Old 04-28-2011, 06:03 PM   #526
jamesw95
Member#: 270830
2008 STi
Temp: 85
Elevation: 400?
Weather: Overcast
Tires: Goodyear Eagle F1 Asymetric 245/40/18
Car: 2008 STi
Tuner: Lance and ?
Dyno: Mustang
Peak HP: [email protected]
Peak TQ: [email protected]
Target Boost: 19.5psi
Fuel: 93 octane
Mods: Invidia catted downpipe, Invidia EL Race header and uppipe, Apexi RS Evo catback, K&N panel filter, Cobb AP
Very friendly and professional staff at Cobb/Austin. The facility is top notch as well.
jamesw95 is offline   Reply With Quote
Old 04-29-2011, 01:33 AM   #527
Fighter4Hire
Member#: 244610
2002 Stage 2 WRX
Facility: R&H Garage
Type of Dyno: Mustang
Baseline # for a stocker at the dyno: Unknown - Around 165/170 whp?
Boost: 16.5 psi
Fuel: 92 Octane
Target AFR: Unknown
SAE Corrections: Unknown
Peak HP at RPM: 198.7 WHP
Peak Torque at RPM: 194.4 WTQ
Mods: Invidia Catless Downpipe, K&N Panel Filter, Dyno Tune/Open Source Tuning(by Kito)
Fighter4Hire is offline   Reply With Quote
Old 05-06-2011, 07:11 PM   #528
Bern28
Member#: 281947
WOW....Some of the power figures you guys have got,considering the low octane in you fuel is awesome
Bern28 is offline   Reply With Quote
Old 05-16-2011, 01:36 AM   #529
BronsonW
Member#: 246941
2010 315whp/335wtq
WRX 4-Door DGM
2010 Subaru WRX Sedan
Facility: 7L Autosport (Presently on NASIOC)
Stock Baseline #'s: ~190whp/ 180wtq
Boost: 22psi (1.5BAR)
Fuel: 91 Octane
Target AFR: 10.8
SAE Correction: .95
Peak HP at RPM: 296awhp @ 4,776
Peak Torque at RPM: 330awtq @ 3,760
Mods:
AVO TMIC
Custom Short Ram Intake
Invidia 3" Catless DP
Greddy Type RS
Custom Turbo Back
Tuning went well had some random bumps in the road. Tuning began with stock TMIC and we were having trouble getting the afrs where they needed to be so we did a boost leak test and found that the plastic end caps had come loose.
Intercooler got replaced by the AVO TMIC. The intake was put on at the sametime as IC. We increased boost to 22 psi and got fueling leveled out and were able to get timing advanced at low end to help with torque.We had the same problem twice while making 22 pounds. The hose that routes from the top of the BOV runs into the intake manifold came off. (Comes factory no clamp.) Car ran rich then would barely idle afrs all over the place. put a hose clamp on it haven't had a reoccurence.
That's something to look at if any of you guys plan to run higher boost if you ever encounter the problem.
Steve @ 7L Autosport did a fantastic job getting a safe, aggressive, and very powerful tune.
All parts purchased through 7L.
Thanks guys!
BronsonW is offline   Reply With Quote
Old 06-08-2011, 10:46 PM   #530
ruggerheist
Member#: 255013
2008 legacy 2.5 gt
limited
2008 Legacy GT
MODS: Tomei equal length exhaust mani w/ catless up pipe, perrin catted down pipe, HKS silent hi-power catback, K&N typhoon short ram intake
open source tuned by Andy @ R/T Tuning on Mustang Dyno
fuel: 93 octane
target boost:17.5
277.8 hp
347.8 tq
ruggerheist is offline   Reply With Quote
Old 06-26-2011, 02:07 PM   #531
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Car: 06 STI
Facility: Cobb Tuning Plano
Baseline # for a stocker at the dyno: 230whp
Boost: 15, 21, 24 (93oct) & 28 (MS109)
Fuel: 93 & MS109
Target AFR: ?
SAE Corrections: ?
