Old 05-07-2006, 01:57 AM   #151
subenerd
Member#: 72630
2004 STi
Power mods:
2002 wrx wagon ~ 55K miles
Gutted uppipe
TurboXS turboback w/highflow cat/standard muffler
TurboXS TMIC
Silicone IC hoses
Iridium sparkplugs-1 step colder
Fun setup When floored it spools to 16-17lbs of boost by ~3000 rpms and holds it throughout the rev range tapering to 14psi near redline. Tune done by Mike at Gruppe-s on 91 octane. Supposedly their 'heartbreaker dyno' reads low...all I know is that this basic setup kicks major butt!
subenerd is offline   Reply With Quote
Old 05-22-2006, 02:35 PM   #152
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
1 step colder plugs
perrin EBCS
MRT intake
Invidia catless tbe
Coolingminst meth kit
all else stock
21 psi
Protune is the light lines, darkers is the meth tune , 50/50 mix
xrocket21 is offline   Reply With Quote
Old 05-29-2006, 05:42 PM   #153
UKP1
Member#: 116199
2001 Prodrive P1
Sonic Blue
will try and post mine up just waiting to make sufficient posts to allow me
UKP1 is offline   Reply With Quote
Old 06-05-2006, 10:20 PM   #154
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
here is my new dyno plot
forged 2.5l sti block
p&ped wrx heads with helix 264 cams,and 85lbs springs
aps headers
aps turbo inlet
aps 70mm coldair intake
aps sr55
aps bov
aps dr 725 fmic
lazer platinum plugs
helix 820cc injectors
invidia dp random tech to blitz tail
ecutek
sonic rx is offline   Reply With Quote
Old 06-06-2006, 02:47 AM   #155
AZRally
Member#: 103491
2013 Audi S4
06 STI
Perrin Signature FMIC
Perrin Crank Pulley
Perrin 3" Catless DP
Greddy Evo2 3" Catback
Injen CAI
Nismo 740cc injectors
Walboro Fuel pump
Ecutek
FP Green
91 octane in AZ SUMMER HEAT!!! IE 109 Degrees outside!
AZRally is offline   Reply With Quote
Old 06-06-2006, 03:13 AM   #156
Davenow
Member#: 23676
How many of you over 400whp have made it out of the 13s yet?
dyno sheets arent worth the paper they are printed on.
Old 06-06-2006, 09:23 PM   #157
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
can you guys post who your tuner was?
Old 06-06-2006, 09:30 PM   #158
AZRally
Member#: 103491
2013 Audi S4
12.8 on 255whp, and most will agree that this still sucks. See my recent post for current power.
Old 06-07-2006, 08:47 AM   #159
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
TUAN from GRD PERFORMANCE in naperville was my tuner
Old 06-07-2006, 09:24 AM   #160
Owenator
Member#: 53034
2007 OBP stealth STI
COBBStg2.WRXwing.fogLites
I believe you want this thread for time slips: "Attach your Timeslip Pic here"
because you posted in "Post your Dyno Plot and Mods, see format inside"
Owenator is offline   Reply With Quote
Old 06-07-2006, 07:28 PM   #161
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
VF34
STi TMIC
K&N panel filter
Ported and coated exhaust manifold
Mad dad catted version 1 DP
Perrin UP
Borla Hush CB
Perrin crank pulley
One step colder platinum NGK plugs
Tuned by Chris at XXTuning
Old 06-09-2006, 11:43 PM   #162
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Default Howzabout some N/A results?
