Old 11-11-2005, 07:27 PM   #101
culmination
Member#: 57065
2004 GT35R STi
mods:
kingpin GT35R 1.06 exh
turboxs FMIC
turboxs UTEC
850cc injectors
walbro fuel pump
APS 3" catback exhaust
HKS SSQ BOV
NGK 1 step colder plugs
Perrin Crank Pulley
AEM ALT pulley
Halman's boost controller
K&N intake with blow through MAF
91oct tune at 21 PSI
culmination is offline   Reply With Quote
Old 11-11-2005, 08:01 PM   #102
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Originally Posted by jalow72
On which Dyno? Personally I think dynos numbers are very much relative and a necessary evil for tuning. I do not try to speculate what one will do over another. One purpose of the post was informational for those who wish to research specific modifications. The other reason why I posted was to illustrate the difference in torque between the 2.0l and the 2.5l engine.
Across the board... the Subaru loses 20% of "flywheel" horsepower through the drivetrain. It is an undisputable proven FACT. Those are great numbers, and I was actually doing you a favor by calculating them for you.
Lighten up.
Kreeger is offline   Reply With Quote
Old 11-11-2005, 08:52 PM   #103
jalow72
Member#: 64293
I am surrounded
by land manatees!
jalow72 is offline   Reply With Quote
Old 11-11-2005, 09:46 PM   #104
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
unkadave is offline   Reply With Quote
Old 11-12-2005, 12:10 AM   #105
C43
Member#: 95586
2004 AquaMist Inject
PSM Deadbolt 361WHP SZ49
Xoticmotorsports
Dynojet
Max WHP- [email protected]
Max [email protected]
Mods- 04 STI 255FP, HELIX HFC DP AND UPIPE, BORLA CBE, TURBOXS FMIC, PERRIN BIG MAF,
PERRIN FUEL RAILS, APEXI EBC, DEADBOLT SZ49, 850CC INJECTORS,Ecutek tuned by [email protected] 361WHP Sorry about the caps but it was a paste
C43 is offline   Reply With Quote
Old 11-12-2005, 09:46 AM   #106
WickedRydaX
Member#: 31900
Originally Posted by root
Please do not turn this into a conversation thread.
Thanks all...
From 1st post
MCL
WickedRydaX is offline   Reply With Quote
Old 11-12-2005, 12:24 PM   #107
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
TopSpeed tune - 93 octane
23psi peak boost
meth injection turns on at 18psi
TopSpeed ECU reflash
Deadbolt TD06H-20G (Zilla)
Cobb catless TBE
GTSpec II header/uppipe
Perrin FMIC
Perrin Big MAF intake
Perrin turbo inlet hose
Perrin modified 816cc injectors
Walbro 255 lph fuel pump
Custom modified stock blow off valve
SMC methanol injection kit using VP Racing pure methanol
One step colder spark plugs
SilverSurfer04STi is offline   Reply With Quote
Old 11-14-2005, 02:36 PM   #108
Owenator
Member#: 53034
2007 OBP stealth STI
COBBStg2.WRXwing.fogLites
Green is the with Agile ProTune, Red is with the Cobb "standard" VF30 map.
Setup:
Cobb Tuning AccessPort - ProTuned by Agile Automotive
Cobb SF intake
Stock TMIC
IHI VF30 Turbo & STI Injectors
Walboro 255 lph fuel Pump
Gutted up pipe
Cobb Tuning catted downpipe
Borla Hush catback exhaust
Spec lightweight flywheel
Spec Stage 2 Clutch (Kevlar disk + Stg 1 press. plate)
STi V6 RA Trans
Redline 75W90NS gear oil in trans & diff
O
Owenator is offline   Reply With Quote
Old 11-20-2005, 05:20 PM   #109
HalfBaked
Member#: 24759
2004 Volvo S40
Purplish-Blue-Purple
1992 nissan sentra se-r.
Mods:
sr20det swap from an avenir (t25 turbo)
3in vrs downpipe
3in jgy test pipe and catback
blitz intake
tougefactory 650cc injectors
nismo fpr
johnny racecar fmic
greddy profec-b
spec stage III clutch
greddy e-manage
Running 18lbs spiking dropping to 15lbs and holding at redline.
HalfBaked is offline   Reply With Quote
Old 11-22-2005, 09:26 PM   #110
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
04 STI
Stock STI ej25
Stock TMIC
VF22
Perrin short Ram
PE 850cc Injectors
Walbro 255LPH Fuel Pump
GT-Spec Header w/ Up-pipe
Turbo XS TBE 4"down pipe-3"mid pipe w/ cat-2.5" silencer
UTEC w/ Map Selector Tuned by Tony @ XX Tuning
Perrin Oil Catch Can
Stock Clutch
Stock Axles
I can't upload the dyno sheet, here are the #'s
289.7WHP @ 5175RPM
362.2WTQ @ 3180RPM
Defiantspaz is offline   Reply With Quote
Old 11-22-2005, 10:05 PM   #111
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Very nice, Defiantspaz. I'd say leave it there. Extra whp form there will cost you ten X's as much. Not including things that break.
Old 11-26-2005, 10:41 PM   #112
Gethin
Member#: 2998
TurboXS UTEC rev 4 firmware 5.0
DIY tuning
modified stage 2 map, less fuel, bit more timing, weak boost map
stage 1-3 parameters
boost gain 48 instead of 50
ABC opened 1 full turn
WGS setting 6psi instead of 0psi
Helix catless uppipe
Helix bellmouth catless downpipe
Maddad centre
Prodrive muffler
K&N panel filter
Perrin IC hoses
UTEC logs show I can increase the boost quite a bit, only hitting between 13 and 15 psi max.