Altitude: ~500', mid summer in TX
Peak HP at RPM: 499 @ 6600 RPM
Peak Torque at RPM: 468 @ 4300 RPM
Mods:
-Full Race twin scroll kit (catted dp)
-HTA gt3076r
-2 x Tial 38mm MV-S ewg's
-Mahle 100mm pistons
-Manley Rods
-Kelford 264/264 cams
-OEM valves
-BC Springs/ retainers
-Freshened heads (no PnP)
-ARP head studs
-Perrin FMIC
-Tial Q bov
-KSTech 83mm cai
-T1 Racing Development Top Feed conversion kit
-ID1000's injectors
-Walbro fp
-KSTech tgv deletes
-GrimmSpeed EBCS
-NGK 1-step colder spark plugs
-Cobb lightweight crank pulley
-Cobb Access Port v2
-ACT hd clutch
-ACT streetlight flywheel
93 octane
MS109
Dyno Video
Enjoy
armyssoldierboy is offline   Reply With Quote
Old 07-08-2011, 09:11 PM   #532
wrath1517
Member#: 193723
2002 RS STI HYBRID
UPDATED:
VF48 PORTED AND POLISHED
GRIMMSPEED V-BAND CERAMIC COATED UPIPE AND DUMP TUBE
TIAL 44 EWG
POLISHED AND PORTED, CERAMIC COATED OEM EXHAUST MANIFOLD
SHOP: TopSpeed
TUNER: Doug
DYNO: Dynojet
FUEL: 93 octane
MAX WHP: 326
MAX TQ: 364
Originally Posted by wrath1517 View Post
VEHICLE: 2002 RS with 2.5 STI Hybrid swap
SHOP: TopSpeed
TUNER: Doug
DYNO: Dynojet
FUEL: 93 octane
MAX WHP: 314
MAX TQ: 304
Mods:
5 spd conversion
STI CLUTCH AND FLYWHEEL
vf43
Big TMIC
TGV deletes
Custom CAI
Tanabe TBE
STI cams
DW750cc
IXIZ Custom Fuel Rails
NGK one step colder plugs
Walbro 255 pump
Cobb v2 accessport
wrath1517 is offline   Reply With Quote
Old 08-01-2011, 09:49 AM   #533
Bdis3
Member#: 202969
99 RS
Car: 05 STI
Facility: R/T Tuning
Boost: 25psi (93), 28psi (C16)
Fuel: 93 & VP C16
Altitude: ~360'
Peak HP: 606whp
Peak Torque: 490wtq
Mods:
Built by Satoru Speed and Fabrication
Tuned by Andy at R/T Tuning
Built engine/heads
Custom Twin Scroll FP35R turbo kit Built by Satoru in house
ID 2000's
Bosch 044
AEM EMS
Custom downpipe/dump tubes
Wire tuck
93 octane
race gas
Bdis3 is offline   Reply With Quote
Old 08-07-2011, 09:33 AM   #534
Mayobeach
Member#: 243453
2007 WRX STi
Ambient Temp: 90
Elevation: ??
Weather: Hot
Tires: Potenza RE070
Car: 2007 STi
Tuner: Tonik Motorsports
Dyno Info: Street tune
Peak HP: 308
Peak Torque: 288
Target Boost: 19
Fuel: 94
Engine/Power Modifications: K&N Typhoon Intake, GM boost Solenoid, Cobb Catted DP & Cobb Catback
Drivetrain Mods - Stock
Mayobeach is offline   Reply With Quote
Old 08-13-2011, 08:33 PM   #535
caperex09
Member#: 243122
Default before and after Process West tmic
car- 09 wrx
shop- DSG
tuner- Matt K
dyno- Dyno Dynamics
fuel- 93
weather- 50/rain
mods: invidia catted dp/q300 cb, grimspeed ebcs and aos, forge bpv, cosworth pf.
OK I really hate this , Old man< computer!
Hp- 271.5
TQ-300.
will post graph when mods update my profile ( or is it just me )
caperex09 is offline   Reply With Quote
Old 08-21-2011, 09:22 PM   #536
twistyrex
Member#: 292123
twistyrex is offline   Reply With Quote
Old 08-23-2011, 11:54 PM   #537
bestfromnw
Member#: 281835
2008 STI
1990 mk2 GLi vdub
edit, found exhaust leak... need to re-dyno
bestfromnw is offline   Reply With Quote
Old 08-27-2011, 03:52 PM   #538
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Ambient Temp: 75
Elevation: ~860'
Weather: humid
Tires: Dunlop SP600 245/40/18
Car: 2011 STI hatch
Tuner: Chris at EFILogics
Dyno Info: Mustang
Peak HP: 301
Peak Torque: 327
Target Boost: 20
Fuel: 93
Engine/Power Modifications: KS Tech 65mm CAI w/ heatshield, Perrin Silicon turbo inlet pipe, Invidia Catted DP & Invidia Q300 Catback
Drivetrain Mods - Group N motor mounts and transmission mount
jay25RS is offline   Reply With Quote
Old 09-01-2011, 07:51 PM   #539
Matt P.
