Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 12-13-2005, 08:20 AM   #126
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
Big_Hitter is offline   Reply With Quote
Old 12-14-2005, 05:06 AM   #127
Member#: 47145
2012 Gas Saver
Mods that matter:
- TurboXS UTEC (professionally tuned by Jorge @ P&L Motorsports)
- TurboXS Hyperflow TMIC
- TurboXS Magnaflow Catless Turboback Exhaust
- BPM XVR crossover pipe with port-matched & ceramic coated stock exhaust manifold, services supplied though Crucial Racing
- Crucial Racing Uppipe
- Crucial Racing 160deg T-stat
- Ultimate Racing 785cc/min Cylinder Flow Matched Injectors
- Deadbolt Zilla TD05H-20G (ceramic coated)
- CoolingMist 150PSI Alky Injection (UTEC activated, 50/50 Meth/Water)
- GMC Syclone Boost Solenoid
- Perrin Turbo Inlet Hose
- Walbro Fuel Pump 255lph
- XS Engineering CAI
- Mr. Josh's Lightened Crank Pulley
- APS DualVent BPV
- DIY Stainless Steel Hi temp painted & thermal barrier covered Turbo/Downpipe Heatshield
(93 pump + 50/50 Meth/water injection @ 21psi) VS. (93 pump, NO meth @ 23psi)
testes1010 is offline   Reply With Quote
Old 12-16-2005, 12:01 AM   #128
Member#: 87454
2005 SAAB 9-2X Aero
Facility: Flat farm road in El Paso, TX at approx. 3,750 feet elevation
Type of Dyno: DIY Dynamic Dyno, http://www.dynamic-dyno.com
Baseline # for a stocker at the dyno: [email protected], [email protected]
Boost: 16.5
Fuel: 91Octane plus Outlaw Octane Booster
Target AFR: 10.8-11.0
SAE Corrections: SAE J1349 air temp and humidity corrections, no elevation correction
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]
Mods: Gutted Up-pipe, UTEC Stage 1 with 5.0 firmware, TXS Tuner
AFR, Boost, Timing, and Load Site during Run:
9-2x project car webpage: http://9-2x.dynamic-dyno.com
antrey is offline   Reply With Quote
Old 12-20-2005, 10:42 PM   #129
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
Default 04 STi stock Turbo with alky
Facility: Extreme Motorsports (Odenton MD)
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: UNK
Fuel: 93 Octane pump
Target AFR:
SAE Corrections:
Peak HP at RPM: 292.47 @ 5600
Peak Torque at RPM: 314.63 @ 3700
Helix catted DP
Deleted snorkus
Cobb AP
SMC injection
Protune by RiftsWRX
2 plots, one with 93 octane only, one with 93 octane and 50/50 methanol/water injection.
STI_FFY is offline   Reply With Quote
Old 12-28-2005, 04:23 AM   #130
Member#: 103324
1992 Opel Astra GSTi
Ford RS Blue
Opel Astra 1992 2.0 turbo Phase 3
Boost: 1,15 bar - 16,68 PSI
Runs at 98 octane
315 hp
475 nm tq
Caveman1 is offline   Reply With Quote
Old 01-04-2006, 12:25 PM   #131
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Just tuned MY05 STi w/ turboXS Utec on 93 and 104 oct
tunning props to (Dan @ EngineLogics.com in Houston, TX)
mod list: megan racing exhaust all the way headers + uppipe, down pipe and cat back, injen cold air intake.
stock turbo, injectors and pump
heres a pic of the dyno chart before and after utec install w/ 93 oct tune ~30 ft/lbs of torque inc and ~ 10 hp inc boost at ~17 psi
~280 hp to ~290hp at the wheels and inc to ~287 ft/lbs of torque
krambte79 is offline   Reply With Quote
Old 01-06-2006, 08:15 PM   #132
Member#: 18987
2014 Forester
Dark Grey Metallic
Default Water Injection tunes
2004 Subaru WRX at XXtuning Dynapack
Anyway, the dyno plot below also shows the gain over the baseline pump gas tune without water/meth. Running on a 175cc nozzle. I also found out after that tune that my alky supply line was cracked and leaking during tuning. So we used less that optimum pressure for this tune.
