Old 10-26-2006, 12:35 AM   #201
WRXBOOST10
Member#: 120654
02 wrx 07 Sti
silver/BLack
Don't know how to post pic/graph anyways
297hp and 276t on 91cali gas 75 degrees ambient temp(Fineline Imports Mustang Dyno)
Stock wrx puts out 160Hp on this dyno
Engine Modds-
FpTD05-18g ported inlet and outlet
TurboXS TMIC
Samco Intercooler hoses
Helix catless upipe/downpipe
Blitz Nurspec Catback Exhaust
Power Enterprise 820cc injectors
Walbro 255lph pump
Agency power headers
Prodrive boost solenoid
Perrin Turbo inlet
Perrin short ram intake
Perrin lighten crankpulley
Hit 18.5 Psi @3400 rpm
WRXBOOST10 is offline   Reply With Quote
Old 10-28-2006, 06:37 PM   #202
Aleksey
Member#: 23445
2007 STI
2004 Forester XT
TD06-16G
Stock STI TMIC,
cattless uppipe
3" TurboXS stealthback
2.5" prodrive axelback
Protuned by PDX
286whp, 326wtq
13.2sec 1/4 mile
Aleksey is offline   Reply With Quote
Old 11-13-2006, 04:20 PM   #203
banilla
Member#: 121864
03 WRX Wagon
Default vf39 wrx
2003 wrx wagon ej205
ihi vf39 turbo
sti pink 550cc injectors
usdm sti tmic
aem cai
tgv deletes
aps turbo inlet
perrin uppipe
mrt 3" turbo back
samco hoses
crappy ca 91octane winter fuel
banilla is offline   Reply With Quote
Old 11-22-2006, 07:33 PM   #204
DuckStu
Member#: 124060
2004 WRX STI
2004 STI, 55,000 miles
Tuning factory, Novi Michigan
Dynapack 5000 hub dyno.
HP 323.2
TQ 318.6
93 octane Amocco
AFR 10.8 measured
Hp type, SAE corrected
Boost, 19psi at 3,500 rpm tapering down to 17 psi.
Little if any airflow over the intercooler
Mods:
HKS headers
18-G Turbo, 8cm exh housing (wheel unknown)
Perrin DP (ported)
Perrin crank pulley (light, but stock size)
3" into 2.5" catless home made exhaust.
ESX top mount intercooler
Perrin Turbo inlet hose
Injen CAI
APS recirc valve
ECUTEK ECU reflash
740cc injectors
Walbro FP
DuckStu is offline   Reply With Quote
Old 11-25-2006, 06:46 PM   #205
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
1990 legacy wagon
Mods
199? Engine case
1993 EJ22T Crank, Rods and Pistons
New main and rod bearings
2.0 DOHC twin turbo heads and intake manifold
550 STI Yellow Side Feed Injectors
1-1 RRFPR
M62 Eaton Supercharger
Mishamoto FMIC
Perfect Power 6
Running about 11 psi.
Old 11-29-2006, 02:04 PM   #206
JJzSTi04
Member#: 114253
04 Subaru sti
Facility: MZM PERFORMANCE
Type of DYNO: MUSTANG
Baseline # for a stocker at the dyno: 170-180whp
boost: 24 by 4k, 29psi by 5700
Fuel:tt105
Peak HP at rpm: 438whp
Peak Torque: 403
mods: stock engine,clutch,fmic,gt35r,740cc,255lb/ecutek/profecb boost controller/ exhaust/intake/etc...