Car: 1997 Legacy 2.5GT sedan 5-speed
Facility: Extreme Motorsports, Odenton, MD
Type of Dyno: DynoJet
Baseline #: unknown
Boost: N/A
Fuel: 89 Octane
Target AFR: 13-13.5:1
SAE Corrections: basically 1.0
Peak HP at RPM: 168 @ 6100rpm
Peak Torque at RPM: 153 @ 5000
Temp: ~80degF
Mods:
- 167k mile stock EJ25D DOHC shortblock
- Cobb Stage 1 ported heads
- Cobb Stage 1 "street racer" cams
- Injen CAI
- MRT header
- 2.25" header back - metallic substrate hi-flow cat, MRT midpipe, Stromung muffler
- Fidanza aluminum flywheel
- S-AFC
- Quaife-type front diff, Cusco 35f/65r Tarmac Gear center diff, Cusco RS rear LSD (I don't imagine these would affect the power put down, but I dunno)
The graph:
The blue curve is what the car laid down when we first put it on the rollers. The ECU had last been reset probably a week or so ago, S-AFC settings were as I had set them in the past (based on dyno time and, later, some limited wideband "tuning" with my LM-1). After doing the initial run, I unhooked the battery to reset the ECU and then did some more runs. The red lines are from the 1st run after the ECU reset and that's the highest HP figure the car put down. Interestingly enough, that's with the S-AFC all zero'd out, which is strange because 4 years ago (the last time it was on the dyno) the car clearly gained top end when I leaned it out with the S-AFC.
Clearly, at the low end into the mid-range, the graph looks like ass - this is due to the car pulling timing (for reasons unknown). You can see where it really jumps in around 3250rpm or so on the red (post ECU reset) curve. With each additional run that got earlier and earlier in the RPM band, so by the final runs the timing was being pulled from about 2500rpm on up to 4000rpm. Once it gets to open loop around 4000rpm, though, look out! Today or tomorrow I'm going to install the "hesitation fix" on the knock sensor and see what that does. More on that at a later date...
As an example of how differently dynos can read, this car put down 142whp on a Dyno Dynamics dyno back in 2002. At that point it had 100k miles or so on it (I'll have to go look that up), it now has nearly 168k miles on it. If anything, I would expect it to be making less power now than it did 4 years ago, yet the slightly-more-optimistic Dynojet has it cranking out an extra 26hp.
Pat Olsen
Old 06-10-2006, 03:46 PM   #163
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Pat, great car makes as much power as WRX...
Old 06-13-2006, 10:13 PM   #164
jus2quik
Member#: 111237
2006 WRX Wagon
Mona Vie distributer
2006 WRX wagon, 3500 miles on odometer
Ebay (ssautochrome) TMIC
Turbo XS DP and race pipe
Cobb catback
Ecutek Tune by Ben at Performance Driven in Jacksonville,Florida
jus2quik is offline   Reply With Quote
Old 06-15-2006, 12:59 PM   #165
mrbalwrx
Member#: 53502
2012 WRX
Default Harman STI Stg2 Tune
http://pg.photos.yahoo.com/ph/mrbals...nm=c559scd.jpg
STI stg2 Tune
04 STI
Utec
Tuna
Injen CAI
Perrin Inlet
PDE catted downpipe
Injen SES catback
Thanks Dan. www.harmanmotive.com
mrbalwrx is offline   Reply With Quote
Old 06-22-2006, 02:22 PM   #166
AREA1320
Member#: 112508
01 2.5RS with 04 USDM swap
Full stage 4
VF34
Pinks
E-MotorUK GC8 fmic
TXS intake
UR pulleys
HKS up and down pipes
Greddy SP2 catback
UTEC
ACT clutch
Exedy flywheel
Tuned by Andy at Xotic Motorsports
www.xoticmotorsports.com
293.16hp 272.46ftlb torque at 19psi. no alcohol. no water. factory boost solenoid didnt like 20psi and bled it off.
11.4 a/f
AREA1320 is offline   Reply With Quote
Old 07-15-2006, 06:20 PM   #167
CrazyJ
Member#: 60235
2004 WRX Wagon
Java Black
Gt35 Turbo
Crower Cams #2
Crawford S2 shortblock
15 psi boost on 91 Oct.