Member#: 293147
Hello everyone. I'm Matt and I'm new to NASIOC. I've been around on Montreal-Subaru-Club.com and Subaruoutback.org for a while. But this is my first time posting here. Here are the specs of my 1996 STi powered Legacy.
Ambient Temp: roughly 75.
Elevation: close to sea level
Weather: dry
Tires: BFGoodrich KDW
Car: 1996 Legacy wagon
Tuner: Steph
Dyno Info: Good question!
Peak HP: 331
Peak Torque: 332
Target Boost: 22.5
Fuel: 94
Engine/Power Modifications: JDM STi v8 engine swap. Lachute Performance turbo back exhaust. EcuTek by Lachute Performance.
Drivetrain Mods - Group N motor mounts and transmission mount. Front and rear USDM STi cross members. And the list goes on!
All of it, in this:
Matt P. is offline   Reply With Quote
Old 09-03-2011, 11:22 PM   #540
CBR954
Member#: 250132
2008 WRX Silver
2008 WRX stock internals
Blouch 440xt 7cm @ 19 PSI.
750cc DW Injectors---These are helping me limit my power.
DW 300LPH pump.
E-85
Process west TMIC
Gimmic MS turbo inlet (modified to actually stay on the dam turbo) POS!! Agency power will be ordered this week.
Perrin drop in filter
Grimspeed 3 port ECBS/Turbo smart boost T ( Hybrid)
Grimspeed Up pipe
Custom oil feed line (original started leaking so the whole thing is stainless braided now).
Invidea catted DP
Turbo XS cat back The BEST sounding exhaust I have heard to date!!
Perrin Short shift and bushings.
CBR954 is offline   Reply With Quote
Old 09-07-2011, 08:59 PM   #541
Gixhost
Member#: 180111
* 2004.114.3 STi
This was done over a year and a half ago now...nothing special after browsing through this thread. Tuned at Turbo XS.
2004 STi w/TBE about 29,000 miles at the time of tune.
Gixhost is online now   Reply With Quote
Old 10-06-2011, 07:17 PM   #542
earthsscum
Member#: 231850
2016 wrx
dgm
Uploaded with ImageShack.us
earthsscum is offline   Reply With Quote
Old 10-18-2011, 09:41 AM   #543
30.pnd
Member#: 296474
Originally Posted by Bdis3 View Post
Car: 05 STI
Fuel: 93 & VP C16
Altitude: ~360'
Peak HP: 606whp
Peak Torque: 490wtq
Mods:
Built engine/heads
ID 2000's
Bosch 044
AEM EMS
Wire tuck
93 octane
race gas
very nice..
30.pnd is offline   Reply With Quote
Old 12-23-2011, 01:20 PM   #544
Motiva
Member#: 304763
2004 WRX
Rally blue
Default STi 18 psi 424 hp 449 tq Motiva tuned
2004 STi
Stock motor
Perrin FMIC
850cc side feed injectors
Walbro 255 fuel pump
AEM EMS
GT28 rotated internal gate turbo
Albuquerque New Mexico
But I cannot post an image of the dyno yet.