175cc nozzle with cracked line tune, faint line is without water inject, darker line is with.
So here is the improvement with the 325 nozzle and nothing else added as far as bolt ons, only added a wastegate divorce pipe to my HKS downpipe.
Here is AFR/Boost
Here are the mods.
2004 WRX
Stock 2.0L internal wise
HKS downpipe
VF-22 turbo, not ported or clipped
TurboXS uppipe
Ceramic coated stock header
Perrin Short ram
Snow Performance stg. 2 Boost cooler water injection system using 325 nozzle. ( I am thinking of the pump upgrade also, I want more injection pressure), Running a 50/50 mix methanol/distilled water, or Denatured alky/water
Stromung Cat back twin tip. Exhaust has no cats what so ever.
Walbro 255 fuel pump
PE-650 injectors
Granted we used very high boost for this tune on the dyno, and did road tune after with the boost turned down a little, because I wanted to feel what it was like. Man was it fast. So I am now back to running 20 lbs of boost in 3rd, and about 21-22 in fourth, and maybe around 23 in fifth. But I am not doing this for sustained periods.
DonkeyPunch is offline   Reply With Quote
Old 01-06-2006, 08:51 PM   #133
sonic rx
Member#: 33457
Chapter/Region: PRSIC
here is a dyno ploy of my tune by tuan over at grd performance . this is on winter gas 93 oct. and 20 psi max since i did not copy in color it was a hair under 325 awhp and a little over 300 awtq. i darkend the lines a little as i had to shrink the pic.
sonic rx is offline   Reply With Quote
Old 01-10-2006, 01:48 PM   #134
Member#: 40038
2002 Impreza WRX
Default my 2002 wrx dyno
Facility: Modern Garage SLC, Utah
Type of Dyno:Mustang Dyno
Baseline # for a stocker at the dyno: 179
Boost: 16.5
EGT: 1060 and lower
Fuel: 91 octane
Target AFR:?
SAE Corrections: none
Peak HP at RPM: 302.6
Peak Torque at RPM: 261.6
Mods: Stock EJ20, Super16g, perrin FMIC, Samco Inlet pipe, Helix TBE catless, TXS catless uppipe, Modified stock injectors, act 13.9lb flywheel, exedy stage 2 clutch, streetTUNER ecu.
Ambient temp: 60
Humidity: 30%
Magman is offline   Reply With Quote
Old 01-10-2006, 03:43 PM   #135
Member#: 58477
. Member #1 of
the witty MS Crew
catless turboxs stealthback
prodrive roundtip
helix uppipe
samco i/c hoses
cobb accessport
peak boost about 16psi
blue line was my first run that got me 220/220 then the next three got me 230+/230+. no changes were in between any of the runs.
red run was my best with 235/235.
i was hoping for 220/220 and got that but when i was told i got 10/10 more on the second run i was happy. it just kept going up.
intence is offline   Reply With Quote
Old 01-23-2006, 12:34 AM   #136
Member#: 79498
2013 XV
Default Protuned Stg 2
This was on the Mustang Dyno at Dieman Motorsports up in Lee's Summit (KC), MO,tuned by Doug from Top Speed. A stock WRX is supposed to put down around 175hp.
05 WRX Wagon, 91 octane
Mods (engine):
Cobb AccessPORT, ProTUNED by Doug from TopSpeed
Cobb Inconel Up Pipe
Cobb catted Down Pipe
Stock mid-pipe
Prodrive Muffler
USDM STi Intercooler
Samco I/C-TB hose
There's no base run since the first run on the Stg 2 base map wouldn't pull hard enough to trigger the end of the run, since AFR's were down under 10, and the car was making smoke signals out the exhaust. From the first run he was able to actually complete there was a 13hp and 14ft/lb improvement with the peaks coming earlier in the rev band in the final tune.
richde is online now   Reply With Quote
Old 01-23-2006, 07:55 PM   #137
Member#: 44725
2004 WRX wrb
Dyno: Dynamic Dyno (http://www.dynamic-dyno.com)
Fuel: 91 Octane
Peak HP: [email protected]
Peak Torque: [email protected]
Mods: Samco I/C hoses, Scoobysport single-tip muffler, Gp N motor & transmission mounts.