JJzSTi04 is offline   Reply With Quote
Old 12-02-2006, 04:59 PM   #207
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Facility:Japtrix FL
Type of Dyno:Mustang Dyno
Baseline # for a stocker at the dyno: 240
Boost:18
Fuel:93
Target AFR:11.3
SAE Corrections:
Peak HP at RPM:271
Peak Torque at RPM:319
Mods:Stromung down pipe (catless), Stage 2 flash, Perrin drop in filter
STISTL is offline   Reply With Quote
Old 12-03-2006, 12:49 PM   #208
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
Car: 2004 STi
Facility: Xotic Motorsports - Cochranville, PA
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: around 250-255 or See run one
Engine Management: Cobb AccessPort v1
Fuel: 93 Octane
Mods: For Stock Baseline and Stage 1 Baseline - completely stock drive train
For Stage 2 Baseline - Cobb DP w/ cat, no other mods (stock catback)
For stock pull October 11, 2006
Temp: 73.6 F
Humidity: 49%
Barometric Pressure: 29.1 in-Hg
For Stage 1 pull October 11, 2006
Temp: 72.5 F
Humidity: 51%
For Stage 2 pull November 30, 2006
Temp: 73.6 F
Humidity: 43%
Barometric Pressure: 29.3 in-Hg
Corrections: STD
Peak HP at RPM:
261@ 5800 rpm Stock
282@ 5500 rpm Cobb Stage 1
297@ 5500 rpm Cobb Stage 2
Peak Torque at RPM:
265@ 4500 rpm Stock
306@ 4000 rpm Cobb Stage 1
315@ 4000 rpm Cobb Stage 2
background: Stock and Stage one pulls were done back to back on dyno, Oct 11,
w/ Stage 1 flash and 'run in' on dyno in between runs.
Cobb catted down pipe and Stage 2 flash done November 19.
Stage 2 pull was done Nov 30
I most pleased w/ TQ improvement at 3000 rpm, and total area under the curve now.
plans: IOTA PnP exhaust manifolds from living room to car,
Injen Crosspipe for Christmas
Street Tuner + tune from Andy.
ekw is offline   Reply With Quote
Old 12-08-2006, 09:50 PM   #209
lil shoaf
Member#: 93776
2002 Impreza WRX
Conservative Tune for my "STOCK" WRX Transmission.. TMIC Snuffed out the Turbo and stopped the power gains.. FMIC now installed, awaiting retune... All on PUMP 93..
lil shoaf is offline   Reply With Quote
Old 12-08-2006, 10:52 PM   #210
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
El Gato is offline   Reply With Quote
Old 01-06-2007, 07:50 PM   #211
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
1990 legacy wagon, with a retune and better FMIC
192 whp and 212 torque.
Torque line, not curve
Mods
199? Engine case
1-1 RRFPR
12x28x3" Ebay SSAUTOCROME FMIC
Perfect Power 6
Old 01-12-2007, 06:26 PM   #212
ryantherobot
Member#: 129692
2011 WRX Sedan
Obsidian Black Swirl
06 STi.
Facility: Harman Motive
Baseline # for a stocker at the dyno: 240ish?
Boost: 18psi on 91oct, 19psi on 95oct
Fuel: 91/95
Mods: AP v2, Cobb DP w/ cat, HKS CBE, K&N drop in.
SUUUUUUPER happy!! pulls and pulls and pulllls
ryantherobot is offline   Reply With Quote
Old 01-14-2007, 11:36 PM   #213
xSTIx
Member#: 78906
2005 Subaru STI
'05 STI
39000 miles
ALL STOCK
50 Degrees/50% Humidity
93 Octane
Dynojet 4th Gear pull
267whp/281WTQ
xSTIx is offline   Reply With Quote
Old 01-23-2007, 03:07 PM   #214
Carreragt2e
Member#: 130877
2013 Cayenne GTS
that is whp, 17.5psi boost, the only thing I forgot when I had it dynoed was to up the boost back to 19 ( I believe thats what the vishnu ecu tune was reflashed for, could be wrong, feel free to correct me) . It was running 19 fine in warmer weather, but started having issues on the freeway with the cold weather so i turned it down. o well, Im still happy with where its at.
mods
Vishnu Performance Reprogrammed ECU,Vishnu Power Pulley Kit,Vishnu Signature Series Down pipe,Perrin dual stage drop in panel filter,IHI VF34 turbo,Walbro 255lph fuel pump,STI 565cc pink injectors, Blitz Sequential Boost Controller-ID V2, HKS SS BOV STI JDM Top Mount Intercooler Samco Intercooler hoses Omori EGT gauge Subaru column mounted boost gauge kit, GT Spec Gen 2 Header, Daddy’s 3rd cat eliminator, JIC Bullet 505Ti exhaust
Drive train:
Exedy 1 piece 12.7 lb. flywheel,Exedy Sport Clutch,STi Version 6 RA Gearset
:green: but needs a tune so I can get closer or over 300, but I gotta figure out what I want to use for that first. more studying to do befor that. Im not going all out crazy as this is my only car
thanks!
