Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 06-13-2005, 06:28 PM   #51
Member#: 71542
2013 WRB BRZ
SilverSurfer04STi is offline   Reply With Quote
Old 06-20-2005, 09:17 AM   #52
Member#: 58323
Green = ECUTek
Red/Blue = Cobb AP Stage II
-Borla Hush CBE
-Samco Sport Ancillary Hoses
-K&N Drop in Air Filter
-APS Cast Up-Pipe
-Stromung Ceramic Coated DP
-Gutted Stock Midpipe
-ECUTek by KTR
-AMSOIL 10w30 Synthetic Oil
-Kartboy Shifter Bushings
-MRT Whiteline Rear Diff. Bushing Kit
-AMSOIL 75w90 Synthetic Gear Oil
-ROTA Tarmac II 17" Gunmetallic
-Falken ZE512 225/45/17
-McGard Spline Drive Black Lugnuts
-Tanabe GF210 Springs
-KYB AGX 4-way Adjustable Gas Shocks
-MRT Whiteline Front Strut Tower Brace
-MRT Whiteline Rear Strut Tower Brace
-MRT Whiteline Steering Rack Bushings
-MRT Front & Rear Alloy Endlinks
-AXXIS Ultimate Brake Pads
-Stoptech Stainless Steel Brake Lines
-Stoptech Slotted Rotors Front & Rear
-Perrin Rear Adjustable Sway Bar
-Perrin Rear Hardened Sway Bar Mounts
-MOMO Aluminum/Leather Shift Knob
-Aluminum Dead Pedal
-Aluminum Gauge Bezel
-Blitz DTT & Boost Gauge
-2004 WRX Front Seats
-Escort Passport 8500 Hardwired Radar Detector
-Painted Stock Headlights & Silverstars
-PIAA Extreme White H3 Fogs
-CWest Version 1 Grille
-STI Hood Scoop
-Genuine Subaru/EGR Front Lip
-Genuine Subaru OEM Rear Under Spoiler
-WRX Splitter
gusto is offline   Reply With Quote
Old 06-20-2005, 09:59 AM   #53
Member#: 35313
Spry Forester
Silver Spark
Mustang Dynomometer
261.7 HP @ 6,250 rpm
254.4 HP @ 4,750 rpm
Stock STi's typically 220hp on a Mustang from what I've read.
K&N Typhoon Short Ram
Perrin Turbo Inlet Hose
TXS RFL-Ti TBE (w/cat)
Perrin Pulley
Ambient temps about 70F, Elevation 975ft ASL (edited)
crystalhelix is offline   Reply With Quote
Old 06-21-2005, 09:46 AM   #54
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
Tuned at turbo XS
Shell v-power 93 octane
mobil 1 with lucas oil teatment engine and tranny
helix top mount
STI pinks
wahlbro 255 fp
thermo tech wrapped borla header
ERZ racing up down pipe both wrapped
blitz nur-spec catback
Perrin turbo inlet hose
AEM alternator pulley
ebay grounding kit
pivot voltage stabilizer
crucial racing 160 thermo stat
one step colder copper plugs
I thinks thats about it
boost4life is offline   Reply With Quote
Old 06-21-2005, 11:31 AM   #55
Member#: 69005
'04 4EAT Wgn
Cool My 4EAT with UP/DP/Y-hose/91 CA gas
Mods are listed on the graph.
With the fact that there are more loss between crank and wheel, via A/T gearbox vs M/T gearbox, and I retained the stock catback (for silent and stealthy), the results are still good.
dcwrx2 is offline   Reply With Quote
Old 06-28-2005, 06:58 PM   #56
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
aps cai, gpmoto maf elbow, perrin inlet, deadbolt td06-20g oil/water int w/g, perrin TMIC, utec, pe 850's ballanced at rc engineering, walbro pump, helix catted dp, borla 3" catback. jedi catchcan replumb w/throttlebody dump delete. coolant throttlebody delete.....mudflaps
after addressing some heat issues, i hope to het a tinch more peak power..
this was on a mustang.
stock sti will put down ~220.
Boost: 20
Fuel: ~95
it was hot as hell.. i think on the way home i saw 91 deg.. in the dyno room it had to be more than that... and it was crazy humid...