Gear: 2nd
Edit: updated for errors in program control inputs... still pretty good for almost no power mods.
JasonF is offline   Reply With Quote
Old 01-23-2006, 09:00 PM   #138
Member#: 100667
2002 WRX stage 4
Default 2002 wrx
2002 wrx
Vf34, Utec, 785cc injectors, headers, intake, tbe, fmic.
Tuned by Jorge at P and L motorsports
subeforlife2002 is offline   Reply With Quote
Old 02-08-2006, 09:49 PM   #139
Member#: 86078
2005 Sti
4094R Twin Scroll
Default Still needs some work...
2005 STI
Aps DR55
Aps 725 FMIC
740 cc injectors
255 fuel pump
Aps Tumbler deletes
Perrin Fuel Rails
Aps 3.5" turbo back exhast
Apexi Boost Controller (18-22-18 psi)
94 octane
Still needs dialed in better...
Mixture is not close enough to make proper hp and torque
I am having the MAF after the turbo in the Intercooler pipe going to the throttle body next week and tuned for it...
Will post the results...
shvrdavid is offline   Reply With Quote
Old 02-17-2006, 01:40 PM   #140
Member#: 97675
93 Stroked LS3 FD
Launch Edition 2015 STI
Default ej5-40t
high flow pannel filter, stock air box
ebay tmic *scooby* version (no fitment issues)
dc sports catless uppipe
stromung catless divorced wastegate downpipe
maddad 3rd cat delete non tapered
hks high power exhaust
ej5-40t turbo with ported wastegate
850cc stock modded injectors
91 octaine
marcus.raw is offline   Reply With Quote
Old 02-25-2006, 02:31 AM   #141
Member#: 99184
Fp-Red, perrin Big Maf, helix injectors, perrin 3" inlet pipe, SMC meth injection, APS turbo back exhaust, Turbo XS fmic, walboro fuel pump, tgv delete, act clutch, and topspeed protune.
LuSTi is offline   Reply With Quote
Old 03-26-2006, 12:21 AM   #142
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Default 05 WRX, EJ25, VF22, Cams, pump gas
05 WRX,
EJ25 (Wiseco pistons, STi rods/crank),
VF22 (too darn small),
264 cams,
Pump gas (Exxon 93),
water injection,
Modded Stock injectors,
Street Tuner... still needs work. Not my car, but my tune.
Look at the torque curve. One bar of boost at 3k rpm.
ImprezaRSX is offline   Reply With Quote
Old 03-27-2006, 04:23 PM   #143
Member#: 38567
2002 WRX Stage 4
Midnight Black
Performance Mods
Cobb Tuning AccessPort Protune - 18psi - 93 Octane
IHI VF34 Turbo
Hyperflow Top Mount Intercooler
STI Injectors
Perrin Fuel Rails
Walbro 255 ltr Fuel Pump
Intake Silencer Removal
AMSOil Air Filter
Perrin Uppipe
Ultimate Racing Downpipe w/ High Flow Cat
Borla "Hush" 3" Twin Tip Exhaust
Kartboy Exhaust Hangers
Exedy Sport Clutch
Kartboy Short Throw Shifter
Kartboy Shifter Bushings
Redline Shockproof Transmission Oil
Whiteline Steering Rack Bushings
Prodrive Springs
KYB GR-2 Struts
Perrin Rear Sway Bar & Mounts
Perrin Rear End Links
STI Front Strut Tower Bar (Replica)
Whiteline Rear Strut Tower Bar
Electronics & Gauges
Greddy Boost & EGT Gauge in A-Piller
Blitz FATT Turbo Timer
blkwrx02 is offline   Reply With Quote
Old 04-04-2006, 05:58 PM   #144
Member#: 109265
2006 WRX sleeved
built engine
Dyno: Ecutek on-road dyno (very similar to mustang dyno)
performance mods :
TD05h16g turbo tuned @16 psi (conservative tune)
custom up-pipe 2.5"
custom turbo-back 3" w/high-flow cat in downpipe
green air filter
pink injectors
walbro 255 pump
lightweight pulley kit
other mods not related to power : brakes, suspension etc.