-Eric
Carreragt2e is offline   Reply With Quote
Old 02-11-2007, 01:53 AM   #215
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Twin charged 1990 Legacy, the latest dyno
284 hp and 305 torque @ 21 psi and 291 hp and 317 torque at 22 psi.
As for the AFR range... My uppipe wideband (Bosch sensor with AEM) read ALOT different... But I didnt knock once...
I wanted 300 hp, but 9 psi wasnt worth breaking something.... Once I actually have a decent exhuast, external wastegate installed, I will be there....
199? NA open deck Engine case
3-1 Vortecg RRFPR
GT30 equivilent turbo
SS Autochrome FMIC
9" Crank Pulley
2.5 downpipe and exhaust
6 puck disc
Forester flywheel
RS pressure plate
Perfect Power 6
Plus GOBS of time....
Old 02-17-2007, 11:49 PM   #216
El Gato
Member#: 110648
93oct 479whp 456tq
Old 02-26-2007, 01:03 AM   #217
oxymoron
Member#: 80643
Car: MY05 Foretsr XT with STi 6 Speed
Type of Dyno: Dyno Dynamics Roller Dyno
Baseline # for a stocker at the dyno: 120 wkw (163whp)
Engine Management: EcuTek Custom Tune
Fuel: Australian Spec 98 Octane which is similar to you 93 i think?
Mods:
AVO 400L Turbo
X-Force 3" TBE
GT Spec Headers and Up-Pipe
Process West FMIC
Process West CAI
Silicon Turbo Inlet
Sard 650cc Injectors
MRT Fuel Rails
Walbro 550hp Fuel Pump
Sard Rising Rate Fuel Regulator
STi Inlet Manifold
TGV Deletes
E-Boost 2
235 wkw = 320whp
oxymoron is offline   Reply With Quote
Old 03-09-2007, 11:37 AM   #218
brendan_mac
Member#: 125055
12 STI hatch
Nothing Fancy: [2002 Wagon]
R.R. D-pipe
R.R. Up-Pipe
Reflash and Custom tune ecu
One Stage Colder Plugs
This dyno is a heartbreaker with no correction.
For Comparison: Stock STi =>
brendan_mac is offline   Reply With Quote
Old 03-16-2007, 10:05 PM   #219
urfsin
Member#: 128975
2005 Outback XT
Golden Thunder
05' Outback XT
The blue line is my "off the shelf" stage 1 TDC tune. Bone Stock, just AP v.1
The red line is my "off the shelf" stage 2 TDC tune. Megan Racing UP, gutted stock DP and Mid Pipe. Everything else was stock.
This was back in October 06'. I now have a K&N drop in filter, Perrin EL headers and a Megan Racing turboback. I will get a pro tune at some point in the near future. I hope to get 275 AWHP and 320 AWTQ.
urfsin is offline   Reply With Quote
Old 03-20-2007, 02:42 PM   #220
dhunckyn
Member#: 98553
2013 WRX Hatch
First I would like to thank Nathan (for the great tune) and the guys at Pro Power Dyno Service (for their hospitality and great faciltiy). cheers.gif The car feels great, much smoother than before and the added power is noticeable. On Cobb's Mustang dyno I was 251/285 with an APS TMIC. Now 311/332 on a Dynojet dyno. Not sure how much of a increase it is but it does feel much better, maybe 20+ more hp????
