Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-17-2005, 02:56 PM   #1
jlee8196
Member#: 22211
Default Full boost at Part TPS. with Hydra. OK?
I've notice that I can get ~16psi under 50% TPS @ ~3.5K rpm /w my Hydra
Good or bad?
If I'm getting currect AFR it should be no problem. right?
Anyway to controll boost by TPS?
jlee8196 is offline   Reply With Quote
Old 01-17-2005, 08:39 PM   #2
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
The PTFB issue is with factory ECU cars that will stay in closed loop at low TPS, causing the car to want to run stoich. As long as your A/Fs are correct for your boost, PTFB isn't an issue.
BAN SUVS is offline   Reply With Quote
Full boost at 2400 RPM read on for more info manchild83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 12-22-2004 11:35 AM
Full boost at what RPM? 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-23-2003 05:13 PM
Full boost at part throttle no longer an issue? desiwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 99 05-10-2003 09:58 AM
Full boost at what RPM? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2003 10:13 PM
Why is full boost and part throttle bad? corallo99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-25-2002 09:21 AM