juste_frank is offline   Reply With Quote
Old 04-19-2006, 04:58 PM   #145
Member#: 85896
2005 STi
Default PDX Tuned GT35R 2005 STi
Facility: PDX Tuning
Type of Dyno: DynaPack
Baseline # for a stocker at the dyno: about 250hp
Boost: 19.5 on 92oc and 27 on c16
Peak HP at RPM: C16=512 @ 6488 / 92oc=452 @ 6361
Peak Torque at RPM: C16=465 @ 4764 / 92oc=404 @ 4435
Mods: GT35R, Externally gated Tial44, Blow through MAF (custom aluminum big MAF pipe), Perrin fuel rails, PE850's, APS TGV deletes, TurboXS boost controller, DR725 FMIC, HKS SSQV, Walbro 255lph, exedy twin plate, drop in CP pistons. Cobb AP ProTuned by PDX Tuning
aspenwht05sti is offline   Reply With Quote
Old 04-19-2006, 05:05 PM   #146
Member#: 84547
06, Lafawnduh
Fender rolling king
this is on 92*
i am getting re-tuned on Saturday for the water/meth
C16*.... mmmhhaahaha
as well getting re-tuned on Saturday, dont know if i will see much of a differnce, but only one way to find out.
Perrin 816cc Modified Injectors
Perrin 4 inch inlet
Perrin Big MAF
Perrin FMIC Limited Edition with STi crinkle red coated piping
Perrin fuel rails
Perrin Radiator hoses
Perrin Catch cans
Perrin Vacuum hose’s
Perrin Rotated GT30r w/.82
Perrin rotated up/down pipes (jet hot coated & wrapped)
Stainless steel braided oil line
Invidia N1 CAT back exhaust
AVO headers (jet hot coated & wrapped)
Tial 44mm Exturnal wastegate
Walboro fuel pump 255lph
Worx DS2 Dual Stage BOV Limited Edition Wrinkle Red
ARP Subaru 2.5L DOHC head stud kit
new OEM head gaskets
STi NGK IX Iridium Spark Plugs
Mahle 1.209 x 3.917 22cc Inv Dome PowerPak Pistons
Tumble delete and port
Group N engine mounts
Aquamist WI 2d complete kit, with the race pump and high-speed valve
Aquamist DDS3 blue bar water injection monitoring system.
Custom 4 gauge ground wire kit w/negative battery terminal block
Odyssey Battery PC 680MJT
Samco ancillary hose kit
PWR radiator
Zero Sports thermostat
Zero sports radiator shroud
Drive train:
Alcon 370mm BBK
BF Goodrich braided lines
DOT 5.1 fluid
Exedy Hyper twin clutch and light weight flywheel
Kartboy short throw shifter
Kartboy front and rear shifter bushings
Full synthetic fluid in the tranny and rear diff.
Tein Flex Coilover’s
27mm Whiteline front sway bar w/ Whiteline endlinks
26mm IPD rear sway bar w/ mounts and Perrin endlinks
Fuji limited Carbon fiber front strut brace
Ebay special rear strut brace
GT Spec Latter bar
Performance alignment 1* negative camber
Diamond D6 12" sub in a custom slot ported box
Diamond Hex 6.5 components w/ crossovers and silk tweets in the front
Diamond M6 6.5 components w/ crossovers and aluminum tweets in the rear
Diamond D6 600x4 channel amp for the speakers
Diamond D6 1500x1 channel @ 1omn.