DISCOPOPE is offline   Reply With Quote
Old 07-06-2005, 06:15 PM   #57
Member#: 85083
2015 WRX Premium
World Rally Blue Pearl
2004 WRX wagon
ERZ flex uppipe
I need to go back for a dyno run as I have since been retuned with a gutted stock DP, and 2.5" stromung cat-back. Hoping to put down 200.
mcdrama is offline   Reply With Quote
Old 07-06-2005, 06:33 PM   #58
Member#: 5810
2001 S366 2.5RS
All Wheel Dyno
Lakewood NJ
01 2.5RS with 113k on the ticker
Apexi cat-back
Cobb intake
Borla header
UR crank pulley
ACT clutch
Exedy flywheel
ZEX 65shot
obviously before and after N2O runs
sidewayz is offline   Reply With Quote
Old 07-18-2005, 09:20 PM   #59
Member#: 73361
'03 PSM Wagon
V9 EJ207/6MT, Dom 3.0XT-R
Facility: TopSpeed
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: 175 hp
Air Temp: 90 deg.
Boost: 18 psi peak
Fuel: 93 Octane
Target AFR: Unknown
SAE Corrections: Unknown
Peak HP at RPM: 274.93 @ 6600
Peak Torque at RPM: 263.97 @ 4600
Mods: 02 WRX Engine, VF-39, Blitz 550's, STI fuel pump, UTEC tuned by TopSpeed, Helix Uppipe and Downpipe, Tanabe SRM Catback, Lightened crank pulley, no a/c, Samco turbo outlet and intercooler hoses
Dyno Chart can be seen here:
andrewp724 is offline   Reply With Quote
Old 07-18-2005, 09:27 PM   #60
Member#: 9090
09 Forester Gump
Interesting comments... I have never seen a dyno plot that talks to the crowd before.
V6TurboTA is offline   Reply With Quote
Old 07-18-2005, 10:51 PM   #61
Member#: 81185
05 STi White/TA
GT30R .63
Subaru Stars
ST1Ddope is offline   Reply With Quote
Old 07-19-2005, 12:46 AM   #62
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
mine was an autograph!!
ImprezaRSX is offline   Reply With Quote
Old 07-20-2005, 02:00 PM   #63
Member#: 66558
Facility: TDC Tuning (Concord,NH)
Type of Dyno: Land and Sea
Baseline # for a stocker at the dyno: 170hp
Boost:15psi (Very hot day, wouldn’t hit target)
Fuel: 93oct/108oct
Target AFR: Unsure - Looks like about 11.8 tapering to 11.1
SAE Corrections: (Edit) SAE
Mods: 04’ wrx Stage2 … PDE Flex UP/TXS TBE/Cobb AP
Dyno Plots: AP Stage 2 v.1.30/Protuned 93oct/Protuned 108oct
pezman04wrx is offline   Reply With Quote
Old 07-21-2005, 05:39 PM   #64
Member#: 4507
05 STI
Aspen White- No wing
2005 STI, Matrix Mustang dyno in Portland, tuned by PDXTuning:
[email protected], [email protected], 92 octane
FP Green, 7cm
Perrin modified injectors
Perrin FMIC
Perrin big maf
Aquamist 2d, 50/50 methanol/water
No scanner so no actual dyno plot.
paulw is offline   Reply With Quote
Old 07-31-2005, 11:43 AM   #65
Member#: 91560
2012 STi Hatch
[IMG]brett and candice 009[/IMG]
boostinscooby is offline   Reply With Quote
Old 07-31-2005, 09:40 PM   #66
Member#: 52369
2005 WRX STi
430awhp, 416awtq
2005 STi
Ultimate Racing Stage 3 STi kit
UR Fuel Kit w/900cc injectors
430awhp and 416awtq on 93 octane.