Gethin is offline   Reply With Quote
Old 11-26-2005, 11:03 PM   #113
kedrin
Member#: 48380
Originally Posted by Defiantspaz
04 STI
Stock STI ej25
Stock TMIC
VF22
Perrin short Ram
PE 850cc Injectors
Stock Clutch
Stock Axles
289.7WHP @ 5175RPM
362.2WTQ @ 3180RPM
now that has to have some great curves on that chart...
kedrin is offline   Reply With Quote
Old 11-29-2005, 04:49 PM   #114
antrey
Member#: 87454
2005 SAAB 9-2X Aero
Facility: Flat farm road in El Paso, TX at approx. 3,750 feet elevation
Type of Dyno: DIY Dynamic Dyno, http://www.dynamic-dyno.com
Baseline # for a stocker at the dyno: [email protected], [email protected]
Boost: 16.1
Fuel: 91Octane plus Outlaw Octane Booster
Target AFR: 10.8
SAE Corrections: SAE J1349 air temp and humidity corrections, no elevation correction
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]
Mods: Gutted Up-pipe, UTEC Stage 1 with 4.2 firmware, TXS Tuner
Excel graph below shows AFR, Boost PSI, and Load Site. The Boost and AFR have been multiplied by 10 to view at a similar scale as the HP and Torq:
9-2x project car web page: http://9-2x.dynamic-dyno.com
antrey is offline   Reply With Quote
Old 11-29-2005, 06:08 PM   #115
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
I just got done doing an upgrade. All mods were done at XX Tuning in Hartford, CT and installed by Al. Tuning done by Tony.
Mod list:
APS SR55
APS 65mm CAI
APS DR725 FMIC
APS 3.5" exhaust, really loud!
XX Tuning Fuel Rail Kit
PE 850cc Injectors
UTEC w/ map selector tuned by Tony @ XX Tuning
One Step Colder Plugs
STI Hardened Motor Mounts
STI Hardened Transmission Mount
Exedy Stage 2 Cerametalic Clutch
Driveshaft Shop Rear Axles
Perrrin Oil Catch Can
I still can't figure out how to post attachments. If I can E-mail them to some one so they can post them, please PM me.
Low boost 17 PSI= 351WHP,338WTQ on 93 octane fuel.
high boost 21 PSI= 386WHP,387WTQ on 93 octane fuel.
Race map in the future, will post when tuned.
Old 11-29-2005, 08:22 PM   #116
antrey
Member#: 87454
2005 SAAB 9-2X Aero
Picture posting tutorial:
http://forums.nasioc.com/forums/show...hreadid=110137
If you're picture is not being hosted on another website you are currently out of luck. Attachments cannot be directly inserted into your posts.
Old 11-30-2005, 06:12 AM   #117
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
I was hoping someone could make a post and include the sheets there, I didn't think they could be inserted it to my post.
I have my dyno sheets posted on Tunernetwork.com under "Got My Numbers".
Defiantspaz there aswell.
Old 11-30-2005, 06:28 PM   #118
krees23
Member#: 95154
2005 Subaru WRX STi
Good thread - subscribing
krees23 is offline   Reply With Quote
Old 11-30-2005, 06:45 PM   #119
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
Thank for the tutorial.
Old 12-05-2005, 01:03 PM   #120
brcewane
Member#: 63990
Flat Grey
02 WRX
- Stock WRX Heads
- Deadbolt TD05-16G (regular one no p&p)
- USDM 2.5L Sti shortblock
- Act Street Clutch with upgraded pressure plate
- STi Pink 565cc injectors
- Walbro 255lph pump
- SSAutochrome FMIC
- Grounding kit
- TBE (one cat)
- Up-pipe
- shorty intake with K&N cone filter
- EcuTek tune on 94 octane
270 whp
300 wtq
Clayton Load based Dyno @ 19psi
Don't have the print out as the printing software was on the fritz. Injectors at 75% duty cycle. My problem was in the high end of the tune... the stock Wrx Heads/headers were restricting my top end HP... Could have turned up more boost for more power but it exagerated the power drop off in high RPM's
Wasn't looking for peak HP but more wanted the HP to stay around longer at higher RPM's.
Maybe a header would help out in the top-end
brcewane is offline   Reply With Quote
Old 12-05-2005, 01:07 PM   #121
005sti
Member#: 78293
DP stockcatbckpro-
tune301wtq 289.7whp 93oct
005sti is offline   Reply With Quote
Old 12-05-2005, 02:00 PM   #122
norris639
Member#: 93489
2004 WRB STi
DR65'd 415whp
Default Update
norris639 is offline   Reply With Quote
Old 12-06-2005, 10:19 AM   #123
MDBlackWRX
Member#: 93579
... Retired.
12/7/05 Is when the suby gets on the Chopping block! Heres whats goin in:
IHI VF30
Modified Stock injectors
Walbro Fuel Pump
New Plugs
HKS Catch can
Turbo XS Dynotune!
***Numbers will be up soon***
Right now with stock Turbo
ACT Clutch
ACT Prolight Flywheel
Greddy FMIC
Turbo XS UTEC
Turbo XS MBC
Turbo XS Shorty intake
Perrin Pulleys
HKS Downpipe
Perrin Exhaust
the list goes on...
((((247.5 AWHP)))) Lookin for 300!
MDBlackWRX is offline   Reply With Quote
Old 12-08-2005, 11:43 PM   #124
MDBlackWRX
Member#: 93579
... Retired.
281.1 awhp
274 tq
VF30 @18psi 111mph on 93 octane
Im happy with it.
Old 12-12-2005, 12:45 AM   #125
MDBlackWRX
Member#: 93579
... Retired.
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