Eclipse AVN5495 head unit nav/dvd/r/rw/mp3/cd/am/fm all in w1nder
Tsunami 1.2 Farad capacitor
Tsunami Power block with digital volt meter
All in a custom sub floor
Custom gain knob
Passport 8500x50 Hard wired
Defi-Link Control Unit II wired to the armrest storage area
Defi-Link Meter BF EGT Gauge with high temp probe
Defi-Link Meter BF Boost Gauge
Defi-Link Meter BF Fuel pressure Gauge
Defi-Link Meter BF Oil Temp Gauge
Engine management:
TurboXS UTEC with map selector switch
TurboXS DTEC-BC-PRO w/ Knock Light detonation detector
JDM V9 SPEC C seats
Black carpet swap
Tein Hood dampers
Varis Carbon Fiber heat shield
Diamond Marquise 32 tint
Prodrive PFF-7`s
Kumho ECSTA ASX 235x35x18
McGuard Spline Drive Lugs
Kartboy long exhaust hangers
Custom WRC Rally pig sticker
Sparco Harness bar and 5 point 3” harnesses
JDM Black “I” badge
JDM Greddy turbo timer
Baked the head lights
PIAA clear blinker bulbs
L.E.D running lights
10k HID`s
Hella super tones
60 sq. ft. of insulation in the trunk
Double layer of Dynamatt over the trunk
Cut strips of Dynamat for the floor & did some custom insulation work
Custom carbon Fiber A, B, and C pillars, all dash trim, vent rings, and door card handles
Custom Leather shift boot, E-brake boot, and arm rest cover
Fog panel Custom ram air modification
Sparco 5 point 3" harnesses
Amerex 2.5 Lb. Dry Chemical Fire Extinguisher
Autopower Race Roll Bar
Sparco 3" Professional Nomex Harness Pads
First Aid Kit
Soon to come:
Re-tune on April 22 for the meth.
looking for a little more power on my dail driver map.
custom black door cards
black rear seats
new car alarm with GPS tracking
As always more bling.
BREWPUBEAVER is offline   Reply With Quote
Old 04-19-2006, 10:30 PM   #147
Member#: 83590
2004 WRX STi
Platinum Silver
Default Dynapack Dyno (04 STi)
This is the dyno sheet from the tuning of my UTEC after my first round of mods:
TurboSmart Dual Port BOV
AEM Short Ram
3" cat-back exhaust
TurboXS UTEC with Turbo Bleedoff
DEFI A Pillar Mount w/ Boost and Oil Temp Guages
Sc00byD00d is offline   Reply With Quote
Old 04-21-2006, 11:25 PM   #148
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
XX-tuning, CT
VF34 @ 17.5psi
STi pinks
Borla header and Hush catback
Perrin uppipe
Stock intake box
Mad dad catted downpipe
Perrin crank pulley
Old 04-21-2006, 11:36 PM   #149
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
Car: 2002 WRX
Facility: Torque Freaks, Portland, OR
Baseline # for a stocker at the dyno: Don't know
Boost: Target of 18 psi for this run
Fuel: 92 octane pump
Target AFR: 11.4, I believe
Peak HP at RPM: 284.18 at 6050
Peak Torque at RPM: 263.85 at 5500
Mods: VF34, FMIC, UTEC (with LC and FFS), DTEC-BC Pro with 2 solenoids, Tial 38mm EWG, Unorthodox underdrive pulley, RA gears, ACT Street Disc, Exedy 12.5? lb lightened flywheel, Walbro pump, Ultimate Racing 600cc injectors, custom uppipe, custom (and hacked up) downpipe at the time (now Invidia bellmouth), BPM 3" midpipe with 1 cat and 1 resonator, Prodrive 2.5" axleback
shikataganai is offline   Reply With Quote
Old 04-29-2006, 05:41 PM   #150
Member#: 78074
2005 STi
so i got dyno'd today at a dyno day at pro-motion in fredricksburg, VA. I'm kinda upset with the #s. i did not have air going directly into my i/c , it was just a small blower in front of my bumper... = mad heat soak.. which is why i knocked on the 2nd run im guessing
cobb catless tbe
helix up pipe
txs utec @ 17psi
perrin i/c hoses
gp moto short ram
kcook is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