fireguyrick is offline   Reply With Quote
Old 08-02-2005, 12:42 PM   #67
Mr. Sedan
Member#: 68862
'11 Jeep Wrangler
260awhp/260awtq @ 15psi
ECUtek...tuned by "Tony the Tuner" (They're Grrrrrrrreat!) at XX-Tuning
Walboro 255lph fuel pump
GREEN drop in air filter
HELIX Exhaust
Mr. Sedan is offline   Reply With Quote
Old 08-02-2005, 12:51 PM   #68
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
230whp 237whtq on a Dyno Jet
-ap stg2
-helix up/dp
-borla hush with 3inch adapter(no donut flange)
-removed muffler
Swine is offline   Reply With Quote
Old 08-07-2005, 08:46 PM   #69
Member#: 89675
2005 WRX Sti
The 100 Octane map is more of a 95 mix
91 Map is running 19 PSI
the 100 maps are around 21 PSI
AP protuned stage 2
APS 3" Turbo Back
[email protected] Typoon
Silver2005Sti is offline   Reply With Quote
Old 08-08-2005, 02:50 AM   #70
Member#: 67638
2002 Stage 2 WRX
Midnight Black Pearl
Facility: Full Function
Baseline # for a stocker at the dyno: 165 whp for wrx/ 220whp for stock Sti
Air Temp: at least 90 deg. after driving for an hour in traffic
Fuel: Cali 91 Octane
Peak HP at RPM: 218.1 @ 6000
Peak Torque at RPM: 215.6 @ 4500
-EcuTek Reflash/Tune By Shiv
-Borla Headers
-Borla Catback
-Perrin Up-pipe
-Perrin Downpipe
-Perrin Crank Pulley
-Stock Air Filter
-STi Intercooler
-Intake silencer removed w/fender plug
-Samco Radiator Hoses
-Samco Coolant Hose Kit
-Lineage Grounding Kit
-Rota 17x8 Hyperblack Torque's
-Perrin Front & Rear Endlinks
-Perrin Front & Rear Adjustable Swaybars
-Whiteline Rear Differential Bushings
-Whiteline Steering Rack Bushings
-Brembo cross-drilled/slotted rotors
Extra Bling
-Sti Hood Scoop,-Zerosports Scoop Splitter,-WRX Front plate replacement,-Apexi turbo timer,-Carbon Fiber Shifter Trim,-Carbon Fiber interior,-Titanium Shiftknob & E-brake,-Radiator Shroud,-Morette Headlights,-Billete grill,-Sti replica Mesh Foglight covers,-Zerosport CF Sidemarkers,-Black Lamin-X Tail light tint,-Mattjk screen w/DVD player.
siperwrx is offline   Reply With Quote
Old 08-08-2005, 12:57 PM   #71
Member#: 60741
05 STI
SQC #156
nm...neone wanna host my dyno sheets. Shoot me a PM.
04blkbeauty is offline   Reply With Quote
Old 08-12-2005, 09:58 AM   #72
Member#: 66558
Not mine, but the owner will chime in I'm sure ... Nice set-up man ...
Edited for clarification ... These are Tino's plots ...
Old 08-12-2005, 10:10 AM   #73
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
thanks mate:
Heres my brief list:
Australian spec 2004 sti 2.0ltr
FPgreen 7cm internally gated
Perrin FMIC
ecutek type 3
X-force titanium catback
sti pink injectors
perrin intake
Hmm thats about all. first graph dynoed in 4th gear. second graph dynoed in 5th gear
tino is offline   Reply With Quote
Old 08-13-2005, 08:34 PM   #74
Member#: 37558
2003 TS wagon
JDM bukkake white
302whp/285wtq on a Dynojet
-JDM version 7 motor and ECU
-STi 565cc pinks
-Perrin fuel rails
-Perrin short ram/inlet
-Helix flex UP
-Perrin catless DP
-Bosal catless back
-Boost Cooler methanol injection
-GReddy Profec B spec2 EBC set at 18 psi
Kreeger is offline   Reply With Quote
Old 08-27-2005, 03:57 PM   #75
Member#: 44380
Default 405whp, 309.6wtq on pump gas
I finally got my car on the dyno. We're making good power @ 23psi, but we still have get to get the AVCS system functioning with the AEM EMS. Expect to see our race gas numbers soon.
Exxon 93 octane
• JDM Subaru STi RA Spec-C Version 7 engine
• Reversed and Samco blue powder-coated intake manifold
• AC removal and alternator relocation
• JDM STi 6-speed driveline swap (trans, axles, hubs, prop-shaft, diff)
• RPS Street Max Pro clutch
• Custom Agile SC 61 turbo kit
• Custom Agile front mount intercooler with Perrin core
• Custom Agile polished intercooler piping
• AEM Engine Management System
• Perrin fuel rails
• Power Enterprises 800cc injectors
• Twin Walbro 255 liter per hour fuel pumps
• Braided stainless fuel lines
• Russell in-line fuel filter
• SX fuel pressure regulator
• PWR radiator
• Perrin radiator shroud
• Samco radiator hoses
• Flex-a-lite oil cooler with custom oil lines
• Turbosmart Megasonic blow-off valve
• Turbosmart 38mm Ultragate wastegate
• Custom Agile intake with HKS Megaflow filter
• Custom carbon fiber air box & carbon fiber washer bottle cover
• Optima Red Top battery relocated to trunk
• Unorthodox light weight pulley kit (2 piece—not crank pulley)
Agile Automotive Performance
ps vendor status starting in Sept, 2005
SooobieSnack is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