CrazyJ is offline   Reply With Quote
Old 07-15-2006, 07:15 PM   #168
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Originally Posted by CrazyJ
Crower Cams #2
pic is a tad small.
Bishop is offline   Reply With Quote
Old 07-17-2006, 12:44 AM   #169
size18boarder
Member#: 118637
2004 Sti w/sr55
jpb
Gt35 Turbo
Crower Cams #2
where do you see full boost by?
why is boost set so low?
u rotated?
how much did cams+shortblock set you back
size18boarder is offline   Reply With Quote
Old 07-18-2006, 12:13 AM   #170
CrazyJ
Member#: 60235
2004 WRX Wagon
Java Black
u rotated?
I wanted it really conservative. Only time i up the boost is on track days on race gas. and yes its a rotated. full boost hits around 4500rpm. Make sure u have a 6mt. 5mt takes FOREVER to get there.
Old 07-24-2006, 12:54 PM   #171
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
Stock 02 wrx block
IHI-vf34
STi 565cc pinks
TurboXS downpipe
TurboXS up-pipe
Strait pipe/midpipe (taper to 2.5")
Prodrive Muffler
Perrin Inlet hose
Ebay intercooler
stock air filter
iridium plugs one step cooler
Cobb Accessport vf34 maps
Walbro 225Lph pump
stock driveline
exedy stage 1 clutch
UNTUNED
psyber_0ptix is offline   Reply With Quote
Old 07-25-2006, 02:53 AM   #172
Udonboy
Member#: 40788
2004 WRX Sedan
2004 WRX Sedan
Facility: Harman Motive
Type of Dyno: Dynojet
Boost: 14psi
Fuel: 91 Octane pump
Peak HP: 239.22
Peak Torque: 272.27
Mods:
2.5L STi Shortblock
WRX Heads
TD04 w/ stock injectors
Gutted Up-pipe
Maddad V2 Downpipe w/ 3rd Cat delete (3" flange)
Borla HUSH catback
Blue lines are the 91octane map. Red lines are the "economy" map.
Udonboy is offline   Reply With Quote
Old 07-26-2006, 05:40 PM   #173
wpc
Member#: 119632
2005 WRX
Facility: P&L Motorsports
Baseline # for a stocker at the dyno: ???
Boost: 15 psi
Fuel: 93 and 102 octane
Target AFR: High 11:1
SAE Corrections: ???
Peak HP at RPM: 93 Octane, 198 @ 5500 rpm; 102 Octane, 208 @ 5500 rpm
Peak Torque at RPM: 93 Octane 204 @ 3750 rpm; 102 Octane, 220 @ 3750 rpm
Mods: SPT Intake, SPT Exhaust, Cobb Protune by Jorge Carillo
Temp: 91 degrees F
Humidity: Humid Chicago Day
Barometric Pressure: 29.62 in-Hg
Could not figure out how to post a picture of the dyno print out.
wpc is offline   Reply With Quote
Old 07-28-2006, 02:37 PM   #174
pornie
Member#: 5620
You need to host at a place like Imageshack.us
Car: 05 WRX
Baseline # for a stocker at the dyno: Unknown
Boost: 14psi
Fuel: 93
Target AFR:
SAE Corrections: 1.05
Peak HP at RPM: 211@ ~5300rpm
Peak Torque at RPM: [email protected]
Mods: Cobb AP stg 1 93oct OTS, Stromung catback
Temp: 92 degrees F
Humidity: 49%
Barometric Pressure: 29.19 in-Hg
Click for blah blah blah
pornie is offline   Reply With Quote
Old 08-05-2006, 12:39 PM   #175
crikreef
Member#: 69101
04 FXT
Car: 04 WRX
Facility: iSpeed (San Diego)
Dyno: Dynapack
Temp: ~75F
Boost: Stock
Fuel: CA 91
Mods:
Perrin Catback
I was impressed.
First one is at the fly...
This one is WHP...
crikreef is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