Motiva is offline   Reply With Quote
Old 12-27-2011, 08:56 AM   #545
OversteerAU
Member#: 93042
Ambient Temp: ~32C
Elevation: ~35m
Weather: Hot
Tires: Potenza RE050a
Car: 1990 GT Legacy Wagon
Tuner: Sean ASG
Dyno Info: Dynapack
Peak HP: 563hp
Peak Torque: 480ftlbs
Target Boost: 26psi
Fuel: 93 pump
Engine/Power Modifications:Built 2.5, CNC Heads, Jun Cams, Custom manifolds, Mod 35R 1.06
Drivetrain Mods - JDM 05 DCCD 6spd, twin plate, CroMo axels
Race fuel tune ; VP109 30psi 617hp 545ftlbs
OversteerAU is offline   Reply With Quote
Old 12-30-2011, 09:24 PM   #546
souper
Member#: 156526
Facility: BrenTuning/Kaizen Tuning
Ambient: 35F
Elevation: Sea Level
Type of Dyno: Dyno Dynamics
Baseline #: 232.4
Boost: 17.5
Fuel: 93 Octane
Target AFR: Unknown
Peak HP at RPM: 288.6 @ 5250
Peak Torque at RPM: ~335 @ 3600
Mods: Q300 Catback
souper is offline   Reply With Quote
Old 02-09-2012, 01:00 AM   #547
scotts7
Member#: 309608
2002 WRX 5DR
aspen white
Default 2002 wagon 460whp
Cosworth built EJ25
Cosworth Heads and cams 2005 build
800cc injectors
SR56
DR725 FMIC
70mm intake
APS Fuel system
255 walbro pump
FConV Pro
RA Gears
91 pump gas
scotts7 is offline   Reply With Quote
Old 02-12-2012, 09:25 PM   #548
planky90
Member#: 242587
2010 STI SE
Grey
Jtran Studios
Ambient: 65F
Baseline #: 220whp ish (stock srt10 viper 440whp)
Boost: 1.7
Fuel: 93 Octane + 50/50 meth
Target AFR: 11.6-12
Power: 506whp 419wtq
Mods
Engine Management
Cosworth EcPro
Greddy profec II Boost Controller
Innovate Digital AFR Gauge
AEM Meth Kit (1 Gallon)
Engine
Turbo
Rotated GT35r
Titanium/Ceramic Heat Shield
Short Block-
JE Forged Pistons 8.8:1 Compression
Connecting Rods - BC625+ w/ARP Custom Age 625+ Fasteners
ACL Race Bearings
ARP Head Studs
ARP Main Studs
Engine bored to 100mm
Cosworth Head Gaskets
Oil flow Cosworth Oil Pump
lightweight pulley
Balance to 8500rpm
Blue printed
Heads
Heads 3 way valve job
BC Valve Springs
BC 272 'stage 2' cams'
Supertech Black Nitrided intake valves +1mm
Supertech Inconel Exhaust valves
Misc:
Cosworth High Volume Intake Manifold
Perrin Equal Length Headers
Perrin rotated Catless Downpipe
Perrin Fuel Rails
Gruppe S Catch Can
Perrin FMIC
Custom jtran Intercooler piping anodised cosworth blue
TialBOV
Walbro 255 pump
DIY TGV deletes with ground down shafts.
two step colder plugs\
Custom Aluminium Over Flow Tank
Tsudo N1 Exhaust
Blackwork Racing Tow Hook
Transmission
Gruppe S 14lbs FLywheel
ACT XCSS Clutch
Soon to be exedy twin carbon clutch
Suspension
BC Racing BR Coilovers
SPT lower brace
SPT upper brace
GTSpec Lower Control Arms
Wheels
Rota Grids 18 x 9.5 +38 (5mm spacer on the front)
tires hancook Evo V12
Drop engineering wheel nuts
planky90 is offline   Reply With Quote
Old 02-14-2012, 01:34 PM   #549
SubCraig
Member#: 287993
2011 Impreza WRX Ltd
SS St. 2 Phatbotti tuned
http://i672.photobucket.com/albums/v...1/e07d8435.png
2011 WRX Ltd.
Perrin TBE
Process West TMIC
Phatbotti Tuned
SubCraig is offline   Reply With Quote
Old 03-06-2012, 07:45 AM   #550
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
Car: 2003 WRX Wagon with 172,xxx miles
Goals: Durability (daily driver) and as much torque as early rpm as possible (rallycross)
Tuner: Cobb Protune by Jorge
Dyno Info: Dynojet
Peak Torque: 354 @ 3000 rpm
Peak HP: 280hp @ 4500 rpm
Boost: 20psi
Fuel: 93 pump
Engine/Power Modifications: Stock 2.5, CNC 2.0 Heads, stock compression/cams, perrin up/catted down, walboro, blouch 16G, 725cc injectors, turbo back 3, Sti tmic, ebay turbo inlet, K&N CAI, Grimmspeed EBC, killer B oil pick-up and baffle
Drivetrain Mods - JDM 05 DCCD drivetrain, bushings, megan trailing arms, whiteline lateral sways, front/rear swaybars & ALK, GC control arms, Group N top hats/motor/trans mounts
Ambient Temp: unknown
Elevation: near sea level
Tires: winterforce M&S
mhoerath is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-03-2016 12:43 AM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 11:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 03:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 03:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 06:40 PM