old Dyno
Current mods:
VF39 from STi
Perrin FMIC
Perrin shorty Intake
Cobb TBE
ProTune by Nathan
Clutch Masters FX300 Clutch
Clutch Masters lightweight Flywheel
Prodrive Springs
Whiteline swaybars
Whiteline Diff Bushings
Seibon carbon fiber hood
SSR 17x7.5 Comp Wheels 225/45-17 tires
SSR 18x8 GT10 Wheels 225/40-18 tires
..and some other stuff I'm sure I'm forgetting about
dhunckyn is offline   Reply With Quote
Old 03-26-2007, 04:36 PM   #221
bmooney33
Member#: 130012
04 wrx w/sti block
2004 wrx
STi short block w/WRX heads (compression much?)
perrin big maf
perrin crank pulley
act clutch/flywheel
perrin turbo inlet
turbochargers.com 8cm frank 50 (externally gated)<--- take that FP worshipers!!!
bosal down/midpipe
apexi world sport II catback
modded stock injectors
warlboro 255lph pump
gtspec header/uppipe
PPG gearset tranny
turboxs fmic
TUNED BY DAVE BROWN @ MSPT in HUNTINGTON, NY
those are all i can think of as of right now lol.....but now, onto the sheet
the power falls off really fast, i know...my plugs took a crap on the way to the dyno (ironic, i know) went and got a hotter plug, changed em in the parking lot....then got it workin, set the boost and went on the dyno....
done at no limit motorsport in medford, ny
PUMP GAS BTW
the pull
http://www.youtube.com/watch?v=ERirYV0fXyM
http://www.youtube.com/watch?v=Weg9X9GuZoo
bmooney33 is offline   Reply With Quote
Old 03-27-2007, 02:53 AM   #222
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
04STi
Crower Rods
Ceramic and Moly skirt coated Wiseco Pistons 100mm (CR set at 9.1:1)
SMC Injection (75%Meth) 15GPH nozzle
TGV Deletes
APS FMIC
Exhaust
49lb FP/TC FrankenGreen Turbo
External Wastegate
93 Octane
blah blah blah
Open Source Tune by Me on TDC's Land and Sea DynoMite.
Engine Built by me.
My good friend's car; Byron O'Hara is his name. Same car in the October 2006 issue of SuperStreet.
The higher compression ratio is why the car makes more power to the wheels than most 49lb wheel turbos. Turbos are rated for a HP based on a BSFC and VE. This car is more efficient and therefore gets more power than the normal rating. That's the main reason I run all my built engines in the 9.X:1 ratio area. Breaking all four loose in 2nd on a roll is fun.
Many thanks for Jon at TDC Tuning for letting me play on the dyno for so long. It's nice when tuners get along. He's a great guy and can't wait to party with him at SubyFest!
ImprezaRSX is offline   Reply With Quote
Old 03-29-2007, 12:48 PM   #223
dsmkid95
Member#: 94155
06 CGM STI
Stage 3
Had my car tuned by Tuan over at GRD in Naperville Illinois.
Dyno: Dynopack Chassis Dynamometer
Car: 06 STI
Mods:
Invidia Catless TBE
Perrin Panel Filter
AP V2
Outside temp. 57F
On a protune i made:
293HP
305ft.lbs
i will post the graph once they email it to me. i couldnt be any happier with the tune. Tuan really knows his stuff.
dsmkid95 is offline   Reply With Quote
Old 03-30-2007, 10:24 PM   #224
Jhovany
Member#: 137317
2006 STI
Rally Blue
Jhovany is offline   Reply With Quote
Old 04-01-2007, 01:33 AM   #225
03RexWgn
Member#: 85929
07 Stage 2 UGM STI
2007 STI
Facility: Harman Motive www.harmanmotive.com
Baseline # 262 hp 275 tq
Boost: stock
Fuel: 91 and 95 octane
Target AFR: Unknown
SAE Corrections: uncorrected
91 octane Peak WHP at RPM: 302.8 @5500 RPM
91 octane Peak WTQ at RPM: 329.3 @ 3500 RPM
95 octane Peak HP at RPM: 308 @ 5500 RPM
95 octane Peak WTQ at RPM: 350 @ 3600 RPM
Mods: Maddad 3" bellmouth dp with high flow cat- Maddad twin tip 3" exhaust, K&N dropin, GP Moto elbow, Accessport v2.0 and Protune. Suspension: F/R whiteline sways with kartboy links.
03RexWgn is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
