug
DYNO: Dynojet
FUEL: 93 octane
MAX WHP: 333
MAX TQ: 372
TARGET BOOST: 20.5 psi
go fast mods:
vf43 turbo from 2007 sti
css fmic
perrin intake
turbo xs tbe
grimmspeed bcs
grimmspeed/tial 38mm ewg
ngk one step colder plugs
walbro 255 pump
cobb v2 accessport
fyi...the car achieved these numbers in over 100 degree heat.
kendostick is offline   Reply With Quote
Old 01-23-2010, 09:03 PM   #466
woody06967
Member#: 110330
2007 STI Limited
2016 Golf R MT
Default 2007 STI Limited Stage 2 DSG Open ECU Tune
Facility: Dent Sport Garage, Matt Koestner
Boost: ~17psi
Fuel: 93 octane
Peak HP: 286 @ 5700
Peak Torque: 298 @ 3800
Mods:
Injen CAI
ESX (Spearco) TMIC
APS Downpipe
Fujitsubo RM01A
Car feels amazing, engine is very strong.
Stock STI puts down ~200hp.
woody06967 is offline   Reply With Quote
Old 01-26-2010, 12:15 AM   #467
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Originally Posted by parm View Post
my sti has 305 hp
you don't even drive an STi.
XanRules is offline   Reply With Quote
Old 01-26-2010, 05:38 PM   #468
Frankenboost
Member#: 209766
2007 STI limited
UGM - 547WHP / 471TQ
http://surgeline.cobbtuning.com/dyno...rgb2=204000000
I will try and post the actual pic later.
The strongest pull is the one on the bottom.
547whp on Surgeline's mustang dyno and 471lb/ft tq.
Quick details
E85
2000cc injectors
GT35r
Full built motor by Pacific Import Auto ( Thanks Steve, Mike, Dave, and the rest of the crew)
Custom fuel system by Surgeline tuning.
Dyno tuning by Tim Bailey.
Enjoy
Frankenboost is offline   Reply With Quote
Old 01-29-2010, 04:37 AM   #469
Tdubzord
Member#: 154872
02 WRX beast mode
SRP Bugeye
'09 WRX
Invidia divorced wastegate downpipe
Invidia n1 race
Walbro 255lph (pain in the ass to modify in these 08+)
Hallman proRX
18psi, 46*F
Tuned by Ed from EQ Tuning.
Tdubzord is offline   Reply With Quote
Old 02-03-2010, 03:11 PM   #470
trick3d
Member#: 202146
2010 evoru
GG
06 WRX 315wtq and 259whp
Mods:
Titek Catless DP
Borla Hushback
SPT Intake
Iridium 1 step colder plugs
Tune Done by HB Speed
trick3d is offline   Reply With Quote
Old 02-14-2010, 07:58 AM   #471
michaelharding
Member#: 190632
Default 1994 RS liberty/Legacy ej25 gt35
CD and sleeved ej25, kelford cams, GT35R, decent fuel.
Peak power 407.7 KW ATW
Thanks,
Mick
michaelharding is offline   Reply With Quote
Old 02-23-2010, 11:22 AM   #472
nolanator
Member#: 197677
62 Chevy Nova
800+ hp/tq on 91 octane
2002 WRX wagon (ej20)
CA 91 octane
Engine Mods:
-VF39 (PnP/ceramic coated from Grimmspeed)
-2007 STI uppipe
-Helix V2 catless downpipe
-Invidia G200 exhaust
-DW650cc injectors
-Walbro 255lph fuel pump
-Godspeed TMIC
-Perrin afta-MAF
-TurboXS shorty intake
-Grimmspeed 3port EBCS
-NGK plugs
-pro-tune via accessport
Tuning by Paul Leung at Yimi sport
target boost is at 18.5psi
nolanator is offline   Reply With Quote
Old 03-04-2010, 02:00 AM   #473
john elsbree
Member#: 161011
05 STI
05 STI
Tuned at KITO Auto Sport
Ballard, WA
Mustang Dyno
92oct
MODS
65mm APS CAI
Agency Power turbo inlet
HTA68 Turbo
Tial 44mm EWG
Kakumie Up-pipe
APS DR525 FMIC
TGV Deletes
COBB TBE exhaust
820cc fuel injectors
Walbro 255 fuel pump
Perrin light weight pulley
Results - 315AWHP 327TQ
john elsbree is offline   Reply With Quote
Old 03-26-2010, 02:01 AM   #474
dabbdc
Member#: 240135
2009 Sub Legacy GT
Default 09 Legacy GT automatic Dyno Results
Under 4k miles on car
Mods:
K&N drop-in filter
Cobb Catted DP
Stage 2 Opensource Tune
3 dyno passes
1 step colder iridium plugs
93 octane
tuned by www.shopct.com Norwalk, CT
Horsepower: 237 at 6250 rpm
Torque: 340 ft lbs at 2900
dabbdc is offline   Reply With Quote
Old 04-11-2010, 01:04 PM   #475
SCOOBY_ROO_2010
Member#: 243758
2004 SILVER STI
ROTATED PTE6262
AP Stage 2 Tuned by Tim Bailey
Perrin CAI
Invidia catted DP
AMR stealth FMIC setup {08+ STI}
SPT catback exhuast
3 port solenoid
Synapse BOV
Special thanks to PIA for the installs
SCOOBY_ROO_2010 is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1271 08-08-2014 05:58 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 11:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 03:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 03:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 06:40 PM
